Question about Dell Dimension 2400 PC Desktop
Hard drive crashed
I have a Dell Dimension 2400. Without warning the hard drive crashed. Is there any way I can access and retrieve info I had on this hard drive?
  • bjjs434 Feb 12, 2009
    Not sure what you mean by does it spin up. Windows won''t load has a blue screen eroor code (IDE failure) and when I tried to reinstall XP it would load up the drivers but then nothing.
  • rick
    rick May 11, 2010
    Does the hard drive spin up?
    Habit-Forming:
  • 21 Answers
I have a similar problem. You have a bad hard drive. If you want to use your computer, you are going to have to boot the hard drive manually. To do this, simply start the computer normally and quickly press F12 repeatedly. At the options screen, select number 2, "Hard Drive (C):" and your computer SHOULD load up normally. I hope this helps!
Posted on May 27, 2009
    President:
  • 1,179 Answers
It all depends. Best bet is take it to a data recovery professional & see if they can recover anything for you. Hope this helps.
Posted on Feb 10, 2009
  • Roy Lonsinger
    Roy Lonsinger Feb 12, 2009
    The IDE failure could mean 1 of 2 things. Most obvious is the hdd itself has went bad, no spinning sound coming from it would show it not having power. 2. Worst case is if the ide controller on the motherboard went bad. If you can enter bios setup you can see if the controller is enabled & working. If it is then the hdd itself has went out. You may possibly be able to recover data but it would be something a data recovery specialist should determine. Hope this helps.
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
That is a western Digital Hard drive compatible with most computers even Dell Computers
May 15, 2014 | Dell Dimension 2400 PC Desktop
My dell dimension 2400 isnt acknowledging cds in the e drive yet it says that the drive is ok. Can I get it to read them again?
Is it a CD drive, a CD burner, a DVD drive, a DVD burner or a Blu-Ray drive? Have you tested all types of cds for the drive? Do certain ones read and noth others? What version of Windows are you running? Did it stop working after a program install or a system crash?
Nov 08, 2011 | Dell Dimension 2400 PC Desktop
On dell dimension 2400 desktop Primary Drive 0 not found. When I hit F12 it does nothing. I can't get to the Diagnostics page.
More than likely your hard drive has crashed. You'll need to replace it and reinstall the operating system.
If you'd like to try and mount the drive to recover files, I'd recommend downloading and burning ubuntu onto a cdr and launching the live version (advice for advance user)
If you'd like a Pro opinion I'd recommend finding a local repair shop that does FREE diagnostics.
Hope this info helps!
Oct 10, 2010 | Dell Dimension 2400 PC Desktop
What to do after installing a new hard drive?
Download and install the drivers from support.dell.com
Install them in this order
http://www.fixya.com/support/r4432358-proper_order_install_drivers_dell
Apr 04, 2010 | Dell Dimension 2400 PC Desktop
I had to reload my windows xp reinstallation resource cd a couple of weeks ago. Now I am unable to access the internet. I installed all the drivers that needed to be installed. I have DSL and the ISP...
Try this, go to your device manager and uninstall all your modem info from your computer. Restart your computer and let the drivers reinstall. Might want to have the CD for your modem. What has happened is when you reinstalled your windows it place part of your computer back to default mode. In order to place the entire computer back to factory default you have to format your hard drive than reinstall your systems disk. Only problem you lose all your info. I recommend to people to use a external hard drive these days and place all your personal information on this. If I was there I could take care of it for you. There's only so much I can send you without knowing all the facts. Try sending me more info after you try this. Feel free to contact me.
JimmyC
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Capable of upgrading more?
well i would say you really dont need to upgrade everything is cool with your computer really so it would just be a waste of money
Dec 19, 2008 | Dell Dimension 2400 PC Desktop
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Replaced hard drive
try connecting it as slave and after rebooting the system, your harddrive may be recosnise by the system. after copy the data and format this HDD in low level.
Jul 29, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 with secondary SATA hard drive keeps crashing
generally all computers can handle a secondary hard drive. i myself am a dell tech. why not try to increase the wattage output of your power supply from the present 200 or 250 watts to at least 300 or 350 watts to give enough provisions for additional devices that will be connected to your computer. normally a hard drive will get burned or fried because of a loose power cable connection. data cable will never fry your hard drive. try running the hard drive diagnostics if it passes then it should work well. try also using chkdsk /r in the command prompt to fix your hard drive if the damage is not that extensive.
Jun 20, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
95 people viewed this question
Alun Cox
