Question about Singer 5050 Mechanical Sewing Machine
Singer 5050 zipper foot
Machine came with a plastic zipper foot. I switched it out properly, but thread is knotting on bottom immediately and fabric won't move along at all. Is it because it's plastic?
  • lexierdh Feb 25, 2009
    Was told at local sewing center to really put my foot down on the peddle! He didin't try to sell new zipper foot, but also didn't mention tread tension - was at 4-5. Will change & let ya know! Thanks!
    Scholar:
  • 69 Answers
No, the foot has nothing to do with the stitch quality. Your machine is jamming up, check your upper tension. It should be set between 3-5. Make sure the dial has not changed by mistake.
Posted on Feb 12, 2009
Why can't I reverse stitch properly on Bernina 1008 when using zipper foot?
please check that the foot is attached on the drop arm in the correct position as it sounds like the foot is not down far enough to reach the base plate I have had the same problem when you have more than one foot in your spares box eric
Dec 12, 2017 | Bernina Sewing Machines
My singer 6136 bobbin keeps knotting up
Are you getting knots under the fabric when you sew? If so, that is bird nesting (thread nesting) and is commonly a top thread issue. Most often the thread is not seated fully in the tension disk or the top tension setting is off.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the tension at the midway point and then tweak it so the top and bobbin threads meet in the middle of the fabric.
Jul 20, 2017 | Singer Sewing Machines
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 22, 2016 | Singer Sewing Machines
Thread bunches up into a knotted mess on bottom. Bobbin doesn't sit flat inside the bobbin case but spins with a tilt, lower on the left and higher on the right. Bobbin touches plastic cover plate.
Usually, thread bunching under the fabric is an upper tension issue. Be sure to ALWAYS RAISE the presser foot when threading the upper thread.
With the bobbin case operating at a tilt, there is something mechanically wrong with the machine. It may be best to take it for service.
Aug 30, 2016 | Singer 4411 Heavy Duty Sewing Machine
Singer inspiration. When using zipper foot. Excess amount of thread on bottom of material, very loose and loopy. Wasting alot of thread for such a some task.
Your top threading is not right, check to make sure that your thread hasn't jumped out of a guide. Totally rethead with the presser foot up, now pull thread, it should move smoothly, next put the presser foot down, the thread should barely move. This will seat your thread in the tension discs. If, that does not work, insert a new needle.
Apr 23, 2011 | Singer Inspiration 4210 Mechanical Sewing...
Singer 5050 sewing machine threads gathering under fabric and becoming knotted. how do i fix this
Try a new needle and rethreading. Check your threading by putting the presser foot up , then pull thead, should move smoothly, now put presser foot down, now pull, it should barely move. This usually seats the thread in the tension discs.
Jan 02, 2011 | Singer 5050 Mechanical Sewing Machine
When I Try to sew all the thread on the bottom side of the fabric is long, stragglie, knotted & broken. I sew for approximately 3 seconds and then I can hear the machine grunt and then stop and I have...
It is in your top threading not in the tension discs right. Totally rethread as per your manual, now with the presser foot up, pull on the top thread, it should feed smoothly, now put the presser foot down, pull thread and it should barely move. Sometimes that seat the thread in the tension discs right. Read your manual and it will answer lots of questions for yopu. Hope that helps you.
Nov 12, 2010 | Singer 3116 Simple
I hear a knocking sound on my machine when I sew, and sometimes the thread pulls and messes up the fabric... any ideas?
The bobbin case and shuttle need to be cleaned and the machine oiled.
When you thread the machine, always have the presser foot up.
When sewing and you need to reposition the fabric, make sure the needle is down into the fabric before raising the presser foot.
When the presser foot is up, the tension opens and does not control the flow of the thread and you get a messy stitch or a jam.
Refer to page 84 of the manual for your machine. If you do not have a manual, download one free at the Singer Co. website. It is important to
follow the instructions in the manual.
Feb 24, 2010 | Singer 3116 Simple
I purchased singer bobbins to use in my singer 5050. I thread the machine and bobbin per manual instructions, but when sewing, the thread severely bunchens and knots up on the bottom side of the item I'm...
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Sep 30, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
139 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
