Question about Canon PIXMA iP1600 Printer
I must have droppped my cannon pixma iP1600
The thin belt behind the ink cartrages has come detached. I see one wheel to the left but do not know how to reattach it. Any answer would be helpful. Thank you.
  • 31 Answers
To replace the belt, you need to remove the top cover from the printer. Open the ink cover and remove three Phillips head screws. Then turn the printer upside down. The cover is held on by six plastic clips. Canon has helpfully marked these with small arrows. Starting at the front, lever the cover off carefully, taking care because the plastic is very soft. Then release the clips at the rear. The cover can then be removed.
The toothed belt is driven by a wheel at the left hand side. There is a lip on the wheel so you will have to loosen the assembly to replace the belt. Make sure there are no twists in the belt and feed it over the tensioning wheel at the right hand side. Make sure the cartridge carrier moves smoothly. You might like to clean up any dried ink.
Reassembly is the reverse of disassembly. Replace the three screws and you are ready to test.
If the belt keeps coming off, it has probably stretched and will need to be replaced.
Posted on Jun 04, 2016
I want software
Posted on Feb 12, 2009
Loading ink cartridges
what are the numbers mentioned over the cartridges.
Jul 03, 2008 | Canon PIXMA iP1600 Printer
Cannon Pixma IP1600 is full and will not print, how do I fix it
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Feb 26, 2010 | Canon PIXMA iP1600 Printer
HOW TO INSTALL PRINT HEAD ON iP1000 PIXMA CANNON
With the Canon printer, you just have to open the top cover and remove the inks, after that you lift the lever on the left side of the carriage. Tip the top of the printhead toward you and lift out. To replace you keep the lever up, insert the bottom first and then lay the top back and lower the lever. Install inks and you're good to go.
Jan 25, 2010 | Canon PIXMA iP1600 Printer
How to refil Cannon LBP2900 cartridge
you do not have to take the whole printer to the shop to fill the ink cartrage if you have the manuel to the printer it should tell you how to remove the ink cartrage and replace it with a new one and also they may have a refill kit at one of your local computer stores or where they sell ink and they should be able to tell you how to get the ink cartrage out to replace it
Sep 02, 2009 | Canon LASER SHOT LBP-2900 Printer
I'm having problems installing the new ink cartridge on my printe
Please download complete driver from following link and install properly. Make sure before installation of printer driver printer should be disconnected.
http://support-asia.canon-asia.com/contents/ASIA/EN/0900400901.html
Thank you
Sachidanand
Aug 17, 2009 | Canon PIXMA iP1600 Printer
My printer says that it is out of ink on the color side
hi all,
The printer shows message No Ink means ink has run out. Even you refill the cartridge this message stay remain. Check here to find out more.
regards
Nov 19, 2008 | Canon PIXMA iP1600 Printer
HOW TO LOAD MY 1600 CANNON PIXMA PRINTER
http://www.driverfiles.net/Printers/Canon/PIXMA-iP1600/download/page,sh,39298,430,12,.html might help
Mar 04, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
66 people viewed this question
old marine
old marine
