Question about Sanyo Projector Lamp for PLC-XU100, PLC-XU110
Sanyo plc-xp46 lcd projector
How to reset lamp replace indicator after replace bulb
how to reset lamp hours after replaceing New lamp
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Posted on Aug 03, 2010
I have a Sanyo PLC XE20 which powers down after a few seconds with a bulb error I purchased a new bulb but the problem persists. What next?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Sep 08, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
My sanyo PLC-sw20a lamp does not light after turning on, the red lamp indicator still lighted and there is no indication for lamp replacement. Is the lamp busted?
have a nice day!
May 20, 2011 | Sanyo PLC-SW20A Lamp
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
I need reset counter lamp projector sanyo model: plc-xu300
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
have a nice day!
Feb 15, 2011 | Sanyo PLCXU300 Projector Lamp
Sanyo PLC-XU33 multimedia projector. Starts up, goes through countdown, stays on for a minuit after that, then bulb goes out and it goes into shutdown?????? Rob,
hi,
check the video inputs. if there is no video input then the projector will goes off after count down.
also check that is the lamp replace light lights up or not. if its lights then you have to change the lamp and then reset the lamp hour.
ok
Jan 19, 2011 | Sanyo PLC XU33 Multimedia Projector
After lamp replacing on Sanyo PLC-XP46 the projector starts up and immediately shuts down. Lamp counter was reset.
Check the iris door, it opens and closes freely. If dust has clogged it up, it will not stay on. Also check the air filter and the fan, if they are dirty, it will shut down as well. If your manual does not show any diagrams of the unit, post a comment and I will look it up. Hope this helps.
Jan 11, 2011 | Sanyo PLC XP46 Multimedia Projector
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
Lost the manual - I am replacing the bulb
remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on.
Aug 04, 2008 | Office Equipment & Supplies
Sanyo plc se15 no light output
i all,hoping you can help with my problem.Ihave been given a sanyo plc se15 projectoe but with no lamp originally,the "lamp"indicator and "lamp replace indicator"were originally lit but when i have installed a new(23hrs use previously) lamp i have no light output and these 2 indicators are still lit! what voltage should i have on the lamp terminals(i a fully qualified electrician btw) is there some sort of reset procedure as i dont have any instructions etc
thanks in advance for any help
Mar 05, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo  Projector Lamp for PLC-XU100, PLC-XU110 Logo
520 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
