Question about StarTech.com (ATXPOW300PRO) 300-Watt Power Supply
Power Suply Replacement
Where can i find the correct replacement of a Power Supply to my PC: an IX PACCO (all integrated) 2,4GHz.
In the site maybe there isn't more units, unless i search in the
web introducing the serial number of the original Poer Supply.
Maybe i have to search more or better, but, could you help directly in
this case?
I will thanks all your guide.
Siceresly,
Lic. Claudio Massiani computor wont power on
  • 31 Answers
Backlight replacement on element eleft502
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 18, 2016 | Element Televison & Video
Ix pacco 2.4
I don't think so. If you need to reset it just open your system and see the CMOS clear jumper just beside the HDD port there should be three pin just change the jumper If jumper is seted into 1-2 then you put it 2-3 now system start by default It will go into CMOS then go to advance setup set the boot prority as first boot device HDD0 and pree F10 to save it.
Aug 18, 2012 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
PC won't start up
Check for power on the A/C outlet. Maybe the circuit breakers were tripped. If there is power, then the power supply installed on the computer might be surged. Replace power supply if thats the case. Normally, there's a button that says 'power' or an image of a lightbulb... you need not use the remote.
Mar 16, 2009 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
Any good computer supply company should handle power supplies. The important thing is to get one rated for the same power. (300W, 350W, 400W, etc.) You can always go higher, but not lower.
Oct 18, 2008 | Computers & Internet
Pacco group ix my ciu p4 2.66ghz 15" tft
try ebay I find a lot of hard to get parts some new some used there
Power Suply Cord
If the cord is the ONLY item you need and NOT the terminal block in the dryer, then Home Depot sells replacement cords with a molded plug attached as well as ring lugs on the opposite end for terminating them on the dryer block. You'll need to know if you are using a 3-prong or 4- prong set up in order to get the correct cord. Hope this helps..
Sep 06, 2008 | Whirlpool LER3624JQ Electric Dryer
IX PACIUP4240-l----power suply .....help me plssssss!!!
just go to computer shop ask ATX power supply for u r computer configuration or else remove the old power supply from the cabinet and take it to computer shop and show him the old one then he will provide the similar capacity Power supply
Aug 05, 2008 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
hello i got the same problem like u,but the thing is i call some1 2 check my p.c and he took my power supply and never give back 2 me,can u let me know that serial # or any info about the power supply....thanks or if u bought 1 4 u...........
Jul 10, 2008 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
Graphics
Graphic card output connections cannot be shared on two different cards. You will need to install the PCI card then find a way of connecting your screen cable to it depending on type of PC case and motherboard orientation.
Feb 17, 2008 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
StarTech.com (ATXPOW300PRO) 300-Watt Power Supply Logo
55 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
