Question about HP (PH075AV) Bluetooth Wireless Adapter
Internal Bluetooth Adapter won't work...
For some reason, my laptop won't recognize the internal Bluetooth adapter. my PC is a HP Pavilion dv9700, model # dv9930us.
  • subrata_vet Feb 28, 2009
    bluetooth of my laptop won't work since i change my window from vista to xp. how can i solve this problem?
    Scholar:
  • 54 Answers
Hi...
first what we need to check if the bluetooth software is installed or not,right click on my computer and go to properites,once you click on properties,click on the tab that says advacned and underneath this box you will see an option which says device manager,click on device manager and check if the bluetooth adapter is listed under the category that says bluetooth or network adapter,if you see that there is no yellow question mark under bluetooth option,if there is a yellow question mark then you probably need to reinstall the drivers...if the software is listed and yet it is not getting detected probably we need to reset the bluetooth adapter and also make sure if the bluetooth light on the laptop is on or not,the light is situated on the front of your laptop...
incase the device manager looks perfect then go ahead and reset the bluetooth card
link to download drivers for vista...http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-56755-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3747258
here the manual that u can download to see how you can reset the bluetooth card...http://h10032.www1.hp.com/ctg/Manual/c01295898.pdf
vedhick
Posted on Feb 15, 2009
HP Pavilon dv6910us Entertainment PC Defective ac adapter connection? ac port?
Sounds like your Internal DC Power Jack is broken. It has to be repaired or eventually it will completely break and you won't be able to boot after the battery drains. It calls for taking your laptop apart since it is on the motherboard or sits in a slot on the motherboard. Most times it is soldered on the motherboard. You have to unsolder the old and solder a new on it it's place.
Mar 27, 2012 | HP Pavilion dv7-1132nr Notebook PC
I HAVE A HP PAVILION DV9700 I DO NOT HAVE A POWER ADATOR CAN I RUN POWER FROM MY OTHER PC TO THE DV9700 TO POWER IT
As long as the adapter you are going to use matches the specs of the required adapter, you shouldn't have any problems, check ebay for a replacement
Feb 24, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
My laptop will not charge when the charger is plugged in. I tried removing the battery and turning it on while it was plugged in. Is my computer messed up or is it just the charger. Also my warranty has...
Your laptop still not charge even with the battery removed?
I guess you need a new adapter. Or you can test with a known working adapter first.
Specification of HP pavilion DV7 charger:
Output: DC19V 4.74A
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin inside
Reference: http://www.chargerbuy.com/replacement-hp-pavilion-dv7-ac-adapter-19v-4-74a.html
Feb 16, 2011 | HEWLETT-PACKARD Hewlett Packard Pavilion...
I have hp pavilion dv6325ca laptop can now i upgrade my laptop with internal bluetooth module as already i have a internal wireless adapter can u suggest how to upgrade
The easiest option for you is to buy a Bluetooth dongle. It connects via USB, and if you get a compact one like the one in the image below you won't even notice it on the laptop. You can get one from Ebay, they are dirt cheap, under $2.
Dec 23, 2010 | HP 407674-004 - HP Compaq nc2400, Pavilion...
My screen is not working! the notebook is working ,but no video. hp notebook dv9700 series
I would unplug it and take the battery out. Then plug only the ac adapter in and turn on. If still no video. Try external monitor. If still no video check HP recall list. I think these laptops have known chip problems. Maybe you can get warranty repair. search for hp recall laptops dv. then you'll see if yours is on the list. and contact them to see if included in extended warranty. Basically I suspect a chip problem here if no video on external monitor or internal
Nov 08, 2009 | HP Pavilion dv9700t Notebook PC
HP Pavilion dv9700 laptop, Wireless stops working at random.
It is because your wi fi network adapter not getting ip addresses from router.
For that connect your router to computer with ethernet cable then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go to advaced and enable DHCP .
Then save and restart router.
Then go to your laptop go to my etwork places proeprty then right click on your wi fi adapter then proeprty then tcp ip and set ip get automatic.
Then it works fine.
Let me know if you need more assistanse.
Thanks.
Sep 23, 2009 | HP Pavilion dv9000z Notebook
Dv2000 internal wireless adapter not detected. enabled in bios setting?? the internal wireless adapter is not detected and doesnt connect to the internet. however, i checked to see if the direct cable...
Is there a blue light to show that the wireless is active on the laptop? If not, switch the wireless connection on once windows has loaded. It may be that you have a faulty connection between the wireless card and the motherboard. Check out this link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277
and follow the instructions
Jun 08, 2009 | HP Pavilion zd7020US Notebook
Hp dv2815nr package W/ bluetooth mouse & case
The best way to overcome the situation would be to get an internal bluetooth card installed into the laptop if possible. http://en.wikipedia.org/wiki/Image:DELL_TrueMobile_350_Bluetooth_card.jpg
Jun 25, 2008 | HP Computers & Internet
HP dv1000 laptop and internal wireless modem
Although you have internal wireless, you are capable of attaching an external wireless device. For example, you could attached a D-Link WUA-1340 USB Wireless G adapter (http://www.dlink.com/products/?sec=0&pid=477), or, if you have a PCI port, you can use a Linksys WPC300N Wireless-N Notebook adapter (http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1144763513196&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1319686869B07). Either device with any brand will work just like your internal wireless. In fact, because you chose to use an external device, you may get a better wireless signal. Because internal wireless devices are inside the computer, it is more difficult to received a signal than with an external device.
Apr 20, 2008 | HP Pavilion dv1000 Notebook
Updating to internal (non-PCMCIA) Ethernet
Your Pavilion N5340 should have an internal mini pci port, which can host a wireless adapter.
regards
Feb 13, 2008 | HP Pavilion N5340 Notebook
Computers & Internet Logo
632 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
