Windows problem I have a program running in dos mode, I already set the config.nt but still there is an error. The error is.. 16 bit MS-DOS Subsystem... H:\ip\MRK1.EXE The NTVDM CPU has encountered an illegal instruction. CS:20d9 IP:c411 OP:fe268907 5e Choose 'Close' to terminate the application. Please i need help for my program to run and work properly. Thanks & Godspeed
  • Bob
    Bob May 11, 2010
    Watt program do u want 2 run???
    Problem Solver:
  • 8 Answers
Try this.
Right Click on your DOS program EXE file. Then go to properties and go to Compatibilty TAB. Click in Check Box for Compatibitlity mode and select WINDOWS 95.
Posted on Feb 10, 2009
Windows system32 autoexec.nt fail to operate
Win XP SP2: System not suitable for running MS-DOS. ... This file is part of the Windows 16-bit subsystem and usually lives in the system32 folder. ... P.S. If this doesn't work check out the Microsoft web page for additional fixes. ... Computer Tips Daily - Run your Windows PC like a pro! No matter what your skill ...
Jul 16, 2010 | Microsoft Windows XP Professional
Turbo c not working....16 bit ms-dos subsystem error
There have been several changes in the way programs work. Windows xp does not
allow direct access to hardware resources to protect system integrity.
However you can try a few things
Generaly speaking this error shows up when a program tries to use a file from an incompatible version of windows.
Alternatively login in safemode and use. it ll work fine. rate this!!
Aug 15, 2009 | Borland Turbo C++ 4.5 Full Version for PC
I recently had a HD crash and have replaced it with another HD using the same Windows XP OS. While trying to reload programs that were on the old HD to the replacement, some of the programs get this error...
I always receive a "C:\WINDOWS\SYSTEM32\AUTOEXEC.NT" error message.
“C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-
DOS and Microsoft Windows applications. Choose ‘Close’ to terminate the application.”
This error message is not caused by the installation CD-ROM, but rather by the
“Autoexec.nt” system file. Windows is unable to find this file when launching the
installation CD-ROM, the file most likely having been deleted by another application.
To resolve this problem, proceed as follows:
1. Go to “C:\Windows\repair” and find the file “Autoexec.nt”.
2.Copy this file to “C:\Windows\system32”.
3.Right-click the file “Autoexec.nt” that you have just copied, and select
4.Tick the “Read-only” box and then click “OK”.
Aug 06, 2009 | Microsoft Windows XP Professional SP2 Full...
16 bit MS-Dos Subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction cs:0000lp:flboop:of00640352 choose close to terminate the application
I too have a problem on my PC,when running the Turbo C programThe error message is:
16 bit MS Dos Sub system
turbo c++ IDE the NTVDM has encountered an illegal instruction.
At last i found the solution, and it is simple.
After installing your turboC follow the steps..
1) go to TC directory and open BIN.
2)In "BIN" folder you can find "tc.exe". Right click on "tc.exe" and click properties (and make sure that do not click on shortcut of TC.exe).
3)In properties there should be a tab called "screen", In that you will find "usage" option. There.. select "window" option instead of "full screen".
4) Then click "OK".
5) Now click "TC.exe".
6) It will open in window mode, if you want you can change full screen mode by pressing "ALT + Enter".
Thanks & Regards
Shravan reddy Konnela.
Jun 02, 2009 | Microsoft Windows XP Professional with...
Windows problem
I would say the easiest thing to do with legacy programs is to run a virtualized version of an older windows OS within Vista.
Visit VMWare Server to download their free product that can run in Vista. You can then "find" a windows 98 cd-rom image to install with. It is fairly easy, but there will be a little work getting Win98 running.
This is probably the best way since you don't have to worry about compatibility with Vista, and also if the legacy app crashes it only crashes your VM and not your whole system.
If you would like some more in-depth discussion about virtualization, just email me.
Feb 10, 2009 | Microsoft Windows Vista Ultimate Edition
When i am trying to use c++ on my system it is giving me message the NTVDM cpu has encountered an illegal operation
Here is an explanation of what NTVDM is: The NT Virtual DOS Machine (a.k.a WOW, or Windows on Windows), is a Win16 subsystem that runs under Windows NT, which allows 16-bit applications to run as if they were being executed on a DOS machine, with that machine's multitasking and segmented memory model. Because the system is multitasked 16-bit DOS and Windows applications cannot crash NT. However, 16-bit apps within a Win16 subsystem run the exact same way as they do on a DOS/Win 3.x machine; therefore, 16-bit apps within the subsystem can crash one another, or the subsystem. To prevent this, you can launch multiple WOW subsystems as long as your program does not communicate using shared memory. Windows NT will not allow NTVDM to execute instructions that try to directly manipulate hardware or memory locations. As a result, some DOS and Windows 3.x applications (such as games) may not run under Windows NT.
Feb 02, 2009 | Computers & Internet
Program Vista Home Error Message: config.nt The system file is not suitable for running MS-DOS and windows applications.
Hi VincB49,
Without getting too technical what you have is trying to run a 16-bit program in an 32-bit environment. When a 16-bit trys to run in windows 2000 it runs in windows nt dos environment, anyway, try this: Click Start>control panel>system>Advanced- click on "Environment Varialbles"> In the user name for User_Name list click "TMP" and click edit> In the Variables Value box type:
c:\winnt\temp and click OK three times, close control panel. I hope this helps you, if not, hit me back, we have other options i.e. pathway applications.
Thanks for using
Sincerely, cyyyd7
Oct 08, 2008 | Computers & Internet
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Related Pages:
Safe Mode
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
