Question about Zenith C27V36 27" TV
Zenith 27" HDTV second antenna input not accessible on TV/remote
The flatscreen C27V36 27" TV from Zenith has, among other inputs, 2 antenna/cable inputs, as many TVs do. Problem is, there's no visible way to switch between these two inputs on the front panel below the screen or on the remote control. I would like to have my cable service going in antenna1 and a digital antenna on antenna2, but as it stands I have to manually switch one out for the other on antenna1 (2 doesn't even work when 1 is unplugged). When I do channel scans I first pick up channels on antenna1 and then also on antenna2, but still, there's no way to actually access 2 that I can find.
Has anyone ever had a similar issue with any TV?
  • 3 more comments
  • Darren Frye Feb 11, 2009
    It does have PIP, but that functions fine with just the integrated analog tuner. I do have a converter box though, which I am attempting to put between the antenna2 stem and the antenna. I'm really not even sure this can be done anymore.
    So the PIP apparently only uses one tuner...still haven't figured this out but it's just a matter of time...
    testing
    How do I make a post that's not a comment?
    Benimur if you're reading this, I meant to post what I said in the first comment below the original problem above...thanks for the input by the way.
    Hello
    The converter box output is indeed coaxial. Still, when scanning the TV for channels (with the converter box already scanned/tuned), it just picks up ch 3 for the selected antenna input.
    You know I just thought of why my little imagined configuration might not be possible in the first place: The only remote I have that can control PIP (the original remote) can't control the converter box, which would be necessary since I can't scan for converter box channels through the TV as mentioned earlier. Or maybe I'm just going nuts...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Pls verify if your particular model/versions has a PIP feature. To my understanding, the 2nd Antenna/Cable IN goes to a 2nd tuner that is primarily used for the PIP (picture in picture) mode. This mode would allow you to watch simultaneously 2 different TV channels.
Pls post back. Good luck and thank you for using FixYa.
Posted on Feb 10, 2009
  • Louie  Role
    Louie Role Feb 11, 2009
    Hi again,
    Comment or post would be the same. If the output of your converter box is RF (not A/V), then it should work on either inputs.
I do not know my converterpin numbers ! I would like to reset to facory condition. I am
Your converter is not connected correctly to your TV. Start with the antenna connected to the antenna input on the rear of the box and the R-W-Y outputs of the box connected to the R-W-Y inputs on the rear of the TV. Use the box remote to turn it on and select "setup". With the box menu displayed on the TV, select channel search to find active digital channels in your area.
May 29, 2017 | Televison & Video
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Jul 15, 2008 | Televison & Video
Can't get the tv to switch from cable to antenna mode using a RadioShack remote or the buttons on tv
It sounds that the front panel controls are locked with your tV. You have to unlock it first, if you want to change its input selections. If you cannot select the inputs by using the remote control [I thing you are using a universal remote control], setup the remote control with an other setup code. All codes to remote control won't work with some functions. You have to search and select, which code give maximum functionality with your TV.
Jul 06, 2012 | Zenith SY2569X TV
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
Converter box question
This set has the ATSC tuner required for the new over-air standard. No converter is needed.
Dan
Mar 04, 2009 | Zenith C27V36 27" TV
Zenith c27v36
The short answer is no. You will not need a converter box. This set contains the ATSC tuner required for the new over-air signals.
Dan
Aug 07, 2008 | Zenith C27V36 27" TV
Mitsubishi WD-62525 Input 480i
it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Concierge by Zenith Input Problems.
I had the same tv at my motel and wanted to hook up my Wii. Turning to Channel 999 worked.
Jan 17, 2008 | Zenith C27A24T 27" TV
How to change from video mode to cable/Antenna Input without a Remote
Alot of Zeniths have menu for that, have you tried to press the channel up button?
May 15, 2007 | Zenith A25A11D 25" TV
Zenith C27V36 27" TV Logo
224 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
