Normal
0
Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth
Devices window. Insure batteries are installed.
Press the Connect Button on the Keyboard
(Usually located on the under side of your keyboard) this allows Windows to see
the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To
Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device
Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and
click Next.
Windows will generate and display a Passkey. Type the Passkey specified on the Bluetooth
Keyboard
(Do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if
you make a mistake, you can backspace key. You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds,
click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected
to the computer. Finish and follow any on screen instructions.
Hope this helps.Bud
unable to connect to internet even with installed profiles. only wap. unable to connect to already...
(More)
unable to connect to internet even with installed profiles. only wap. unable to connect to already installed pc lg suite. jus had touch screen n main screen replaced it jus not doing anything other than send sms n mms.. cant connect google , short cut dont wrk says ïnvalid access". or un supported profile type even tho virgin have sent thru all apps
unabl to bluetooth connect without passcode. where would I find it or change it. I have tried my sim...
(More)
unabl to bluetooth connect without passcode. where would I find it or change it. I have tried my sim passcode but not accepting it
