Question about Kenmore Sewing Machines
Error on screen
SCREEN SHOWS ER AND WILL NOT SEW
  • 1 more comment
  • gpartida47 Feb 10, 2009
    need to solve problem with my kenmore sewing machine model# 385-1950180
    tried everything advised was to take to sears but no way !
  • gpartida47 Feb 11, 2009
    I HAVE HAD TWO REPLYS NOTHING THAT WORKS NO SOLUTION TO MY PROBLEM!
    Sergeant:
  • 250 Answers
Often when your needle starts to shudder, the thread is caught on something somewhere along the sewing path. Turn off your machine, change your needle, take all of the thread out of the machine and rethread it. Then remove your bobbin to make sure that there is nothing stuck in the bobbin case, or in the area where you insert your bobbin into the machine. Look around the sewing area to see if something looks out of place.After you insert a new needle and rethreaded your machine, and before you turn the machine back one, try using the wheel to make a few stitches manually. Watch your sewing thread to make sure it is feeding evenly. If the needle does not move up and down correctly, or if you hear a grinding or bumping sound, you probably need to take the machine to be repaired. Otherwise, turn your machine back on. If the error message is gone, try sewing slowly for several inches - if all seems well, increase the speed a little at a time. If anything seems off to you while you sew - stop sewing immediately and look very carefully to see if you can find a problem.
An electronically controlled sewing machine has a liquid crystal display as well as a needle bar rocking mechanism for driving a needle bar to which a needle is attached, a thread take-up lever driving mechanism, a needle thread catcher and so on. One of three kinds of animation information stored in a message memory of the sewing machine is selectively read in, and is presented on the display according to an error message display control or a guide message display control when any error/guide message appears on the display. Therefore, even when an operator sees the display with less attention, the presented animation information attracts the operator to the display when any error/guide message appears on the display, resulting in that the operator will not miss the displayed important error/guide message.
Posted on Feb 10, 2009
    President:
  • 2,110 Answers
You may have a problem with the type of needle, if you are using a singer needle, they usually do not work well in other machines. I would suggest a Smetz needle.
with the thread bunching up, it is possible that the tension is not right, but more likely the machine is not threaded properly.
here are some sites that may help you
http://www.sewalot.com/tension_adjustments.htm
http://www.gwsms.com/didyouknow.htm
http://www.sewusa.com/Sewing_Machine_Manuals/kenmore_Sewing_Machines_158.htm
http://www.sewwhat.net/millie/H.sm_manualsCOPIES.htm
  • 4,472 Answers
How long have you owned the machine? Also what is the exact error being shown? is it only ER? once I have more information I will be able to assist you further. Please accept and rate my solution or wait before requesting more assistance.
Thanks,
Lee
    Sergeant:
  • 326 Answers
Its the internal circuit short problem.also can be loose connection problem in the machine check out all the connections properly.
  • 360 Answers
Will need the model number and what the machine was doing when the error occurred to properly diagnose, please post.
try this, turn machine off, unplug machine for 5 mins plug machine in and turn on.
clarkco
  • 679 Answers
Please tell me the model number of the machine.
  • rockfixya
    rockfixya Feb 10, 2009
    you may have a problem with the type of needle, if you are using a singer needle, they usually do not work well in other machines. I would suggest a Smetz needle.
    http://www.sewalot.com/tension_adjustmen...
    http://www.sewusa.com/Sewing_Machine_Man...
    http://www.sewwhat.net/millie/H.sm_manua...
  • rockfixya
    download repair manual from>>
    Thanks
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
I have a singer curvy 8780 I can't sew at all as soon as the needle goes down the machine makes one long beep and the display screen goes blank. The display is still lit but shows nothing. Help
Sounds like your machine is experiencing a failure of a computer component. Suggest service or, if cost prohibitive, looking for a new machine.
Nov 14, 2015 | Singer Sewing Machines
No digital display on the screen and will not sew...was sewing along very nicely, changed thread and now have this problem?
It may be something you can fix if you can find a dealer who will tell you what the code means and how to re-set it. The backward and forward C are not a normal code. Does your book have a section for error codes under "trouble shooting?"
Dec 30, 2014 | Singer Sewing Machines
Will not sew anything over 5mm with built in stitches.
Take it back and ask 'em to fix it right this time.
May 19, 2014 | Bernina Artista 180
My Elna 6005 turns on, but the mode buttons don't work at all. What can I do to fix it?
Check the "Twin Needle Button" It will interfere with decorative stitches.
Jan 10, 2013 | Elna Heirloom Edition 6005
Screen won't show numbers on quantum 9910
it sounds like the computer part of the machine needs to be check at a sewing machine repair shop
Jan 20, 2012 | Singer Quantum 9910 Computerized Sewing...
I have a Janome sewing machine and I have forgotten how to move the needle so I can sew to the right... how do I move it ??
Press the Adjust key at the bottom of your screen. Press the plus key to move your needle to the right and the minus key to move your needle to the left. Use the first + and - keys that shows the needle.
Oct 19, 2009 | Janome Sewing Machines
ER message on Kenmore Sensor Sew 70
the halifax switch under the top cover needs to be adjusted
Nov 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
41 people viewed this question
Top Kenmore Sewing Machines Experts
Bargain Box
Bargain Box
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
