Question about Brother DCP 130C All-In-One InkJet Printer
I have had a paper jam
I have cleared the paper jam and unplugged machine etc but still reads error of Printer Unable 30
  • Anonymous Feb 23, 2009
    my printer had a paper jam that i fixed and it continued to say paper jam on the screen. it now says no cartridge or change the cyan cartridge even though there are new cartriges in all of the colours
Open the top lid and pull out the paper from the top
Posted on Feb 17, 2009
My printer is showing an error
our printer brother mfc 5460 is not printing.....even though there's an ink....how can we fix that? pls help....
Dec 27, 2009 | Brother MFC-5460CN All-In-One InkJet...
No Help Any Where For this Problem"Unable to Print 50 or 30 Both"
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 19, 2009 | Brother MultiFunction Center MFC-440CN...
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
My printer had a paper jam and i cleared the paper out but it says unable to print 30
did you try unplugging machine for a few minutes? Maybe it'll go back into it's original start-up mode.
Jan 22, 2009 | Brother Multi-Function Center MFC-240C...
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Error message print unable 50
the encoder strip which gives the printhead the position is out of place (error 50). You have to open the printer and reinsert the strip:
http://www.fixya.com/support/t211210-brother_mfc845cw
Stick a 1.5 inch tape onto the printhead cover where the strip runs thru. This will prevent this accident in future!
Nov 05, 2007 | Brother IntelliFax-2480C Fax
Brother DCP 130C All-In-One InkJet Printer Logo
270 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
