Question about Xerox WorkCentre Pro 416 All-In-One Laser Printer
Unimessage pro driver error
After installing the GDI driver on Windows XP, for Xerox Workcentre pro 416, and try to print anything, I get the following error:
Machine device id can not be recognised, please select device type explicitly. I tried it with several PC-s. Also I tried the drivers of the 416Si version. They install fine, but the printer is not printing anything. No error messages. Please help!
  • karpati_vikt Feb 11, 2009
    This printer is a standard 416, or 416DC, wich has no network connection. I connect to it with a standard parallel port printer cable on LPT1 port. So you think, this is not a driver issue? I will try the nvram resetting, and image control board swap, if possible. Will report if any results! Thank you so far!
    Guru:
  • 110 Answers
Try reseting the nvram. if no luck after that try changing the image control board.. with another one if it's avaliable.(maybe you have another machine around. If not then conect your printer to the network reset the printer so you can get an ip address.. usually it's a 192.168.*.* Then type that ip address 192.168.*.* into the top of your web address bar and you should be able to see you printer. If not i would change the image control board because it might be bad.
Posted on Feb 11, 2009
My workcentre pro 416 is printing all copies as all black.
It sounds to me like the High Voltage Power Supply, Biasing Ground, or Blanking Exposure Lamp may be a fault. You could also have a problem with the Digital Scanner unit. But, there is nothing that you can do yourself: EXCEPT: If the unit takes a Toner Cartridge that includes the drum, I would try replacing that first. Then if no joy, your going to have to call out the big guns. Good Luck!!
Jun 13, 2012 | Xerox WorkCentre Pro 416 All-In-One Laser...
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
Xerox Workcentre Pro 416. There is no driver for Windows 4 64bit.
I would say you need to contact Xerox for the soluton.
Oct 19, 2010 | Computers & Internet
MY xerox work center pro copier 416 works well while photocopying,but i need a driver to operate from my PC
Here is the xeros link to drivers from A-Z.  There is no workcentre pro 416 listed.  Check your model number and scroll down to workcentre.  Good luck.
http://www.support.xerox.com/go/prodAtoZ.asp?Xlang=en_US
Oct 13, 2010 | Computers & Internet
Vista printer driver for a Xerox Workcentre Pro 635
try this....
http://www.xpvistasite.com/workcentre_pro_635_12490.htm
Jan 04, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Sep 08, 2008 | Office Equipment & Supplies
Xerox printer and windows vista
use workcentre pro 265 drivers. worked fine for me and is embedded w/ the vista os.
Mar 27, 2008 | Office Equipment & Supplies
Xerox WorkCentre Pro 416 All-In-One Laser Printer Logo
975 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
