Question about Sony Alpha DSLR-A100 Digital Camera
I have a sony a100. It says unable to use card
I can not get my camera to work with any card I have. Every time I put a card in, it says "Unable to use card...Format?" and when I do, It still wont take the card. What happened??? Also, how do you zoom on this camera? I am freaking out cause I have my first photo shoot in 2 days! Help!!??
    Scholar:
  • 170 Answers
What card do you use on the A100? And what capacity? Are you sure you have inserted it in the correct way? Be careful while inserting a CF card because of you insert it wrongly, it can damage the camera. Zooming is done using the zoom ring on the lens barrel. Just twist the zoom ring. Hope you are using the 18-70mm kit lens with the camera.
Posted on Feb 10, 2009
When I turn on my camera it state unable to read memory card and gives you the choice to format. I have used the card and do not want to format it.
This is likely due to the memory card being damaged or it losing a part of data. The only solutions are either to purchase a new memory card, or to save the data from the memory card onto a computer or another location and then format it.
Oct 18, 2011 | Sony Alpha DSLR-A100 Digital Camera
Intermittently unable to review photos taken with Sony A100. Also at the same time unable to access the menu
Is the CF card a slow or counterfeit one? There are lots of cards on auction sites that are branded, but copies with poor quality components. try a known good High speed card. Also check if you have any bent pins in the camera CF slot.
Jun 02, 2010 | Sony Cameras
Pin missing in card slot of Sony A100, I get the message unable to use card.
well it cant read the card,,, its a shop job to fit a new card reader slot bord,, pricy job too,,,sorry
Oct 30, 2009 | Sony Alpha DSLR-A100 Digital Camera
I have had my sony for about 2 years and suddenly last night while shooting pictures, the message "unable to format card" appeared on my screen - what can I do?
It's just the memory card. This error message comes up when the card sustains damage to any degree. Did you lend your camera or card to anyone or put the card into the wrong reading drive by accident? It may be time for a new memory card/stick. Exchange it if it's still under warranty.
Jun 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
What do i do when I turn on my sony alpha 100 and it tells me unable to use but I formatted it and it still says unable to use???
It's most likely a problem with the memory card. This message comes up when the card sustains damage to any degree. Did you lend your camera or card to anyone or put the card into the wrong reading drive by accident? It may be time for a new memory card/stick. Exchange it if it's still under warranty.
Jun 06, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony A100:put in empty CF cards, says card full, won't format
Might be 2GB card is more then enough for camera hardware o handle. Try 1GB card in this camera.
Mar 15, 2009 | Sony DSLR-A100 K Digital SLRCamera Digital...
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
Cf card reader sony a 100 dslr
Buy a camera that does not use CF. Time to upgrade.
Nov 12, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
425 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
