File missing Hello sir am sandhu from bangalore, my problem is that when i boot my pc , in the start it shows the error message , SSVICHOSST.EXE file missing. pls help me to solve this problem.
    Genius:
  • 3,422 Answers
HI,
1. START> RUN > type CMD > now paste the following reg add
“HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon” /v Shell /t REG_SZ /d Explorer.exe
this procedure is to remove the error that comes whenever you restart windows
something like “could not find SSVICHOSST” or “error loading SSVICHOSST” or “windows cannot find ssvichost”
Posted on Feb 10, 2009
Will not boot, error message
Hello
Im sorry to hear about your luck. Basically this error message is letting you know that one of your important windows system files is corrupt or missing.
Problem is every solution requires you to use a cd. Does the PC have USB drives ?
Oct 18, 2009 | Computers & Internet
It keeps saying that ntoskrn1.exe is missing
It is pretty much crashed....hard. Might want to reload the OS. Yes you can recover from that, but it is not worth the time and frustration to do it...Provided you can afford to lose whatever you had on the primary partition (C:\) drive. Let me know if you need other asst. It is a little complicated to explain. How many machines is this affecting? All of your E-Machines?
Aug 13, 2009 | Computers & Internet
Booting time its showing Error messagr internal key board error plz tell me wat is the problem....and where is the service center in bangalore.
it may be happen due to some system file is missing used for boot by system it may be solved by re installed the operating system.
by the way below the address u needed.......
IBM Service Centre in Bangalore:
IBM India Private Limited
Lavanya/Priya/Sudhir
Subramanya Arcade, Ground Floor
12, Bannerghatta Road
Bangalore - 29
Phone : (080)41953043, 3035, 3032
E-mail : tphlpbng@in.ibm.com
Mar 05, 2009 | IBM ThinkPad X41 Tablet PC
Windows cannot find "ssvichosst .exe" file at start up
please mate if u have not find ssvihost.exe file please reinstall xp using updrade or using boot u can fix xp all...
Feb 24, 2009 | Microsoft Windows XP Professional With...
I Have lenovo leptop which infected with ssvichosst.exe I would like to know what is this ssvichosst? & How I can remove this ?
GO TO DOS PROMPT AND DEL THIS FILE e.g goto start-->run-->cmd than press ok than you will be at c:\documents and setting\ so type c:\documents and setting\cd\ and enter than goto system32 directory by c:\cd windows\system32 and than run the following commands
c:\windows\system32\attrib -s -h -a ssvichosst.exe and than run c:\windows\system32\del ssvichosst.exe this will remove this virus file.
Dec 12, 2008 | Computers & Internet
Ssvichosst.exe
Cannot find regsvr.exe
Download and run this:
http://piyushlabs.googlepages.com/Heal_regsvr1.0.zip
BTW...it's a virus you have. It will get worse if you don't clean it or restore your computer.
Oct 24, 2008 | Microsoft Windows XP Professional
How do I...
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Miscellaneous corruption
Corrupt boot.ini file.
Missing boot.ini file.
Missing or corrupt ntoskrnl.exe file.
Windows NT installed on a partition bigger then 7.8GB
Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
Erro message
hi it is some problem .exe file. you setup regd recovery
download it download.com
or setup c drive xp boot cd to recovery .exe file.
go to run command type sfc then enter. setup
Feb 17, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
