Question about GE Profile Harmony DPGT750GC Gas Dryer
My dryer wont work
All I get is a message that reads:  A problem has been detected with the model selection connection. call GE service
    Problem Solver:
  • 5 Answers
Possible Solution...
When you get message first try turning off. Open door spin drum one or two times. Close door. Power back on/start.
Works for our problem. Post if this helps.
Posted on Apr 12, 2009
    Guru:
  • 462 Answers
Im Just taking a stab at this.
Possible this note is in the hardware to tell you this model doesn't have the feature your trying to get it to perform. Some boards are not model number specific and are used on a "line" of equipment. The item your choosing may not be available on your model. If it is available it may be that the board is not getting a signal back to it confirming the operation and it now thinks your model doesn't have this feature. Other than these 2 items I would have to call GE (and would have to call them any way to confirm my suspicion).
Posted on Mar 13, 2009
  • Farley Redfield
    Farley Redfield Mar 13, 2009
    Please if this helps you rate me accordingly and good luck.
Replaced rollers and not getting message that door is not closed and wont work
This has happened to me before.?? To replace the rollers you most likely had to disassemble the whole dryer. Now the first thing I would check is to see if you connected the door switch back or if you connected it wrong.
Mar 06, 2015 | GE Profile Harmony DPGT750GC Gas Dryer
Ge front load error codes t01
make this test: God bless you
- 45 -
Service Test Mode
The dryer control has a service test mode that can be utilized by the service technician in order to test
critical components and to access error codes. This test mode will help the service technician to quickly
identify failed or improperly operating dryer components.
Test Mode Description
t01 Model ID Verifi
es (or sets on new board) the proper model id.
t02 Error Codes Lists up to 10 control-detected problems.
t03 Software ID
Displays the software version number and the non-
volatile memory version number.
t04 Program Non-volatile Memory Test Control computes and compares the 16-bit CRC of
the non-volatile memory with the pre-computed
version stored in the non-volatile memory.
t05 User Interface Control turns on all LEDs and the 7-segment display.
t06 Keys Continuity Verifi
es that all displays and buttons work.
t07 Outlet Thermistor Displays outlet thermistor temperature.
t08 Inlet Thermistor Displays inlet thermistor temperature.
t09 Moisture Sensor Displays voltage read from the moisture sensor.
t10 Exhaust Detection Verifi
es status of the exhaust system.
To enter the test mode: To exit the test mode:
Disconnect the power for 30 seconds.
Reconnect power and within 30 seconds of
reconnecting power:
Press signal button.
Press delay start button.
Press delay start button. (Displays t01)
1.
2.
a.
b.
c.
d.
Press the power button during the test selection
mode.
Note:
A dryer left in the test mode will exit the test
mode after a period of 30 minutes
Oct 01, 2013 | GE Dryers
I have a ge profile dryer model dpsb513eboww and the sensor dry doesn't work properly. It runs 3 minutes then shuts off. The clothes are still wet. All else works fine.
You should inside the driver and on the front or back wall will be the sensor: two metal bars that send an electric current through the clothing. When the dryer detects more current goes through, it knows the clothes are still wet and keep running. If the sensor bars are broken, disconnected, or dirty, it will read no current and think you put clothes in there that were already dry. Make sure those contacts are nice and clean. Failing that, you'll need to test the sensor circuit for voltage to see what the problem is.
Sep 19, 2009 | GE DPSB513BW Dryer
GE Select clothes dryer model DSXR453EVOWW
Open the door and remove the screws holding down the top. Then raise the top and you can get to the screws holding the front on. Get the front out and then the drum can come out so you can clean that guy out and replace that belt. How about some repair PHOTOS?
Sep 12, 2009 | GE Dryers
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Ge dryer not heating
Most likely problem is burnt out heater coils
Feb 02, 2009 | GE DVLR223 Dryers
Heat shuts off after a few minutes
Check Replace Thermostat. The Dryer Thinks Its Not Lighting Because The Thermostat Isn't Working.
The Dryer Has A Safety Mechanism So It Wont Flood Your Home With Gas. When The Thermostat Is Broken The Unit Doesn't Detect The Heat And Shuts Off The Gas.
If You Like You CV
Jan 09, 2009 | GE DBXR463EBWW Electric Dryer
Not heating also exhaust fan on dryer is not woeking screen show a problem has been detected with the model selection connection
Hello chuhunghuang
Welcome
You said, your not heating also exhaust fan on dryer is not working screen show a problem has been detected with the model selection connection
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
Let me know how it goes!
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Oct 13, 2008 | GE Dryers
Problem with "model selection connection" message on touch screen
GE Dryer - Profile Harmony
DPTGT750GC1WW and perhaps others.
If a screen comes up with "model selection connection". It could be the motherboard that has problems. Most likely not the touch screen.
Possible solution - Before calling for repair.
- First unplug the dryer for two minutes.
- Hand spin the dryer drum one or two turns while unplugged. ( in case motor was over heated)
- Make sure the dryer door is fully closed.
- Plug in (after the two minutes).
- Cross fingers
- Start.
- Let dryer cool between loads when possible.
If this fails you may need to call for repairs. I think GE has one year repair plan unless you bought extended plan. If you paid with credit card, see if it was a paid with a credit card that extends warranty another year. Perhaps look into this "card choice" for your next high end purchase.
Only if this helped...Donations_M.D.,box774,Fairfax,CA - Another try if this fails - If you dare - Unplug, you can remove about three screws holding top panel on (on rear) and tilt top forward. Check to see that all connectors are seating well on motherboard. (White box in center). Hope see works for you!
Parts:
WE04X10105 Display
WE04X10107 Power/PCB ASM-Main (motherboard)
WE04X10127 Power filter (circ) EMC
Aug 25, 2008 | GE DPGT750GC Gas Dryer
GE Profile Harmony dryer error message
Oct 29, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750GC Gas Dryer Logo
192 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
