Question about Conair 24 Piece Deluxe Chrome Hair Clipper Kit HC290
I need to put my clippers back together.
I needed to put the shaving foil on and i ended up taking the clippers off and some other parts came off and im trying to figure out how i can put back together. how to put the spring back On my clippers
  • 61 Answers
SOURCE: I need to put my clippers back together.
Please listen up, conair clippers,shavers etc.. are not good quality tools,you should try andis,there stronger and more reliable and gives a much better job.
Posted on Jan 26, 2009
Andis model mc-2
Go to the Andis website and look under the services section, find your clipper model and they will have an exploded view diagram of your clipper with each part listed and directions on where each part goes.
Apr 29, 2014 | Andis 01690 Hair Trimmer
I have a Remington f4900 foil shaver and I need replacement parts for it but I can't find them anywhere. Is there a specialty store that I should be going to?
Have you tried looking at a site like eBay or amazon? There is also always the possibility that you might need to get a new shaver if you really can't find the parts you need.
Feb 16, 2014 | Remington F4-4900 Foil Shaver with...
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
My Golden A5 clippers won't shave a knowlegable dog groomer friend of mine said the blade seems sprung from the housing it doesn't fit snug against the body of the clipper is there an adjustment I can...
it seem the hinge on your clipper is worn out, here how you can check it, place blade on with the clipper off tap the blade forward if the blade pop,s open the hinge is worn out, you need to replace it, Now on the cutting part of the blade when was the last time you had your blade sharpen. if it been a while or you can not remember it's time to have it sharpen by a professional.
Apr 13, 2010 | Oster Golden A5 1-Speed Universal Motor...
Putting back together hair clippers
are u talking about the clipper it self or the clipper blade i need to know which one
Nov 07, 2009 | Health & Beauty
Noisy Braun 7680
I followed the instructions from Nick123456 for taking the shaver apart, cleaned all areas and oiled everywhere I could see moving parts around the motor. Then I put it back together making sure that the side screws were very tight. It is now much quieter and the shave seems OK but not brilliant. (Sorry about the typos in the original posting).
Aug 03, 2009 | Braun Syncro 7680 Electric Shaver
Jan 26, 2009 | Conair Health & Beauty
Unable to get the blade back on
i had the same problem and i fixed mine ( it is not broken) ... the tongue is the thing that is silver and has grooves that face upward, the tongue should be up compared to pressed against the shave, take a small screw driver or a kitchen knife and get under the tongue and lift it up, once this is done you need to slide it on the blades and snap it down, i found that i did not need to have the clippers on to put it back on.... at first i got confused in thinking that the tongue was the red thing at the top, and in actuality this is the thing that moves the blades to clip.... i hope this helps, once you get the tongue up the blades are on in 10 seconds...
Aug 10, 2008 | Oster 76076-010 Hair Trimmer
Health & Beauty Logo
1,859 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
JDFFEMT
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
