Question about Datalogic QuickScan® QS6000 Plus (6660120010030201) Handheld Barcode Scanner
PSC QuickScan 6000 will not scan when trigger is pulled.
I have a PSC QuickScan 6000 scanner that was purchased used. It did not included a cable so I found Part no 8-0424-03 (PS/2 keyboard wedge) to connect it to a PC.
When the trigger is pulled nothing is happens.
I have found that the scanner will work for about 5 seconds when I hit any key on the keyboard but it does not seem to accept or read the barcode. I have tried the reset barcode and going though the setup to create a base program for it, but the scanner never gives me the blinking green light to tell me it is in program mode.
Any ideas?
  • 25 Answers
SOURCE: psc quickscan 6000plus
That scanner has been constrained to accept a digit length of 12 or less .. probably IPC codes which are 12 digits in length.
Do you know the symbology of the barcode you are scanning? (i.e. UPC, EAN, I2of5, C3of9 etc).
Posted on Jan 05, 2008
  • 58 Answers
SOURCE: PSC 6000 Plus not scanning
There are a few questions:
What kind of cable do you use?
USB, SERIAL, PS2
What kind of computer?
Normal computer or Laptop?
Then...
When you recieve the scanner like new you always have to program it.
First you do
Reset to factory defaults.... Never do this with working scanners
then
you have to program it.
First the Connection type
and then if needed a computer type.
After that you usually have to scan a suffix.
This means when you scan a barcode it needs to do something after.
normally it doesn't give Enter after you scan.
That is what the suffix is for.
and then you scan additional symbologies to scan
Like Code 39, UPC A etc. etc.
It needs to be programmed with the manual you recieved.
if you don't have it you can download here.
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
go down in the list to quickscan 6000
and programming manual.
please don't print all the pages. only what you need.
If you need more help i will hear it.
good luck.
Posted on Jan 09, 2009
SOURCE: PSC QuickScan GP5385-104342 RS-232 / DOESN'T WORK!
I think the problem you all are having is that this model of scanner requires a "decoder" to work correctly. It is another box which goes in-line between the scanner and the RS-232 port or ps/2 port of the pc. I'm not 100% positive about this, but I am pretty sure this is the problem. You need to look on e-bay for a psc barcode decoder.
Posted on Apr 02, 2009
POSresource
  • 3 Answers
SOURCE: driver for psc quickscan 6000 plus scanner
Hi!
Your PSC QuickScan 6000 should not require any drivers. If this unit plugs into your keyboard port, you should be able to scan a barcode and view the data results in a text editor, such as Notepad. This technology is called "Keyboard Wedge" and consists of a cable with three ends. The first is plugged into your hand-held scanner. The second and third are rather close together and are at the end of the cable. This cable is called a "Y" cable because it resembles the uppercase letter "Y". The bottom part of the "Y" plugs into your scanner, while the first upper part plugs into your computer. The second upper part of the "Y" should be a female plug, allowing you to plug your keyboard into it.
Now if you are using a Keyboard Wedge scanner with a USB keyboard, the female end of the "Y" cable would not have anything plugged into. Unfortunately, the scanner will most likely not operate properly if no keyboard is attached to the keyboard port.
I suspect you may have an RS232 or "serial" scanner. Does your scanner have a power supply that plugs into a standard wall outlet? If so, you may have a serial interface scanner. You could use a program called Com to Keyboard, which would convert RS232 or "serial" data into keyboard data. This is a free program, however, it is a resource hog and may slow your system down.
Feel free to call if you have any additional questions.
Good Luck & I Hope this helps!
-Dave
Dave Krause
Founder, Bluesky America's GetOpen.com
720.771.5194 Direct 888.7.GETOPEN Toll-Free
Posted on Apr 04, 2009
  • 144 Answers
SOURCE: quickscan 6000 will read not read programming barcodes
usually there is a laminated like square piece of paper that gives you 4 options to scan and one of them is auto
Posted on Jun 06, 2009
QuickScan 6000 Plus cant get it to work with windows 7. If i use ps2 port, the red scanninglight dissapears after one scan. If I use an converter ps2 --> usb and plug it in usb port, it seems to work...
try the other usb ports. sometimes that works. also make sure that your other usb devices are off if possible. If you are using a usb keyboard try using a ps/2 keyboard. If you have an open usb port in the front try using that instead. I have seen this many times. Good luck.
Sep 22, 2011 | Datalogic QuickScan QS6000 Plus Bar Code...
Having trouble programming the scanner..I have the product guide but I am not sure of to set the scanner too..........
I recommend that you first come up with a question to ask. Then go to the website of the manufacturer of the scanner. Search support for answers to your question. If you don't find them use the phone number or email address on the website to contact them.
Oct 12, 2010 | PSC QuickScan 6000 Plus Handheld Barcode...
QuickScan 6000 hardware connectivity.
A ps2 / USB converter costs a few quid - worth a try?
Sep 17, 2009 | PSC QuickScan 6000 Handheld
I buy the one but there is no cd driver can it go without driver
hi :
Aug 13, 2009 | PSC QuickScan 6000 Plus Handheld Barcode...
Quickscan 6000 will read not read programming barcodes
Jun 06, 2009 | PSC QuickScan 6000 Plus Handheld
Driver for psc quickscan 6000 plus scanner
Hi!
-Dave
Dave Krause
Mar 31, 2009 | PSC QuickScan 6000 Plus Handheld Barcode...
USB, SERIAL, PS2
Then...
First you do
then
good luck.
Jan 09, 2009 | Datalogic QuickScan® QS6000 Plus...
I need an owners manual
You can download a manual (06656 User's Guide/Programming Guide) at the DataLogic site. They bought PSC in 2005.
http://www.scanning.datalogic.com/sitefiles/result.aspx?m=Product%20Manual&p=53XX&l=english&d=1&t=search&s=NonCurrent
If your cables are connected between your keyboard and PC, be sure to set up the correct Keyboard Wedge Parameters, beginning on Page 34, to allow connectivity.
I'd start by scannig barcodes "CE" and "ZA" to reset to default wedge values. If that doesn't work, I'd procede to sc an "CF" for PC=AT,PS/2.
Pages 36 & 37 address the Caps Lock issue, where the scanned value is in the wrong upper or lower case.
Have a nice day,
Label_Guy
Jun 12, 2008 | PSC Quickscan GP5385 Handheld
Dec 15, 2006 | PSC Quickscan GP5385 Handheld
Datalogic QuickScan® QS6000 Plus (6660120010030201) Handheld Barcode Scanner Logo
252 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
