Question about Motorola Mobility C975 Cellular Phone
My motorola c975 powers off when charging
If I connect the desktop charger with the phone on it switches itself off and displays the charging screen. It also does not show if the battery is full. The indicator is always red when the charger is connected. I tried to connect the phone using a USB cable. The phone will not stay on as the cable also charges the phone. Because of this, I cannot back up my phone numbers or copy my pictures onto the PC. Any solutions are welcome. Thanks.
SOURCE: Motorola E815 - Battery Charger
The E815 has a very poor design on the charger port. The cleaning that Solution #1 referred to is that Verizon cleans the contacts of both the phone and the charger using rubbing alcohol on a toothbrush to clean both the phone contacts and the charger contacts. I have to do this once a week or so to keep my phone charging. The rubbing alcohol dries quickly and will not harm the phone. Motorola has changed the charging ports on the newer phones because they recognize that they have a problem with this design. I have also turned in my phone to Verizon (twice) for a replacement. If you replace the phone be careful to record ALL your contacts because when Verizon transfers your contacts from the old to the new phone the speed dial numbers all get messed up because they start their numbering differently than you had it. I am still repairing my speed dial numbers. Hope this helps.
Posted on Sep 07, 2007
soldierruel
  • 175 Answers
SOURCE: Motorola razor v3 display problem
If the charger is not an original motorola charger,, then you have a problem. make sure its original.
Posted on Oct 16, 2006
SOURCE: C975 Navigate switch
stick it in your ********
Posted on Apr 15, 2008
SOURCE: Picture Capture Failed Motorola C975
you can restart your phone it's ok
Posted on May 14, 2008
  • 18 Answers
SOURCE: phone can not be identified by the pc. it wants the usb charging
micro sd card has a built in driver on its own, all you have to do is to unlock your phone and connect the cable to your phone and your pc.. press "yes" on your phone questioning you "connect as a storage device" or something like that.. then you can start file transfer from pc to phone and vice versa..
Posted on Feb 11, 2009
Why does my Motorola Admiral not turn on automatically when it's plugged into a charger?
it's not to worry about your phone when your phone does not start automatic because in the only region off your better dead. you just live your phone into a charge sometimes after you can see your phone is automatic restart
May 17, 2017 | Cell Phones
Plz give me the unlock code for Motorola C975 imei 354910006648135
hi you can get the codes from this site theunlockspot to unlock your motorola c975 mobile .here they ask the country and the provider name to which your mobile is locked then they send you the codes to unlock your mobile.
Nov 15, 2011 | Motorola Mobility C975 Cellular Phone
Y my motrola c975 the battery is emptied quickly ??besfriendship_gold@yh
Did you charge the phone for the full 16-20 hr first time? If you didn't do this then the battery will degrade faster than normal.
I suggest you replace the battery.
If you have anymore questions please feel free to ask, Rich.
Jan 20, 2011 | Motorola Mobility C975 Cellular Phone
Where to download motorola C975 usb data drivers
Motorola C975 Motorola C975 USB Driver is used for connecting... Windows 2000 / Windows XP / arsim.gifDownload
please mark this as fixya
Dec 21, 2009 | Motorola Mobility C975 Cellular Phone
Charging problem
I think the charging port is bad and this could be as a result of factory error since the fault is not from you. The phone restarts probably because the charging ports is bridging.
I will advice that you purchase a desktop charger that will enable you charge the battery seperately and when the battery gets full, you insert it into the phone. You could get another battery so that while you charge one, you use the other.
Or if you can look for a repairer, that will help you fix the fault of your phone.
Best wishes
Nov 16, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
New phone won't turn on just has "Hellomoto" screen
hi.there...don't worry.. what happens with your new cellphone..is normal..why? when your battery is low and there a pop up screen at the display "battery low...please recharge" that's mean you must charge the battery soon.
when connect your phone to charger adapter and your battery is very low / weak condition the display only showing "hellomotto" and nothing else. but it's normal! diplay need more power from you battery to showing all information.after the battery reach the minimum power to display it ( usually after 15-20' charging) try to push red bottom at your keypad phone and the display will showing again..good luck..
Feb 02, 2009 | Motorola Mobility RAZR V3
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Motorola Mobility C975 Cellular Phone Logo
95 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
