Question about HP LaserJet 3600n Printer
PAPER JAM COLOR LASERJET 3600N
SAYS THE PAPERS IS JAMED RED LIGHT ON BUT AS SOON AS YOU OPEN AND SHUT THE PAPER TRAY IT WORKS RED LIGHT NOW OFF THIS HAPPENS ALL THE TIME MIGHT LAST 2-3 SHEETS THEM IT HAPPENS AGAIN.
  • wilsonandy77 Feb 10, 2009
    hhdhdfjd
  • Anonymous Mar 02, 2009
    I have the same problem I don't much like this printer.
Let
Posted on Feb 10, 2009
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
Aug 21, 2014 | HP Color LaserJet 1600
My HP Color Laserjet 3600n had a paper jam. The
Your best method of troubleshooting is the manual sensor test as this is a generic paper jam error.
on your sensor tests:
0 = off
1 = on
A = TOP OF PAGE SENSOR
B = PAPER LOOP SENSOR
C = N/A
D = FUSER PAPER SENSOR
E = DELIVERY-TRAY PAPER-FULL SENSOR
F = FUSER PRESSURE-RELEASE SENSOR
G = MEDIA SENSOR
H = N/A
I = MP TRAY SENSOR
J = CASSETTE SENSOR
K = DOOR OPEN DETECTION SWITCH
L = DEVELOPING ESTRANGEMENT SENSOR - CLR
M = DEVELOPING ESTRANGEMENT SENSOR - BLK
N = MP TRAY MEDIA POSITION SENSOR
A-F are paper path sensors - you can toggle them and watch if they change from 0 to 1. If they do, the problem is not in that area.
G can have states from 0-7 each one representing a different type of paper - shouldn't have anything to do with jamming.
hope this helps. probably a tiny piece of paper or toner somewhere. could also be a torsion spring out of position on a flag.
May 10, 2010 | HP Color LaserJet 3500 Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
The paper jamed now I get a 41.3 error message and can't solve
The error 41.3 is unexpected paper length and was caused by the printer pulling more than one sheet. Now the problem is clearing the paper jam in the paper tray. The only way I have found to get it clear is to put the printer on its back with the paper tray facing straight up. Now push the tray in just a little bit if you can and try to shake it to get the paper to shift to the other end. After a minute or two put the printer back down and try to open the tray. If you can then just put the paper back where it goes in the tray. Be sure the pickup roller is clean, no paper dust and such. then try printing again. If you still can't get the tray out then you will have to dis-assembly the printer to get it clearer. Let me know if this gets you going.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 19, 2009 | HP LaserJet 4 plus Printer
Jam in top cover area
Replace your paper pickups and set your paper tray setting correct, both in the tray and the settings menu. That should help you out. The part# for paper-pickups is RF5-3739.
Mar 17, 2009 | HP LaserJet 4600dn Color Printer
Paper jam in tray
Chances are the paper is getting torn as you remove the tray. I suspect you need to replace you feed rollers.
Feb 20, 2009 | HP LaserJet 4600dn Color Printer
Paper Jam in HP2600n printer
Very difficult to disassemble. You should call a HP Service Center.
Jan 22, 2009 | HP Color LaserJet 2600n Printer
Stuck on "initilizing"
There are 3 things that will prevent it from going "ready"; they are
1. a paper jam (did you retrieve all of the page out of the printer?), all it take is a small piece of paper in the wrong spot and that will do it.
2. No paper in the paper tray.
3. The ink or toner cartridge is not seated properly or just plain missing. A color laserjet has 4 cartridges.
Good Luck!!!
Dec 02, 2008 | HP Color LaserJet 2600n Printer
Paper
then you have some buried deep inside..turn light off in office, close door, and use a flashlight or penlight..paper will glow from light..that will help a bit..then long tweezers to extract the fragments, eh?
http://tinyurl.com/6qcpgy
Aug 15, 2008 | Brother HL-2040 Laser Printer
HP LaserJet 3600n Printer Logo
200 people viewed this question
Ben Johnson
