Question about Kenmore 44102 Front Load Washer
How to check and possibly fix a clogged pump
I just read a posted question about a clogged or fried pump. I was wondering how I could tell the difference and possible fix a clogged pump vs. a fried pump. If you know what I'm asking. Thanks in advance!!!
Anyways, my washer is spinning and all that good stuff, the water just wont drain. Like a week before that I could not get any water to fill it!!! I figured it was frozen pipes though, but nothing else was frozen. Just a little more info if it helps...
  • 5,911 Answers
The following link explains how to check the drain pump on a Kenmore Elite for obstructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Read through the link thoroughly. The use of a wet/dry shop vac comes in very handy when performing this task and minimizes any mess you may encounter. These pumps can become damaged with debris jammed in the impeller. If cleaning the pump does not correct your problem, the manufacturer recommends replacing it.
Since the pump is monitored by the volume it pumps, you still may have to replace it even if it seems to be running. If error codes are generated after cleaning and the pump is running, the impeller and/or motor may be damaged, causing it not to pump at the correct volume (this is a worst-case scenario). If you determine that the pump requires replacing, post back and let me know. I can give you pointers on how to replace it and where to obtain a replacement. If you need further assistance or have additional questions, please let me know. I hope this corrects your problem.
Posted on Feb 10, 2009
My 95 blazer keeps cutting out changed fuel filter and fuel pump is good, i wonder if i got bad gas cause it started after i had put $5 worth ov gas?
Could be trash in the lines or just a coincidence. You should never let your tank get below 1/4...the fuel actually cools as well as provides lubrication for the fuel pump. How was fuel pump checked? If they didn't check fuel pressure then it could still be weak. Also is check engine light on? If so you need to have codes read....there are lots of things that could cause the issue you have and the codes can help identify the exact cause.
Aug 04, 2016 | Chevrolet Blazer Cars & Trucks
Dishwasher KUDM01TJWH0 Dishes don't come out clean. Removed the inlet valve per information on some websites. Put a multimeter on the valve and it reads 1.013 on the OHM 2K meter. I can't tell if...
The easiest way to tell if it is filling properly is check the water level when the fill cycle is done...the water level should be level with or just over the heat element (oh it sounds as it the valve is good per the ohms reading) Now then a leading cause of poor washibility results is a clogged filter on the pump and ya should check it your pump filte rhas a build up on it restricting water flow through the pump which will surely give poor was results. This youtube video will show ya how to check for a clogged filter http://www.youtube.com/watch?v=iRCCrEwrst8
Good luck i hope i have been able to help ya fix your dishwasher,
GENE
Oct 20, 2011 | Refrigerators
I have a 00 cadillac deville base. i have a po410 check engine code. i was wondering what is the usually fix for this
Code po410 secondary air ignition malfunction
Start up your car cold, if you don't hear a sound like a vacuum cleaner running under your car you probably need a new air pump.
First, check the maxi-fuse in the underhood fuse block for the AIR pump.
If it's blown then you need to get under the car on the driver's side.
Remove the front cover and look at the bottom cover on the air pump, if it's dislodged and full of water the pump probably sucked up some water and is no longer good. There is a bulletin out to replace the air pump and the intake duct with a redesigned part that is not so suceptible to water intrusion. Also it's possible that the connector is burnt up, I have seen some with new air pumps set codes because of a fried electrical connection.thank you and have a wonderful day
Aug 22, 2011 | 2000 Cadillac DeVille
I have a Kenmore Ultra wash 665.16522. The water won't drain completely. About 2 or 3 inches of water will stay at the bottom. I wonder if there is a food catcher, and if so, how do I clean it? JSBravo
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance.
Dan
Mar 16, 2011 | Kenmore 16522 Built-in Dishwasher
I have a 1998 Dodge Caravan and the oil gauge light dings when I slow down or stop. How can I fix this?
Your oil gage is telling you your engine is showing signs of wear / aging. (Possible wear on the main bearings, connecting rod, and camshaft bearings) Your idle may now be lower than it should be. Or your oil sending unit is failing. Or... the oil pump iself is not performing as it once did. Or the Oil pump pick up tube in the oil pan is clogging up. Have you tired a direct pressure reading of the oil pressure? If the direct pressure gage indicates same as your oil light then everything listed above will have to be checked to determine exactly what it is that needs fixing.
Kelly
Apr 13, 2010 | 1998 Dodge Caravan
Wm2688h will not drain anymore.
You need to take a flashlight and look into the suction port on the pump. Make sure the pump is not clogged and check the pump impeller. Make sure that no blades are broken or missing and the impeller should spin freely. If any blades are missing or broken on the impeller or if it will not turn freely, the pump will have to be replaced. Hopefully, it is just a clogged pump. Hope this helps and best wishes.
Aug 08, 2009 | LG WM2688HWM TROMM SteamWasher
Error code f-21 how can I tell if the pump is bad
according to the whirlpool website the f21 is a communication erroe, nothin to do with pump. if you remove the top panel from washer (3)screws from across the rear of unit, youll find the main control board just under there. i would look for loose wiring connectiond at tha point.
f21=
This error occurs if the touch-pad/LED assembly is not
able to transmit/receive data to/from the central control
unit (CCU).
Possible Causes / Procedure
1. Check the touch-pad/LED assembly by selecting
different cycles and changing the modifiers and
options available to confirm the touch-pad/LED is
responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
1996 cadillac deville want start
If you had a strong stream of gas shooting out then you may have an fuel injector problem. Possibly a clogged injector or bad injector.If the stream of gas was weak replace fuel filter first and test again.If problem persists check pump fuse then replace pump. sorry for miss reading your post.
Aug 25, 2008 | 1996 Cadillac DeVille
I have a whirlpool duet washer and I keep getting an alarm code FO2 which is a draining issue but I dont believe the washer drain is clogged possibly electrical issue
Have you actually checked the drain pump to be sure? It doesn't take much to clog the drain pump and cause slow draining issues. I've seen items as small as a cotton swab or toothpick stop the impeller on these pumps. The following link explains the "F02" error and how to check it:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
You may be correct and have an electrical connection problem to the drain pump, but this is not common. You should also make sure you are using HE detergent and read the label carefully when you do. Some of these detergents are double (2X) and triple (3X) concentrated. If you diagnose the problem and it turns out to be the drain pump, please post back with your model number and I can assist you with locating a part number for your washer. Here's the link for step-by-step instructions on how to replace the drain pump (if needed):
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope this helps you. Please post back if you require further assistance.
Aug 06, 2008 | Whirlpool Washing Machines
Kenmore 44102 Front Load Washer Logo
115 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
