Question about SanDisk 2GB microSD Memory Card
Open a password..
I have 2GBmicrosd sandisk mmorycard when i inserted to card reader it asks password but i forget it help me to open my memory card and my memory card works in the phone..
  • 7 Answers
I think you have a SDHC sd card have a look at the card and see if it says 2gb SDHC if it does then you need a new SD card if it doesnt have SDHC then it will be a fault with your card reader.
Posted on Feb 10, 2009
Memory card unlocked
i want memory card password
Nov 23, 2012 | SanDisk 2GB microSD Memory Card
I have a sandisk 2gb microsd memory card,but i forget its password.so plzzzzzzz help me & tell me how can i know my password or unlock my memory card.
1.Insert card into your phone but don't access it through phone. 2.Run FExplorer and Open the path C:\system. 3.You will find a file called mmcstore ,rename the file mmcstore.txt 4.Copy that file(mmcstore.txt) to your pc and open that file in notepad. 5.You will find your password in that file.
You can find the FExplorer from the internet..
Dec 17, 2010 | SanDisk 2GB microSD Memory Card
I have a San Disk 2gb micro sd memory card in my phone, to open it, it asks for a password, how do i find the password.
its an application in phone asking for authentication entry thats all try inserting the memory card into pc via card reader it will read
Sep 23, 2010 | SanDisk 2GB microSD Memory Card
My micro SD memory card i cant remove my password. i forget password and in that card i have my important document. i dont want to format it. the another problem is i cant connect it by using card reader....
This Is The Card Error. This Can Be Solved By Inserting The Card In a Mobile And Try The Following Steps:-
  • Go to file manager on your mobile,
  • In the "Settings" option,
  • Choose system folders,
  • In the "System" folder there's a file called "MMCSTORE",
  • Send that to your PC using IR/Bluetooth,
  • Then open it in notepad.
  • The password you need for your memory card is in that file
Sep 19, 2010 | SanDisk 2GB microSD Memory Card
Forget password of memory card problem
HI
You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
  • go to the file <memorycard>:/system then find the file "mmc store".and rename the file to "mmcstore.txt" (Hidden file should be made as shown from tools->Folder option->Show hidden files)
  • Now open the file in notepad ,
  • Now you will see the password.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Nov 19, 2009 | Nokia 5800 XpressMusic Smartphone
My phone memory is locked, how do i open it?
Hi, incase u do not require the data in the memory card then simple insert the card into ur computer using a usb card reader and format the whole card the password should get erased along with it and ur card should start working again
Jun 11, 2009 | SanDisk 1GB microSD Memory Card
My computer cannot see my 8gb sd memory stick even though the reader is working it keeps asking to insert a disc
chek the memory card is not insert properly in the card reader , first u properly insert the card into the card reader and then check
Jun 08, 2009 | SanDisk 2GB microSD Memory Card
My memory card1 gb is blocked asks password in nokia 6300
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 26, 2009 | SanDisk 1GB microSD Memory Card
    Unlock memory card
    when the card is inserted in the mobile, go to memory card option and click the option set new password
    Jan 01, 2009 | Nokia 6600
    Help
    Insert the memory card in the nokia phone and change the settings to the memory card without password and then insert the memory card in your motorola phone.. it will fix the issue...
    Otherwise, connect your nokia phone with your computer and transfer all the contents from the memory card to pc and insert it into motorolla, format the card and copy it from your pc... make sure your having pc suite for doing this...
    Sep 10, 2008 | SanDisk 2GB microSD Memory Card
    SanDisk 2GB microSD Memory Card Logo
    169 people viewed this question
    Top SanDisk Electronics - Others Experts
    Piyal Perera
    Piyal Perera
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
