Question about Panasonic Lumix DMC-LZ7 Digital Camera
Camera will not work after Ni-MH and Ni-Cd batteries used
Camera appears to be dead after an Ni-MH and an Ni-Cd battery were put in the camera together by mistake.
I have tried a pair of Ni-MH. No luck.
Is it repairable? What is likely to have 'blown'?
Thanks for any help.
Warwick, New Zealand
  • 68 Answers
Its not good for the batteries to combine different types but it shouldn't have affected the camera as the voltage they produce is the same. Try a couple of Eveready AA lithium batteries.
Posted on Aug 30, 2009
WHICH BATTERY DOES SUPPORTS IN THE SAMSUNG ES30 Will ENVI NI-CD battery work ?
You can use that battery. IT wont last as long as the alk or the Nimh
Aug 01, 2014 | Samsung ES30 Digital Camera
My Vivitar DVR-310 won't turn on anymore
Most obvious are the batteries. You are supposed to use two AA Alkaline / Ni-MH batteries. The best choice are the Ni-MH rechargeable ones, because you can record twice as long as with the expensive alkaline batteries. When the alkaline batteries are empty, you have to trow them away.
But Ni-MH batteries don't live forever. Typical they should survive 1000 charge discharge cycles, but when "misused" they can be bad before you reached that.
Please also check the contacts. Both, on the batteries and in the camera, where the batteries go, if these contacts are all clean and shiny. And at last, make sure you did put in the batteries the correct way. Turned around the camera won't work at all.
If you got the camera brand new, you should know there are no batteries delivered with the camera.
Dec 27, 2013 | Vivitar Cameras
I have just got a second hand cx4200 camera i have put in nomal batteries the light goes straight from green to red then switches off do i need kodak batteries
You can use any "AA" batteries, just make sure to use a fresh set.
Other options:
optional camera dock with Ni-MH rechargeable battery pack (in-camera charging); 2AA lithium or Ni-MH batteries or 1 CRV3 lithium battery, 3 volt adapter
Aug 19, 2012 | Kodak EasyShare CX4200 Digital Camera
Camera indicates low battery even for fully charged battery.
I have connected my PowerShot A2000IS that was doing the same thing for me and I discovered the following:
1) The unit works fine even down to 2.5V providing the supply source (i.e. batteries can deliver 500 mA for a short burst during startup, i.e. when the camera's lens is extended). The camera draws 300mA with screen on after the initial startup current has settled. This means that the camera may not work with batteries like normal alkaline as these don't normally supply large currents, like NI-MH and NI-Cd can.
2) I found that if I lowered the voltage down to (using my bench power supply) that the low power indicator come on at just under 2.5 Vs, BUT once it has indicated low battery, turning the voltage back up to 3V didn't remove the low battery indication.
3) Finally I connected my fully charged (with combined voltage of 2.7V) Ni-Mh rechargeables (old and well used) using wires to allow me to measure their voltage and I found that when I turned on the camera the voltage dipped to 2.3V, but come up after the lens was deployed.
Conclusion and recommendations:
a) Get some new high quality Ni-Mh cells.
b) Don't use Alkaline cells (even Duracell brand might not handle it).
c) Forget Ni-Cd as terminal voltage would be at best 2.6V which doesn
Oct 03, 2010 | Canon Powershot A2000 IS Digital Camera
Hello i put in new batteries into my camera today and it wont turn on....help! and yes i put the batteries in
Are you using the AA alkaline battery? If yes try to reverse the orientation of the battery instead of positive negative make it negative positive
Now if your using new rechargeable make sure thats the AA Ni-MH this Ni-MH is highly recommended for your camera C743
Nov 11, 2009 | Kodak EasyShare C743 Digital Camera
My camera just does not seem to hold a good battery charge. I use fully charged batteries and this also happens with Duarcell too. I am only using the camera in the "on" selection.
Some digital camera **** the life out of batteries, especially the older ones, even when off. It stores info like date and time etc. I take the batteries out when I am not using it for a while. True it is a pain resetting the time but it saves the batteries. Also go for the top line rechargebles,
Oct 30, 2009 | Kodak EasyShare C875 Digital Camera
Installed new batteries and the camera will not turn on. The camera has been sitting up for 6 mo. with no use. We used energizer lithium batteries.
Try using recomended batteries:
optional KODAK EASYSHARE Docks with 1 KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR; 2 Ni-MH batteries AA, 2 lithium batteries AA; 1 KODAK Lithium Digital Camera Battery CRV3; KODAK Ni-MH 2100mAh Battery Pack, KODAK Digital Camera Battery AA (ZR6); KODAK Alkaline Digital Camera Batteries AA; 3 volt DC input AC adapter
You can even contact Kodak direct and they will send you a free CRV3 battery to test with.
(http://graphics.kodak.com/docimaging/US/en/Landing_Page/ServiceSupportContacts/index.htm)
Oct 26, 2009 | Kodak EasyShare C653 Digital Camera
I try to turn my camera on and all it dose is click
Don't use standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
My camera it's working now!
Oct 04, 2009 | Fuji FinePix A850 Digital Camera
Can't use chargeable batteries
If your camera doesn't work with NiMH, then it's most likely that you have either one or more bad atteries, or your camera is defective. p. 6 from the user guide: "..Ni-MH batteries left unused in storage for long periods can become ?deactivated?. Also,repeatedly charging Ni-MH batteries that are only partially discharged can cause them to suffer from the ?memory effect?. Ni-MH batteries that are ?deactivated? or affected by ?memory? suffer from the problem of only providing power for a short time after being charged. To prevent this problem, discharge and recharge them several times using the camera?s ?Discharging rechargeable batteries? function. By repeating this cycle several times, the temporary reduction in performance caused by ?memory? or ?deactivation? can be remedied and the batteries can be restored to their original performance levels. ..." Sorry i cant help you more..
Dec 23, 2005 | Fuji FinePix A310 Digital Camera
Panasonic Lumix DMC-LZ7 Digital Camera Logo
90 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
