Question about Kyocera FS-9520DN Laser Printer
Replace Toner hi, In dispaly its showing Replace toner. i changed a new original toner kit provided by Kyocera. Its working only two days after that it showing same error.Its produce a sound like tak tak.................
  • ananta Jena
    ananta Jena Oct 05, 2009
    for this problem ichange the bypass drive belt which comes in back side of the printer then its working fine .
    Genius:
  • 2,120 Answers
Remove, shake well and re-install. It may have a broken auger inside the cart.
Posted on Feb 10, 2009
Kyocera taskalfa 1800 is showing add toner on its screen even after another toner has been fixed
While the machine is on, you need to put the old toner back into the machine, close the front cover. Open the front cover and replace it with the new toner. Make sure new toner is shake well.
Mar 01, 2017 | Kyocera Office Equipment & Supplies
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
I had a jam, upon clearing the jam, the printer will hang with the motor turning, and the display saing 'adding toner'. I changed the (new) toner, for a brand new one. Still message will not go away.
Leave the machine working to see the next message of Adding Toner. Usually the next message of "Adding Toner" is "Ready to Copy".
If the next message is "Add Toner", i suggest you to pull the new toner kit out and push it a little bit harder and check again.
If you power the machine off and on again, can you see what the message about toner is, Original or Unknown Toner is installed?
Sep 30, 2014 | Kyocera Office Equipment & Supplies
What do i do if u replace new toner and the message replace toner does go
Check the toner sensor under the processing unit (PU).
Remove the PU and you will see in the front left side, inside the machine, a black sensor (a black part with cross screw on it and a spring underneath it. There is a possibility that sensor to be dirty or damaged.
An important question is... is the toner original or compatible with appropriate chip (toner id)?
May 15, 2014 | Kyocera FS-1118 Printer
My cartridge is full of toner but the printer says it needs to be replaced, how do i reset the cartridge?
You can't. The toner levels are calculated and approximated. Make sure you use genuine Kyocera toner and replace it.
Sep 27, 2013 | Kyocera 1T05JK0US0 Model TK-152K Black...
C6000 after changing the toner kit .. the message dispalyed call for service. .. please help
chek your power 110 or 220
220 ok and 10871087 163 exicutive
restart prblm not slvd??
thn chek fuser lamp nd thermistr fuse
May 22, 2012 | Kyocera Mita KM-2550 All-In-One Laser...
I refilled toner of my Lexmark E120 (since it said it was out of toner) and it worked fine untill few days ago when I got status report: Missing or defective catridge. Could this mean it's out of...
Replace the chip, is a chip cartridge problem.
if not work try this:
31 Defective toner cartridge or missing cartridge
1. Verify that the toner cartridge and PC kit are correctly installed.
2.Wait 10-20 seconds for the printer to verify the units.
3. Replace the toner cartridge or PC kit if necessary.
Aug 01, 2011 | Lexmark E120 Laser Printer
Kyocera FS-C5030N Led Printer My printer ran out of the blue (cyan) toner so I replaced the cartage carefully following are the cleaning steps like I've done successfully before with the other colors....
You need to reset the toner counter. This is done through the Menu button and selecting Life Counters. The instructions on how to do this are found in the Advanced Operators Guide on page 2-75. The link below will take you to the manufacture's website where you can download it.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14192&rid=14764
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
Mar 09, 2011 | Kyocera FS-C5030N Led Printer
I already replace a new toner but there an error msg AP
Hi
The AP message indicates thet the dev is so low in toner that the machine has to go into a full cycle mode to get the toner levels up.
The error code is telling you that one cycle is not enough. you will have to turn the copier off/on and cycle it at least one more time....more if neccessary
Jun 15, 2009 | Kyocera Office Equipment & Supplies
PanaFax UF-780 toner error.
If you mean a 788, there are moveable tabs on the front top of the cartridge that trip switches. Move them around.
Several companies have their own brand names on Panafax's. Their toner won't work. Kyocera must be kyocera Toner, Canon must be Canon toner, etc.
Aug 05, 2008 | Office Equipment & Supplies
Kyocera FS-9520DN Laser Printer Logo
172 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
