Question about Epson Stylus Photo 785EPX InkJet Printer
Printer rollers came off in paper jam and i cant get them back on
The little white plastic. pieces with the roller bars came off, they have a little spring wire that goes up the middle and i cant get them back on with that wire in?
  • Anonymous Mar 12, 2014
    paper jam and the plastic roller fell off
After a week of frustration trying to get the blasted thing back in--I could get the roller piece back in but not with the wire and could get the wire back on the little knob that holds it but that would prevent the roller piece from going in, I cut a notch in the white plastic above the spring hole so that I could, with very small needle nose pliers, hold the straight part of the sprint up while I put the roller piece in place. I then let the spring down through the notch I cut. It took a couple of tries but it all was pretty easy once the notch was cut.
Posted on May 31, 2009
Problem with paper feed. frequent message: carriage jam, open top. No apparent jams, cleaned rollers, slider bar, etc, problem persists
Turn off the printer
Open the Rear Access Door,
Clean the rollers ( upwards ) with a lint free cloth ( little damped in water )
Close the Door
Open the Front access door, Check if there are any paper pieces stuck,
Remove the cartridges out and Install back.
Close the Door and turn on the printer.
It should work.
Regards,
Ron
Feb 22, 2011 | HP PSC 1610 All-In-One InkJet Printer
HP 2420n printer
When you put paper, does it recognize that paper is inserted?
Mar 19, 2008 | HP LaserJet 2420n Printer
Says paper jam no paper in machine
HI,I had the same problem today. I ended up taking a piece of paper and from the back side started lightly forcing the paper in the back slot. I had the top cover open where you replace the ink cartridges. Towards the back you can see the paper start coming into the printer next to some rollers. On mine there was a small black switch about an inch from the right in the middle of the plastic piece above the rollers. Once I started pushing this paper in I could see this switch was stuck in the down position. After several minutes of pushing the paper in and out the switch moved up and out of the paper path. I then pulled out the paper and hit the ok button and it came on line. This may work better with a piece of card stock.
That switch is the issue. I ended up finding an object lodged against the switch. Needed a flashlight, plastic giftcard and a tweezers to get it out. Works great now.
Also,open the printer where the paper for printing is put in.
At the back left hand side there is a white long piece and either side a white piece with a small square on it.
Use a longingish screwdriver and push this gently down. It will click back into place quite easily.
Note: this tops the paper from feeding in and needs reseting after a jam.You will know all is OK when a sheet of ordinary paper is put in > touches the feed roller above the white bits, and is level across the paper feed area.
Hope it helps,,
Thanks for using fixya.....
Nov 22, 2010 | Canon PIXMA MX310 All-In-One Printer
HP 7580 Paper Jam made piece pop up in the way of carriage
Two choices; 1. Take the machine apart and take the roller out and then bend back the little follower.
2. Break the offending follower off and hope the paper still feeds through OK.
Apr 28, 2017 | HP Officejet Pro L7580 All-In-One InkJet...
DELL 1710- PAPER JAM AFTER EXITING PAPER BIN!
Preface; I am a support tech for a major gov't facility and we have hundreds of the Dell printers and PC's.
2 possible solutions. I have seen both. Items can get stuck in the paper path in the guide area, this is just before the pressure roller plate, this is the plastic piece under the fuser roller assy. The rounded plastic piece that guides the paper from the tray into the print area can have paper scraps or objects such as rubber bands, staples or paper clips caught inside of it. This can happen if any of these things get in the paper tray. I just pulled a rubber band out of one of these today.
Many times it is the paper sensor that is located under the pressure roller plate. After you remove the fuser asy you can see a plastic 'finger' that is just right of center in the pressure roller. There is another one a little further in and it is more center line on the 'floor' of the printer.
I have seen these go out with fair regularity. If you remove the paper tray and turn the printer on its side you can find the body of this sensor under the feed roller/arm asy that drops down into the tray to start the feed process. It has some white, plastice type material and wires running out of it. It is held in by a single screw. There is another sensor of the same design located by the pivot point for the feed arm. If the paper gets by the first sensor then stops, it is the second sensor that is out.
Oct 21, 2008 | Dell 1710 Laser Printer
Epson aculaser cx11nf MP E paper jam
open the mp tray
locate 2 white plastic egg shaped piece on the ends of the steel rod
gently push one or the other towards the back of the machine
if the paper jam error message is on then the roller will turn as soon as you give it a push
re load the paper
open and close door a or e
printing should resume
that white piece works with the paper lift to get the paper up to the in feed roller
Sep 01, 2008 | Epson ACULASER CX11NF All-In-One Printer
MP470, Paper jam on one side
There is something jammed in there....shake it upside down first.....if nothing then revese feed a paper through it manually......take left side off hold paper in front and roll wheel on the left side so the paper feeds back into the machine,,,,,,open top to see in there and when paper feeds under white rollers make sure it dosent jam where wite rollers are about an inch from the right there is a small rectangle hole with a black plastic piece in there pry it up carfullywith a paper clip and feed paper with the wheel under it at that point the paper push out a bobby pin into my back tray,,,,, now everything works great.......keep checking i didn't believe something was there either but there was..... also if your paper first starts to feed and stops pull out the paper and check for a bend or crinp in it mine kept doing that and that is exactly where the pin finally came out.....
Feb 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Cat jumped on top of printer and 2 pieces popped out
Hi there you will have to remove the top cover and you will be able to see where it goes as the roller in question is the paper eject roller. there are usually four screws under the top cover and also at the rear of the machine. The picture where the roller is resting on the top of the printer the roller is situated right under that also that white bushing holds the roller in at one end usually the left as you look at the machine from the front.
Thanks J
Jan 20, 2008 | Brother HL 5250DN Laser Printer
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Epson Stylus Photo 785EPX InkJet Printer Logo
87 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
