Question about Acer Computers & Internet
Dissambling acer 5570 laptop
I want to dissamble to clean dust inside the laptop.
    Scholar:
  • 50 Answers
Before you go through complete disassembly, you might want to just 'blow' the dust out. Its much easier, less prone to error, and achieves the same result; All you'll need is an air compressor with a spray nozzle attached, and a minimum 25-30lbs pressure.
Steps:
Turn off the computer, and unplug the power cord.
Remove any removable cover - memory, wifi/mini-pci, hard drive, and pull out the battery.
Place the laptop, closed, upside down on a table or work surface, and hold the end of the air compressor's spray nozzle first against the fan vents while spraying air into the laptop casing. (You should see a cloud of dust burst out)
If there are more fane vents(there usually are), blow out each one in turn.
Hold the nozzle four inches or so away from the memory access, and blow air into the casing. Do the same for hard drive panel, and any other open vent or panel.
Close the hdd, memory, and wifi panels, and any other open panel, turn the laptop upright and open the screen.
Holding the air nozzle a few inches(four-six) above the laptop, carefully spray the keyboard(too close, and you risk blowing out the rubber pads that lift the keys).
Finally, wait a few minutes for any condensation to evaporate, and you're ready to go.
Posted on Feb 10, 2009
How to fix my 5130c2 that have white display only
make sure if your device working or not? if working that means it has LCD problem then try this : dissambly the device and unplug lcd clean with alcol and plug again this will solve the problem,if problem persist you need to change LCD (see on you tube how to do clean and dissambly) and if it is not working it is a software problem then connect to pc suite and update firmware.or try hard reset press and hold 3+*+green button+power on until show insert sim card.
Jun 28, 2012 | Nokia 5130 Cellular Phone
How dissambling gateway w340ui
watch this:
http://www.youtube.com/watch?v=CMo6_0mkEE8.
Mar 11, 2012 | Computers & Internet
Remove bios password for Acer Extensa 7220-101G08Mi
if you know the bios pass word go into bios hitting del upon start up then on pass word enter the old pass word then make the new one empty click save if you dont know the pass word then the back up battery on the mother board will need to be removed for several hrs
please rank this advice below
Jan 18, 2011 | Computers & Internet
How do i clean my hp psc printer 1315, dissemble?
I have the same question. I want to clean the inside of HP PSC 1315, I want to get beyond the scanner glass. I tried to use a screwdriver to unscrew the four screws on the four corners of the printer, but the screwdriver doesn't fit. Is there a special tool to use it. Were you be able to dissamble the printer ?
Please let me know. Thanks!
Jul 19, 2010 | HP PSC 1315 All-In-One InkJet Printer
DISSAMBLING SAMSUNG R40 Hello there, SAMSUNG R40 I got the same problem. I don't know how to dissamble my SAMSUNG R40, and the cooler seems to be clogged with dust, so I'm afraid I'll fry my laptop. I've...
If you are not sure what you are doing, it would be a lot better if you put it back together and called a pro to clean it for you, at least it will work when you get it back.
Jun 24, 2009 | Computers & Internet
Microoven did not work's
hi   the microven work with the voltage of 230-250v 50 z.. if it is not a supply card problem..  u see whether the control panel work are not by pressing start button if it did not not start's mean's it is a circuit board problem.. and at same time there will problem with the fan also.. so, it does't start's.. if it is not in warrenty period .. u could dissamble.. it and chek with a muiltimeter .. by verifying the power board, and conntro board.. dissamble and clean it first.. there may be some minute problem so, that it will not work..  don't forget to vote me..  thank u..
Sep 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
I have an acer aspire 30003, a few weeks ago it stopped running off of ac power, when its plugged in you have to jiggle the power cable just so, or else it only runs off of battery power, and eventually it...
welcome to fixya
if you do not know how to take apart your best bet is to take to a service center and have them repair it
sorry could not be more help but it is a very hard job to do if you do not know how
have good day
Jul 28, 2008 | Acer Computers & Internet
Computers & Internet Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
