Question about D-Link DP 301U (DP-301U) Print Server
HP LJ P1008 can be used as network printer ?
HP LJ P1008 can be used as network printer using D-Link DP-301U Print Server?
  • 30 Answers
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Posted on May 22, 2009
    I have installed the DP-301U print server on my home network to print to an HP Laserjet 4050. When setting up the print server per instruction, I set my computer IP address to a static IP address. The...
    Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
    You cant have the same IP address on any 2 items on your network.
    Oct 20, 2009 | D-Link DP 301U (DP-301U) Print Server
    Printing Problem
    i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
    1. install printer locally via usb and test.
    2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
    3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
    4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
    5. test print. should work fine.
    cheers!!
    Aug 11, 2009 | D-Link DP 301U (DP-301U) Print Server
    Using HP Laserjet P1006. Is it compatible with DP-301U
    Yes. I just got mine working last night. Key is to enable print services for windows through the control panel. Without that LPR printing does not work.
    Jun 08, 2009 | D-Link DP 301U (DP-301U) Print Server
    USB printer HP 1020 Plus in DP-301U
    Did you try using LPR mode instead? I find it works more relyable with any print server. SMB (windows network mode) is ****. I have had simalar problems with another printserver.
    Apr 17, 2009 | D-Link DP-301U (790069251979) Print Server
    Print server DL-301U setting
    I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1006 is NOT in the list):
    Apr 14, 2009 | D-Link DP 301U (DP-301U) Print Server
    Communication between PrintServer DP-301U and HP LaserJet 1020
    Trying turning your printer off and then back on. It happens sometimes that the print server looses the printer.
    Alex
    www.CAS411.com
    Feb 13, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
    DP301U COMPATIBILITY
    I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
    LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
    Feb 09, 2009 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP-301U Problem
    It should be fine as long as it is in the range that the router can recognize and that it doesn't conflict with another IP address used on another device. Usually on the networks I design I keep the printers on higher IP address so that they can be managed on a certain range.
    Is this the wireless print server?
    What specifically do you mean by PJL printer block?
    Aug 04, 2008 | D-Link DP 301U (DP-301U) Print Server
    DP-301U Printer Compatibility
    Yes it will work. In my office i am using 1160 series printer .
    Apr 11, 2008 | D-Link DP 301U (DP-301U) Print Server
    Scanner
    This is not a solution just a possible fly in the ointment. I have often found that scanners only work when attached directly to a computer. Scanning over the network is not a solution I have found. You can always share out the printer from the attached pc.
    Jan 09, 2008 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U (DP-301U) Print Server Logo
    3,060 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
