Question about Maytag 24 in. MDB6100A Built-in Dishwasher
Dishwasher door leak
I replaced the soap dispenser door latch grommet on my Maytag model # DWU9202AAE because it was leaking badly from the bottom right corner of the door. Now it is shooting water out of the upper right corner of the door. If we hold pressure on the door it does not leak. Is this a door seal problem or a door latch problem? Thanks for a response!
    Brigadier General:
  • 8,619 Answers
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Also,The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
A Fixya rating would be appreciated if you have found this solution Helpful.
Posted on Feb 10, 2009
Leak at bottom of door
see this causes and use the common sense. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Sep 19, 2012 | Maytag Dishwashers
Tub leaks, with a partially filled tub (2.5 inches measured from the lowest point over the pump assembly.) Promblem occured after the washer was idle for 3 weeks. Have just replaced the main water inlet...
I am assuming leaking when it is running, not sitting idle. Leaking from the door? Fill and run unit for 1 minute with no detergent. Open door. Are suds present? Suds turn into water when they drop to the floor. Suds can flow over the lip of the tub and drip to the floor. Oversudsing, Sometimes old detergent breakdown. Rinse aid dispenser leaking will cause oversudsing. Combination of all in one products will cause many problems. If suds are present after running unit a minute, pour a cup of cooking oil in unit. Run and fill it a few times until suds are gone. Possible most common cause is dispenser latch grommet.
Oct 15, 2010 | Maytag MDB7100AWB Dishwasher
I have a leak coming from bottem of door only on rinse cycle
If this is a MayTag check the seal around the soap dispenser latch. That seal may have a small crack. You can also take the inside cover of the door off. Then you can see the water marks to see where it is coming from. Mine was the soap latch seal. Cheap fix
Sep 08, 2010 | Dishwashers
Soap dispenser door pops open
Try cleaning the compartment. If the latching is not OK, it could be a latch problem, or alignment, or total dispenser. Contact service provider for assistance.
May 26, 2010 | Maytag MDC4650AW Built-in Dishwasher
There is water leaking out the bottom of the door. Maytag Model #DWU8860AAX
I had the same issue. I replaced the rubber grommet/seal on the soap dispensing door latch and the problem was solved.
Apr 07, 2010 | Maytag Dishwashers
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Soap dispenser door doesn't open for the second cycle.
Hi, the soap dispenser has a motor / solenoid which controls the latch that opens the door. This has gone bad and needs to be replaced. It is located inside the dishwasher door panel. Remove the screws around the inside of the door to gain access to the solenoid. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 18, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
May 01, 2009 | Dishwashers
Leaking dishwasher
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 27, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Jun 05, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag 24 in. MDB6100A Built-in Dishwasher Logo
584 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
