Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Compressor builds pressure, but does not shut off
My compressor will operate just fine, I just have to babysit it and shut it down when it gets fully pressurized, if not, the pressure will go through the roof. The auto shut-off and start up are not working.
  • twistedgrip Feb 10, 2009
    I'm not sure how and where to adjust that.
  • robert sanko May 11, 2010
    When you say the auto switch isn't working have you tried adjusting the cut-in/cut-out inside of the controller?
    President:
  • Hitachi Master
  • 1,388 Answers
Hitachi builds a very nice compressor, however suffers from the same problem that all brands will eventually encounter. Failure of the pressure switch. The pressure switch is a very hard working component of the unit. Depending on use, the pressure switch may cycle from as little as two or three cycles a day to as many as dozens per hour. The pressure switch has springs, contacts and unloader features that eventually wear out. The two most common failures are the contacts and the rubber diaphragm that acts against the springs to shut the unit down. Sometimes the screws securing the base of the switch the inlet port come loose and cause the problem that you are having. (The rubber diaphragm is between the base inlet port and the switch) Simple test is to spray soapy water around base of switch to check for leaks. Replace the switch as necessary with a SquareD brand available at www.grainger.com instead of factory unit to save money and increase life. You may have to make simple modifications however the money saved will be worth it. Choose a pressure switch with cut-off range between 120-139 psi. The higher the cutout switch setting you choose the shorter lifespan for your compressor. Your compressor works harder and gets hotter when achieving higher pressures. Try to use either no extension or shortest cord possible to max life of unit and compressor oil instead of motor oil to prevent carbon deposits. Good luck and email if you have questions about your Hitachi.
Posted on Feb 11, 2009
We relocated our Sullair 3700 about 30m from air receiver, due to excess dust. Now the compressor never stops running, trips on high pressure yet the receiver is not achieving the pressure required
would say dust has done something to do with it
before you had time to move it
will need the compressor serviced
first ..in simple words
to replace the compressor pressure shut off /turn on valve
that should fix the pressure trip build up limit problem
and maybe a partial strip down to clean out the casing
if dust build up is noted
Oct 14, 2016 | Sullair 350 Air Compressor; Sullair...
My compressor runs all the time. what can i do to make it build up pressure the shut down
I believe its called a pressure sensor Had the same problem probably best to take it to a professional
Mar 28, 2013 | Stanley Bostitch 2hp 6gal Air Compressor...
Air compressor want build over 40LBS air!
It sounds to me like you have a bad pressure switch. When these go bad, it takes less pressure to close or open the contacts to shut the motor down. You can get a replacement from any Ace Hardware. It will come with basic install instructions. Just follow those and you should be fine.
Aug 03, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Craftsman air compressor spitting sparks behind fan
If it is an oil type make sure it has oil. If it is the dry type you need a new compressor.
Jul 29, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Compressor will not build up over 25 PSI
your max pressure switch is faulty, and shutting off the power early. replace switch, check owners manual for location(should be near power wires)
Jun 14, 2009 | Hitachi Air Tools & Compressors
Compressor is having trouble sustaining pressure. No leaks.
it has to be leaking some where check Liquid soap check the intake filter.
Jun 11, 2009 | Square D 9013FHG14J52M1X Air Compressor...
When shutting down the compressor, oil comes out intake filter
hi there,
well,if your air compressor was shut off this due to pressure switch w/c auto switch off your compressor,the pressure switch acquired already the cut off pressure.if the pressure goes down the cut in set up reached it will start your compressor
to run.
regarding oil spillage when shutting down check the oil level on the sight glass of crankcase
a red line indicate oil should not exceed on that level line,if the oil exceed try to drain oil.,on the side bottom of engine there is a drain plug.until on limit level .,besure that machine is shut off/breaker is off.have a nice day don't forget to rate me,thank's
Apr 28, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Gas air compressor shuts down
IS IT BUILDING TO THE UNLOAD PRESSURE AND THEN STALLING OR JUST SHUTTING DOWN ANYTIME. IS THE UNIT SITTING AT AN ANGLE?
DOES IT WORK FINE WITH THE LOW OIL SWITCH UNPLUGGED? UNPLUG SWITCH AND LEAVE IT UNPLUGGED FOREVER.THEY'RE ALL P.O.S.
Feb 14, 2009 | Hitachi EC2510E 5.5hp Gas Air Compressor
Compressor starts then shuts down like head pressure building to high
Make sure that your condenser fan is working. If your unit is water cooled make sure you have water flow.
Nov 05, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
2,742 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
