2002 Hummer H1 Logo
Anonymous Posted on Feb 10, 2009
Charging system problem.
Does anyone have a charging system wiring diagram for a 1997 Hummer H1? It has a 6.5L Diesel.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
459
Points
0
Go to www.humvee.net or www.flashoffroad.com Both have an extensive data base of tech info
Why doesn't charging system charge?
Did you check for B+ voltage at the wires connected to the alternator ? Could have a blown fuse or fusible link . Go to http://www.bbbind.com/free_tsb.html free wiring diagrams . Fill in your vehicle info .under system click on engine then under subsystem click on charging system . Look at diagram to see which wire has power an what fuse powers it etc. There are some good videos on youtube on checking charging system .
Where can I get a wiring diagram for a 1997 Dodge RAM 3500 diesel pickup?
1997 3500 Wiring Diagram - Dodge Diesel - Diesel Truck Resource Forums
www.dieseltruckresource.com/...dodge-ram.../1997-3500-wiring-diagra...
Jan 24, 2011 - Hey guys, I'm working on a 97 3500 that's had the bed removed and replaced with a flatbed. There is the biggest mess under that truck wiring wise and. ... 2007 Ram 3500 A/C compressor wont engage, need wiring diagram ...
Dodge Wiring Diagrams / Schematics - YouTube
? 1:13
https://www.youtube.com/watch?v=UI6_vhCHFYU
Nov 19, 2013 - Uploaded by Robert Nauert
Dodge Wiring Diagrams / Schematics ... Nitro, Power Wagon, Ram 1500, Ram 2500, Ram 3500, Ram 4500 ...
1997 Dodge Cummins - Full color wiring diagrams - 12 Valve ...
forum.mopar1973man.com/.../1638-1997-dodge-cummins-full-color-wi...
Wire diagram renault
if the alternator isn't charging it needs replacing , i don't see how a wiring diagram will help you
Charging system voltage low
there are only 3 parts. but the causes are 25 or more.
1: belt missing slipping,
2: engine rpm below 800 RPM (lots of ways ,ask )
3: ALT had.
4: wiring to ALT bad.
5: bad battery or its connections, (wires)
6: bad fuse. see fuse link a11? on fFM page 20?
7: car is PCM alt controlled, it can be bad too. see 2 field wires on ALT and PCM on page 20? below?
8: battery temp sensor bad. making PCM think battery overheats.
the fSM covers all tests above.
pick car here, then pick charging.
5 alternators used on the 5 diffr.engines. got the wrong one?
the see wiring diagrams at end and chapter 20 inside, charge.
pdf page 118 for gas engine, if diesel next few.
Service charging system error message
You should be testing instead of throwing parts at it. Have the charging system tested in the car.
2helpful
1998 isuzu trooper need wiring diagram for charging system with a3.5 li5ter motor
1998 trooper new alternator and still not charging and alternator bench tested good,
Check main 80 amp fuse in engine compartment and also check fuses in inside fuse box, there two in that one. first is engine fuse 15amp and the 10amp gauge fuse,
Here is the wiring diagram for the charging system as you asked for , also check connections, follow battery wire off the back of alternator make sure connections are good , that wire runs to engine fuse box and that is one fuse that i said to check it is 80amp, hope this is helpful good day9_30_2012_10_15_05_pm.gif
38helpful
2answers
How to connect a new era alternator voltage regulator wiring diagram.Or a schematic diagram of the charging system.
knowing the color codes can be a great help..usually in 12v reg system,from the regulator there are 6 white wire having a stripe codes,blue means neutral,green means field,black means ground to body,white means hot wired to +12v,yellow means to bat charging indicator going to instrument panel and finally red means to ignition....and always secure the regulators case to ground.
Hummer 07 h3 will not charge light is on the dash and all so flashes charging system needs servicing.. changed alternator system still will not charge..
MOST NEW GM CARS YOU NEED TO ERASE LOW CHARGE TROUBLE CODE FIRST USING A CODE SCANNER BEFORE CRANKING VECHICLE.IF ALL READY DONE CHECK ALTERNATOR BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES AND CHECK ALTERNATOR FUSE.
Could anyone help me find some quick on line resources for 1992 Ford Taurus Wagon 3.8 L Engine Diagrams/ Wireing Schematics etc.
GO TO AUTO ZONE - ADVANCE AUTO - OREILLYS. BUY A HAYNES REPAIR MANUAL.IT HAS WIRING DIAGRAM FOR EACH CIRCUIT.LIKE HEATING + AC CIRCUITS INTERIOR LIGHTS EXTERIOR LIGHTS STARTING + CHARGING SYSTEM WARNING DASH SYSTEM POWER DOORS + POWER WINDOWS + RADIO SYSTEM + CRUISE CONTROL + WINDSHIELD WIPER SYSTEM.ALSO HAS WIRING DIAGRAM FOR ALL THE PCM SENSORS.AND THE PCM ALSO.
1helpful
Looking for a wiring diagram for a 1999 Ford F350 Diesel. Anyone got one???
1999 ford f250 diesel electrical system diagram free|Free eBook ... The 1999 ford f250 diesel electrical system diagram free Documents at ... That's a Ford Tractors wiring diagrams and Harnesses contributed by Neil Reitmeyer ...
www.ebooksquad.com/search/1999+ford+f250+diesel+electrical+system+diagram+free - 22k
Top Hummer Experts
ZJ Limited
ZJ Limited
ROBERT GARCIA
ROBERT GARCIA
Are you a Hummer Expert? Answer questions, earn points and help others
