Question about Toshiba SD6100 DVD Player
Toshiba DVD player says every DVD is a bad disk
My Toshiba SD-6100 has started saying every DVD I put in is a bad disk. Any way to clean it or something? This unit is only a month old.
  • 1 more comment
  • Anonymous Mar 05, 2009
    we had the dvd player for only a month or so and it says bad every disk I put in I even tried one of those dvd cleaners it doent work
  • tamstace Mar 22, 2009
    My toshiba Model SD-3109U Makes a noise when you put the disk in like it's trying to read it but it wont play. I took it to a shop and they said the laser pickup was bad. To fix it would cost $238.00. If its making a noise like it's trying to read is the pickup bad?
  • Anonymous Apr 02, 2009
    same as everyone else 5 mths old and says bad disc! Piece of junk! Dont buy it!
    Genius:
  • 3,422 Answers
HI,
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.see if the player tries to read the disc. Load a disc and listen.
Posted on Feb 10, 2009
When loading cd, it says bad
It's likely there is dust on the CD player lens. Many DVD units have two lens units, one for DVD's and the other for CD. You will to clean the CD one.
Mar 26, 2017 | Toshiba Televison & Video
I have a toshiba modelsd-p1850sn model it goes on
possibly needs both the disk and the laser iris cleaned. Buy a cleaning kit for about $15 and run the disk in the drive to clean the iris.
please rate my help++++Thanks for using Fixya
Nov 29, 2009 | Toshiba SD-P2000 Portable DVD Player
My toshiba SD 6100 dvd player is playing only blue screen
just tried with RCA or the hightdef. cables the one with Green bue and red.
Aug 24, 2009 | Toshiba SD6100 DVD Player
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Toshiba Sd2800
I have the same problem with my SD-2800 that Ruska has. Any suggestion how the unit can be fixed?
Dec 09, 2007 | Toshiba SD-2800 DVD Player
Sd 5000
the unit i purchased ran great for about 2 months then the video started to freeze. power cycled solved the problem initially, but when power cycling did not cure the problem, i started shaking and tapping the unit. at a point of throwing the unit away - took the cover off to see what's inside. with the cover off, it ran just fine . put the cover back, ran ok for a while then started freezing video again.
twisting the unit appears to make it function..
my solution that appears to work for my unit. .
loosen only the two screws holding the plastic drive mechanism down to the bottom plate (chassis) assumption is that the metal chassis was twisting the drive mechanism and offsetting the photo pickup.
this has worked for the past 2 weeks without a problem.
Dec 04, 2007 | Toshiba SD-5000
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
Toshiba SD-3980
If the disk is not dirty, smudged up or scratched -- it is likely the laser pickup getting weak or the spindle motor not keeping at the right speed. If you have to clean the disc, wipe from the center out with a clean soft cloth.
Jan 13, 2007 | Toshiba SD-3980 DVD Player
Toshiba SD6100 DVD Player Logo
4,247 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
