Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Accidentally re-partitioned mac os x with win xp using bootcamp
Hi
I was using Mac os x 10.5.6 and decided i'd create a dual boot on my mac. so i used a pre-sp2 win xp cd. worked before no problem only difference is last time i wanted an even split between windows and leopard but this time i only wanted to allocate 32GB to windows.
anyway the long and short of t is that i wasn't paying attention and suddenly noticed that it said quick format ntfs or full format ntfs and i didn't want an ntfs format because i needed leopard to be able to read the data. So I aborted. when i my mc back on it just hung at a black screen. when i rebooted and hit the option key it showed window drive instead of my mac and i was so confident it would work that i didn't back up my hard disk before.
is there anyway to get my data back? i tried boomerang recover but it could only recover ntfs partitions pre-mac usage. Is there anyway to get my hard disk and file structure back?
  • Enitan Ajayi Feb 11, 2009
    Yes, that is where it currently is as i wouldn't have been able to use a piece of software called boomerang recover. As I stated it could only recover ntfs partitions, which i triedinstalling before my current mac setup (i mean the one i am trying to recover).
    I have te-installed mac os x onto another hard drive and connected the hard drive that i wish to recover by usb.
    Is there anything that can recover the drive to the way it was? or that will recover ALL the data from the drive as i think it was only repartitioned.
  • JDTec
    JDTec May 11, 2010
    In a case like this, I usually install the hard drive with the data into an enclosure and hook it up to another working computer and retreive the data from it. Then reformat and copy the data over.
Your data is most likely lost. The only real way to know for sure is to spend the money on a data recovery company.
Posted on Feb 12, 2009
Intel core2duo no sound windows xp
I take it the laptop is dual boot and the sound works ok when used under Mac OSX.
If this is the case, then the laptop probably needs the audio drivers for windows. These can be downloaded from the Apple website (Bootcamp Drivers) or by using the 'Bootcamp' utility on the Mac side.
Oct 15, 2013 | Intel Computers & Internet
Tip
How to install/dual boot Linux on your mac
you need to <br /> <br /> A) download a copy of linux (i always use ubuntu) <br /> http://www.ubuntu.com/desktop/get-ubuntu/download<br /><br /> B) burn that copy of linux to a CD<br /> (to do this you need to go to your disk utility app and click burn image to disk and than select the iso you chose, using other software the option will be something like "create mountable disk" OR "burn bootable image")<br /><br /> C) boot to that cd--- to do this you put the cd in and reboot your mac while holding the 'C' key <br /> <br /> D) open the partition editor and create a partition on your hardrive the size that you want linux to be (idealy replacing the main partition on your computer not one of the smaller boot partition)<br /><br />*Optional- If you are planning on dual booting do not replace the main partition completely instead create a new linux partition from the main partition's free space additionally if you are dual booting and using Leopard or later you can use the bootcamp app to create a partition than use the linux partition editor to format the bootcamp partition to free space and than install linux on it<br /> <br /> <br /> E) once you have the partition made simply follow the initial instructions to install there will be an installer app that replaces your now free partition with linux.<br /> <br />*if you chose to dual boot to access linux simply hold the 'Alt' key when booting up and than highlight the linux/windows HD<br /> Enjoy<br />
on Mar 02, 2011 | Computers & Internet
Tip
Dual Boot Xp & windows 7
First you have to create partition.You need at least two partition. One in which you intall Xp and other for win 7. WARNIG BACK UP YOUR DATA BEFORE THIS.*(You can create partion by any hard drive manager you can make a hard drive partition in control panel>administrative tool>create & manage hard drive partition)
Now install xp first in one partition. If you have pre installed then avoid this step.
Now install Win 7 in another partition.
After you restart the machine will ask to chose your os. & just select the required OS.
If any problem appears then just put win XP disk & repair it.
You cant install win Xp after windows 7.
You have to format win 7 before installing Xp.
Commiting any of trick or Tweak you need to backup your data in another HD partition
on Mar 10, 2010 | Computers & Internet
Used bootcamp and tryed to install windows and got disc error ,now wont go back to normal statas. how do i fix?
Insert the Mac OS disk in the drive and reboot while holding down the C key. This will launch your computer in Mac OS and then you can access Disk Utility from the startup window.
Rebuild/ repair as needed, then I suggest removing any partition that you may have set up and re partition your drive for the windows stuff. Give yourself ample room on the harddrive for your windows software and files.
Be sure to print out a copy of the instructions for bootcamp before you launch... also be sure to allow it to automatically set up your mac for windows. Do this:
1.set up a partition according to the directions for bootcamp
2. install windows as per bootcamp instructions
3. after it's launched in windows, insert the Mac OS disk and it will launch all the setup for your mac hardware to run windows... modem, wifi, all that mojive that you usually need to spend hours in PC land ..mac will set it up for you.. Also download a copy of Bonjour from the Apple site. this will set up your printers for use in windows very easily and quickly..
The main thing is follow the directions and let the computer do all the setup...
May 21, 2010 | Apple iMac (MA876LL) 20 in (MA876LLA) Mac...
How to install on mac
You cannot install this software on a Mac. It is only compatible with a Windows PC. However this Apple program will do all it will do and more. http://www.apple.com/finalcutstudio/finalcutpro/
Dec 15, 2009 | Sony Screenblast Movie Studio 3.0 for PC
I install and bootcamp and resize the disk to 160gb. then i accidentally put the cd in the USB external cd drive. i forgot to put it in the Imac g5 cdrom drive. when i boot up.. its a mess my mac os x not...
I understand your problem to be that at the time you were executing the critical reboot just prior to installing Windows with Boot Camp, you placed the Windows CD into the wrong optical drive. Now your machine is stuck at the gray screen and is not responding to anything and will not boot from the system DVD
I have encountered this problem previously. The solution is to boot from an external drive containing a valid copy of the Mac OS. Although your machine will not boot from a DVD at this point, it WILL boot from an external drive if you hold down the Option key after you hear the startup chime, and select that drive's icon when it appears. Once you have successfully booted, go to System Preferences / Startup Disk to select the Mac partition of your internal drive, and your machine will reboot normally.
This leaves only the question of how you obtain an external drive containing a valid of the Mac OS. Some options are 1) a cloned backup drive, 2) another Macintosh via "Target Disk Mode," or 3) have someone create you such a disk from another machine. On the plus side, this solution involves no loss of your data, which makes it worth pursuing.
Nov 15, 2009 | Apple iMac G5 Desktop
I want to install mac os 10.5 leapard on my windows xp pro without destroying it how to dual boot please
I'm confused at the question. You will be unable to install Mac OS on a Windows device, but can install Windows on Mac Hardware. If you have a Mac machine you can install in two ways 1.) there is a partition application in utilities that allows you to create a new partition where you can istall windows without ruining current. 2.) if you do not want to partition then you can use VMware or Parallels ( recommended ) emulators to install the OS
Sep 04, 2009 | Microsoft Windows XP Professional
Black screen says pres any key to boot rom CD disk error press any key to restart. Cant do a thing turn it on or off get the disc out. I have tried to load windows xp through boot campon my macbook and...
You have probably formatted the hard drive when trying to install XP, XP is not compatible with Mac hardware. You will need to purchase a copy of the Mac OS or try and locate the restore disks that should have come with your computer.
Jul 15, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
How to install vista on I-MAC
Hi Harry
yes, vista can be installed on I-macs ...but i need to know which version of operating system do you have (whether it's leopard or tiger and version 10.5.2 or earlier)
I say so because new version of Leopard Operating system has a feature called "boot camp"... this is Apple's "bootloader" ... which means it will help you install windows Vista on Apple I-mac .
If you have genuin vista disk handy with you and after you have backed up all the data on the apple machine , this is what you gotta do....
1. Using the Finder, navigate through Applications, Utilities and run Boot Camp Assistant.
2. Click Continue on the Introduction screen.
3. Next, you will need to specify how you want your hard drive divided up for Windows. A separate partition will be created that Windows will use. Drag the divider to adjust the size for Windows as shown below. I recommend at least 15 GB to allow for the OS and some apps. When you are ready, click Partition and your disk will be prepared.
4. It is time to start the Windows installation. Insert your Windows Vista install DVD and click Start Installation. Your Mac will automatically reboot and boot to the install DVD.
5. Install Windows Vista as you would normally do. When asked where to install, select the partition called BOOTCAMP. You will need for format this partition with NTFS.
6. When Windows Vista has installed, remove the Windows Vista install DVD and insert your OS X 10.5 Leopard install DVD. Run the Boot Camp installer application and all the Windows drivers for your Apple hardware will be automatically installed.
7. When you want to switch to OS X or Windows, just reboot and hold down the Option key to select what partition to boot.
Jun 07, 2008 | Computers & Internet
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
179 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
