Question about Sony Playstation 3 (PS3) Console
Ps3 does not read any of my games
PLEASE help....
My ps3 does not read any of my dise
Posted on Jul 20, 2009
    Genius:
  • 3,422 Answers
See if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.see if the player tries to read the disc. Load a disc and listen.
Posted on Feb 10, 2009
4 Suggested Answers
SOURCE: ps3 read errors
gtgggg
Posted on Feb 16, 2008
SOURCE: PS3 having trouble reading game discs!!!
hey guys. the problem is that the blue ray reader is some how broken and it won't work. mine kept freezing during games like after 3 mins. and it wouldnt read any more discs for that day. you need to change the blue ray reader and that costs about 175$. thats alot of money and its probably not worth it.
Posted on Apr 15, 2008
  • 4 Answers
SOURCE: my ps3 is reading ps2 games but not ps3 games
Hey man i found a solution to this problem i fixed my ps3 over nite, and i would like to help out, i have the 80gb and after days of research i realized that the problem is in your hard drive, its corrupted whether it gives you the error or not, at first i DIDNT think this was the problem since it never gave me an error but when i went to the reset screen (or how ever is called) by holding the power key down till it beeped three times and went to option RESTORE FILE SYSTEM and after that it said the system files were corrupted and would be restored and fixed but after doing so no matter how many times i chose that option it would always say files were corrupted. dont SEND IT BACK TO SONY, dont GET ANOTHER ONE, dont GET PISSED AND THROW IT AT YOUR MOM OR ANY MEMBER OF UR FAMILY ITS NOT THEIR FAULT LOL =]......HERE'S HOW TO FIX PROBLEM WITH YOUR PS3 THAT STOPPED READING blu RAY AND PS3 GAMES BUT WILL READ YOUR PS1 AND PS2 GAMES AS WELL AS REGULAR DVD DICS AND MUSIC DISC......GOOD LUCK HOPE IT HELPS YOU..........................................WARNING!!!!!! THIS WILL ERASE EVERYTHING FROM UR hdd SO DO A BACK UP OF UR GAME SAVES MOVIES MUSIC OR watever U GOT IN IT THAT IS PRECIOUS TO YOU cuz THIS WILL DELETE EVERYTHING FROM IT, dont SAY I DIDNT WARNED YOU, YOU NAGGERS LOL
THIS FIX WILL TAKE UP TO 6 HOURS DEPENDING ON YOUR LAPTOP AND PS3, MAYBE LONGER BUT LETS HOPE NOT.........HERE IT IS,
THINGS YOU NEED: laptop and recovery system disc(s) for your laptop
STEP 1: take out any disc if any from your 80gb ps3 and properly turn it off.
2: turn power switch off from the back and turn it back on.
3: go to the restore screen....this is how, now this is important, press and keep pressing power button( or key, how ever u WANA call it) on ps3 to turn it on but hold it and wait for 3 beeps till it turns off. now your ps3 will not know u WANA go to the restore screen the first time you try this so do the same step again and it will beep once then it will beep twice repeatedly and bang!! your on the reset screen LOL
4: now take your usb cable and do as the screen says, plug ur controller in and press the ps button on the controller and it will then give you 6 options to choose from, YOU WANA GO TO 3 "RESTORE FILE SYSTEM" but hold on there, dont click yes yet.
5: open the hdd(hard drive) thingy on from your ps3 and take off the blue screw that holds it but dont take the hdd out yet.
6: THIS ONE IS IMPORTANT!......you will select yes when it asks if you really want to proceed to restoring file system and after ur tv flickers and pops up the screen saying the files are corrupted and will be fixed and restored pay attention cuz you need to take your hdd out as soon as it begins to do the restore, YOU WANA TAKE OUT UR hdd WHEN THE PROCESS BAR IS ON 0% NOT 1% NOR 2% BUT 0% ZEEEEROOOOOOOO PERCENT(now leave your hdd on a safe place rit now where nothing will happen to it) if YOURE not quick enough your WOUNT catch the bar at 0% it but thats cool cuz you can try again just repeat the first steps.
7:ok now you need patience here, your ps3 will need to stay on for a long time showing the process bar on zero percent and eventually it will pop up another message saying that there was a problem restoring the system files and that you will need to format the hdd but trust me it will take a looooooong time till u get this message, i left it on over nite so idk how long exactly it took but hey idk, maybe it only takes second for u who knows????.....??? ?? ? WHILE YOU WAIT TO GET THIS MESSAGE YOU NEED TO FULLY FORMAT YOUR hdd USING UR LAPTOP OR SOMEONES LAPTOP, IT IS IMPORTANT cuz OTHER WHISE YOU WOUNT BE ABLE TO FULLY FORMAT YOUR PS3 hdd, WELL THE POINT IS, YOU NEED TO DO A FULL AND COMPLETE FORMAT TO IT, USING A COMPUTER, LAPTOP OR NON LAPTOP AS LONG AS YOU CAN ACHIEVE THIS YOURE GOOD TO GO, NOW THIS IS HOW I DID THIS....and dont think, oh well i could just do that using my ps3, trust me, i did that a million times and none of those times worked, i just wasted my time like an idiot =[
8: TURN OFF LAPTOP, now take the hdd out from ur laptop and connect your ps3's hdd on it......(you may need to take the outter metal cover form the hhd to be able to plug it in to the laptop), this is where you need your laptops recovery disc that came with it when u purchased it and if you dont have one then get one or else YOURE fucked =] .........ok now turn the laptop on and as soon as its turning on, go to the boot menu on your laptop on the first screen it gives you, in my case i had to press the F12 key, could be different for you....now when the other screen wit the boot from options pops up, put ur recovery disc in and when ur done choose to boot computer from disc drive meaning from your recovery disc.
9: ok well now you need to choose to "FULLY FORMAT" your hdd just go for the option or options that seem to take the longest time, if u get an option to fully format and delete all sectors and partitions from the hdd then go for that.....thats the message i got i think or something like that. the process will take up to 5 HOURS remember i said you needed patience, make sure your laptop is plugged in to its charger, you dont want it to turn off while it is doing the format. now go watch tv or something cuz this is gona take a long time, formatting 80gb takes a pretty long while, and if you do this before you go to bed then even better you just get up and start a new day knowing ur ps3 will survive this and u will go back to being happy wit it like before =] yay.
10: ok well now that the format is done and ur laptop says is ok to turn computer off, turn it off, it might do it by itself idk, it DIDNT for me i had to click restart now, ok by this time your ps3 should have given you the message saying that there was a problem doing the file restore and that will need to be formatted, now take off your ps3's hdd from your laptop and plug it back in where it belongs, on your ps3 and once it is in place YOURE good and ready to go, take your ps3 controller and click on YES, format hdd, and then it will format your hdd without problem.
SUCCESS!.......yay try putting in your favorite ps3 game blu ray movie or watever you want to test it with and it should work like it worked for me. remember formatting the hdd wit the ps3 itself WOUNT help you at all, this is the best way to fix your problem...good luck and i hope this also helps other people with this problem...latz and feel free to ask any questions, anyone can.
email===> gothik_zoul@yahoo.com
myspace===> myspace.com/gothik_zoul
Posted on Mar 31, 2009
Ps3 won't read any games. everything else works including dvds. please help!
If your PS3 will not read your games what you can do is readjust the laser and it is not that tough to do, once you do this it will be able to read your discs again no problem - do this from home or send it in to be repaired.
Jul 07, 2010 | Sony Playstation 3 (PS3) Console
Please help...My ps3 won't read any games.
I think I can help.
Inside a PS3 is a little laser that reads a disc. It may be broken, dirty or damaged. I recommend going to your local tech store/where you bought it from. If your PS3 isn't out of warranty and you still have the receipt, simply take it back for a new one :). Hope this helped!
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont read my game disc;it reads and plays everything else fine,what came i do,Please help!!!
my ps3 come ,i was playing my game at the end of the game it froze iturn it off and when i cut it back on and put in 1 of my video game.dvd .cd and there was no display is it broken
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
Ps3 game wont read? or goes blank screen.
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like No Display Problme. You may check out the informative blog post at PS3 Repairs blog
Hope it helps to fix the problem.
Apr 18, 2009 | Sony Playstation 3 (PS3) Console
Ps3 won't read any discs or games
PS3 is The amazing device by sony but it has some common problems like Disc read error, unreadable disc etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
Not reading dics
PS3 is The amazing device by sony but it has some common problems like Disc read error, unreadable disk etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont read games
the lens eye maybe dirty clean it rubbing alcohol on a Q-tip. gently clean the eye and use the other end of the Q-tip to dry the access rubbing alcohol.
Nov 22, 2008 | Sony Playstation 3 (PS3) Console
My ps3 games dont register
mine just started doing that also... it reads everything except the ps3 games...
Nov 02, 2008 | Sony Playstation 3 (PS3) Console
No game disc read
Are you using games from the same region? It kinda sounds like your laser is dead or dying.
Sep 12, 2008 | Sony Playstation 3 (PS3) Console
Ps3 not working
same problem here  updated system played game game froze now - it wont read any games, dvds, blu rays... please help
Aug 05, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
780 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
