Question about Yamaha Full-Size Keyboard
Yamaha PSR 510 -- one of the white keys broke out. Need HELP!
I dropped my PSR 510 YAMAHA (I know i know I'm sorry) andone of the white keys broke from its base and the two hooks that are part of the key broke. I could only recover one of the pieces. I glued it neatly with Plastic Surgery (like crazy glue) and sended it down after it cured for 2 days. But still extremely sticky. NEED to know how to remove the keys completely. I unscrewed the area that holds the keys but still did not even get loose. Any HELP?!
I figured it out. Once the whole 61-key section is unscrewed (I believe its just one screw at the end and it simply lifts off) you have to take a flat head screwdriver and stick it in the top edge of the key rows and twist to force the little tabs out of the slots. Be careful because this is not easy and some of the little tabs might break off - it may not be crucial for the keys to snap back in, though. The first few black keys and the tab above are all one solid piece of plastic. All of the keys are grouped in groups of 3-5 or so as one piece. White keys are layered under the black keys so you must release black key groups to access the white key groups. Once you have forced a key group lose from its snap attachment you must also free the keys from underneath to fully lift the keys off the unit. You have to BREAK the hook shapes found on the underside of the keys (they rest up against the orange rubber lining.) Take wire cutters and snap off all the tips in the key group you wish to remove. Depress a key and watch the movement underneath if you have trouble seeing what I'm talking about - you will see the hooks - think of it as the bottom of the key because that is what it is. The piece you break off should be very small - just enough to remove the hook shape enabling you to lift the keys right out. This will not cause the keyboard to be unusable. It will only make it possible to bend the key up once everything is reassembled. It is the only way I see to free the keys and gain access to the action underneath. As for that...
The action underneath is made up of a pair of rubber cups that when pushed make contact with metal sensors. These rubber cups can tear causing them to fail to pop back up to rest position. I am trying crazy glue to see if this will repair the tear. If not then I will try double-sided tape so that the plastic key will pull the rubber cup back up with it (I hope) when released. Good luck. It is a great keyboard. Very sad to see it discontinued.
This is regarding the Yamaha PSR-510.
Posted on Sep 25, 2009
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
I would like to know which transformer I can use with the Yamaha PSR 260? How many AMP's? Volts I know are 10-12.
You should be using the Yamaha PA-3B adapter. The unit draws 9 watts... so at 10 volts a 1 amp adapter would be great. Make sure the polarity is correct.
Sep 07, 2011 | Yamaha PSR-295MS Portable 61-Key...
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Yamaha PSR-79 keyboard fried fuse
i have the same problem please someone help us.
Sep 10, 2009 | Yamaha Portable Keyboard with 61...
Yamaha PSR-510 Keyboard
There is no need for a manual. It is so easy to operate because it is designed for easy opeating. If you need a manual to operate the PSR-510 then you really won't be able to operate it even after studying the manual. But here it is just in case you can by some miracle!
http://www2.yamaha.co.jp/manual/pdf/emi/english/port/PSR510E.pdf
Aug 31, 2008 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
940 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
