Question about RTO PasLode 900420 Impulse Framing Nailer
Paslode 900420 nailer green light cycles doesn't stop???
Paslode 900420 green light flashes but doesn't spark/fan won't stop until I remove battery. I'm going to open her up soon and see what I can figure but, I was wondering if anyone had seen this one before
T.I.A.
Jevfro
  • 2 more comments
  • Anonymous Feb 12, 2009
    Clarification:
    Thanks for the help rowdy... It starts the fan and green light blinks as soon as battery is inserted. depressing safety and/or trigger does nothing (except I can smell butane building up) it just cycles with fan and lights going for ~ 3 seconds, then stops for a half second, and then repeats until battery is removed. It did this one time previously but it stopped a couple of hours later.
    Again I appreciate your help!
    I'm going to take it apart when I get home tonight.
    Jevfro
  • Jeff Cleveland
    Jeff Cleveland Feb 12, 2009
    sorry I didn't mean to post as guest... I wasn't logged in right. anyway I'll update you as to what I find when I take it apart in a couple hours... Thnx Jevfro
  • Jeff Cleveland
    Jeff Cleveland Feb 18, 2009
    Well, a simple cleaning is all it seemed to need!
    I couldn't really find anything wrong w/ it. This is the first time I've ever opened it up (it's 6+ years old) and I was amazed at how clean it was inside.
    This nailer has been a tank! I used it to help build a 1200sf cabin in Idaho. It will occasionally not fire but it's usually just the safety not being fully depressed.
    Thanks for the tips rowdy!
  • David Ford
    David Ford May 11, 2010
    By not spark I guess you mean fire? There could be a couple items that are causing your problem. When you press on the safety does the fan come on, if so does it go out after a short time, when you depress the trigger does it do like above? If not you could have something not releasing against the triggers or the circuit assembly is bad or even worse for money the spark unit. When you decide to take apart let me know and I will try and help further with trouble shooting
    New Friend:
  • 131 Answers
Sounds like you need a new circut assembly.
Around 40 bucks.
Thanks,
Jeff
Posted on Jun 23, 2009
My paslode cordless framing nailer won't shoot? It has a loose o ring at the top
The most common issue is bad fuel. It doesn't matter if you just bought it, many stores don't rotate their stock - check the date stamped on the bottom of the cylinder.
The cylinder o-ring is generally loose fitting and the spark plug is very seldom an issue.
Is the green light on the handle flashing when you install the battery?
Does the fan run when you depress the nose?
Those answers will help narrow down your problem.
Sep 18, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun ,fan won't shut off
replace circuit mold assembly or spark unit its probably the spark unit
Jul 08, 2012 | RTO PasLode 900420 Impulse Framing Nailer
I have a 900420 gas paslode nail gun .When I push the gun down it is dead ,the battery is charged and it has gas
You need to remove the combustion chamber assembly and check for spark, remove 4 screws from filter cover and 2 screws from nose mount then carefully slide the assembly off, fit a good battery and press down on the roller arm below the fan, the fan should run, operate the trigger while the fan is running and you should get a spark, if not you will have an electrical fault, if you get spark bend the roller up slightly and see if that solves your problem
Sep 22, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Gun was jamming up so i cleaned it now green light flashes but if i disconect wire put battery in then plug wires back in fan runs then stops and green light flashes again what could it be
the green light flashing means the tool is ready to fire. when the trigger switch is depressed or the safety activated the fan will run for a short time and automatically shut off. if the tool is not firing then it could be a loose connection of the circuit board or the spark unit. Let me know what the exact problem is and I will try and help further. Also check the expiration date on the bottom of the fuel cell.
Apr 16, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 900420 nailer fan keeps running. Nails drive fine but I have to release the battery to stop the fan.
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
May 10, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 1st fix gun .battery fully charged and placed into gun.the light flashes green and the gun will fire once after which the light flashes red and the gun will not fire.any ideas.i have tryed other...
I would look at the fuel cell on the bottom is a expiration date and they will not fire older fuel. Also do you remove the battery and it does the same thing? When you depress the safety on the work can you hear the fan motor? You say the tool is clean does it have enough lube to move all items freely. Just a couple thoughts, Also look at the spark plug wire for being broke or coming out of the spark unit. Let me know and we will go into this deeper.
Jun 30, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framing nailer 1998 yr. model when engaged wont fire
you have spark and cleaned tool correct, but fan won't turn that freely, if so the fan motor is bad, it should come on when you pull the trigger or move the roller lever for the safety. The fan is about 80.00 Let me know if I missed something and how did you check the spark?
Jun 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
1,040 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
