Question about Braun Tassimo Espresso Machine/Coffee Maker
Braun Tassimo machine problem... water doesn't come out into cup.
The lights work... makes noise...but no water comes out into cup.
  • Anonymous Feb 13, 2009
    New machine. Did the plastic disc cleaner routine, but even during that NO WATER EVER CAME OUT TO THE CUP! I'm not happy.
  • killer36 Nov 23, 2009
    The water doesn't come out in the cup
SOURCE: braun tassimo no lights
Same thing happened to me this morning.
Posted on Feb 14, 2008
SOURCE: Braun Tassimo Type 3107
I found that most problems around the tassimo relate to the peircing mechanism being clean and properly in place (it moves sometimes when you open the lid), or that the "window" that reads the barcode needs to be kept clean. When i've gotten all lights blinking or going right to manual, I have found cleaning the window seems to fix the problem more often than not.
hope that helps
Posted on Mar 05, 2008
SOURCE: lights keep flashing on my tassimo machine
I know that if the water reservoir is empty or the reservoir isn't properly attached all the lights flash until I correct it. I think the first time I powered on my unit all the lights flashed as well but went away after I put a coffee disc in.
Posted on Dec 30, 2008
SOURCE: Tassimo machine leaking water underneath
I'm having the same problem with my machine. I rang the Tassimo careline and they told me to descale the machine but, so far, this has only made matters worse. I'm now going to take it back to where I got it from because it's still within its warranty.
Posted on Nov 20, 2009
  • 5 Answers
SOURCE: All the lights are flashing on my Braun Tassimo
Several possibilities: (1) No water in tank.
(2) Tank not inserted properly. Try removing tank and then replacing it, making sure that the hook-tab at the back of the tassimo body engages the matching slot at the front of the tank.
(3) Tank not seated properly. Try pressing down on the tank and twisting left or right. If this stops the blinking and allows your drink to brew, at least you know where the problem is. If you have to do this all the time, consider exchanging the unit.
(4) The lights will all also blink if there is residue (coffee, milk, etc) on the bar code reader window. The residue is usually plainly visible. The bar code reader window is a horizontal rectangel directly under where the bar code of the T-Disc sits in the Tassimo. To fix this, just wipe the window clean (no need to scrub), close the lid again and check for blinking.
Posted on Dec 24, 2009
How to repair water leak from tassimo base?
The water tank at the rear must make a proper seal. Make sure it is clean and lubricate with Vaseline. The cup tray also catches drips so remove it and empty any water into the sink.
Nov 04, 2014 | Braun Tassimo Espresso Machine/Coffee...
Problem with Braun Tassimo Espresso Machine/Coffee Maker: all the lights are flashing and does not working. bar code reader are clean, somehow the water is not going throw on the machine
the unit needs to be descaled. order the clean tablets from Tassimo and follow the steps as printed in your owners manual as an alternative you can use any good quality espresso cleaner but DO NOT USE VINEGAR as this could damage the boiler...
May 29, 2014 | Braun Tassimo Espresso Machine/Coffee...
My tassimo coffee comes out watery
Make sure you push the lid down all the way before putting the clamp down on the front.
I've noticed that the back of the lid on my vivy (t12) can get stuck up (even with the clamp down) causing the water jet to not be inserted all the way - which produced very weak coffee.
May 14, 2012 | Braun Tassimo Coffee Maker
How do you operate the Braun Tassimo Kenco coffee machine
fill tank with clean water ,turn power on , insert the T disk beverage of your choice in the disk head and close cover , the green light should be on , place appropriate cup under spout , press the button , and happy brewing ..
Jan 10, 2011 | Braun Tassimo Espresso Machine/Coffee...
Hi,when my tassimo finishes filling the cup,it
For a Braun machine, unfortunately this is quite normal as it's part of the "purge" once it has finished brewing.
The new Bosch machines do not do this and finish their cycle with a steam purge instead.
Mar 25, 2010 | Braun Tassimo Espresso Machine/Coffee...
Water not going into cup
hello can't seen to get the water to come out in the cup
Nov 23, 2009 | Braun Tassimo Espresso Machine/Coffee...
The sensor on the water tank will not hold in position making all the lights flash, not making coffee!!
My Tassimo was doing the same thing. Defective tank sensor, I taped a small magnet on the back just above the power switch next to the water tank to trick the machine into thinking there is water in the tank. Just make sure there is water in the tank, as the sensor is now fooled on.
Oct 26, 2009 | Braun Tassimo Espresso Machine/Coffee...
hope that helps
Jan 19, 2008 | Braun Tassimo Espresso Machine/Coffee...
Leaky Tassemo coffee maker
i think it's supposed to do that. the cup at the base is supposed to be catching all the water that the tassimo is 'leaking'. it should be dumped after every cup of tea/coffee. if you have taller cups, and do not use the cup base that comes with the machine in order to fit the taller cups under where the tea/coffee comes out, then you are right. it seems like it's 'leaking' because it is. there should be enough room in the base for one cup, but then it can also be removed so as to dump the excess water out after the cup is made. hope this helps!
Feb 03, 2007 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
417 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
