Question about Sony KP-65WV700 65" Rear Projection HDTV
Replacing bulbs for kc65wv700 sony
I need to know how to do this... My hubby is not here no more and techs said I could not get the parts any longer. WELL I found it and need to know if this is something i can do. Repair companies want 400-500 to do it. I can not afford that. I HAVE TO FRONT COVERS OFF already adjusted but the blue bulb is out. HELP anyone Please
Single mom
    Scholar:
  • 150 Answers
Hi, sorry. but this is not something you can do, after replacing tube there is a large alignment procedure that must be done as well.
total time for a seasoned tech is 4-5 hours if everything goes well, my advice is to call every shop around you for the best deal, hope this helps, video-tek
Posted on Feb 10, 2009
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Instructions for replacing the bulbs
The "bulbs" for a KP-51WS500 are 3 picture tubes--they are no longer available from Sony. The only way to get one is remove it and send it out for REBUILD--very expensive and usually not worth doing..
All these sets had bad tubes--a lot of them had the wrong tubes installed when they were sold---I know as I replaced dozens of them when these sets were still under Sony warranty--
Tell me what problem you have and I will try to help you---the most common problem is the screen will go bright blue, red , green and or set will shut off.
Sometimes you will get a blue cast (blue tube seems to be the one that goes most) to the picture with faint curved trace lines.
If you have this kind of trouble there is something you can do to try to correct it---it requires no replacement of parts--only some adjustments
If this information has helped you rate this solution as I do this here for free.
I am here to help people.
SD TECH
Nov 05, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-65WS500: Shuts off when hot?
There is no "bulb" in your tv , you have a CRT projection tv, need to have power supply checked as well as the convergence board. Have a trained tech do it, this is not for beginners. Julio milleniumtvsvc@gmail.com
Jul 22, 2009 | Televison & Video
Problem with Sony CCD TRV138 camcorder
Symptom shows bad CCD IMAGER in camera and requires replacement. (IC951 on CD-465 board, mounted at end of lens mechanism).
Nice to know that you are tech person so buy CCD IMAGER from any part store under following part number..
A-7013-219-A CCD BLOCK ASSY (CCD IMAGER) (TRV138/TRV338)
Good luck.
Mar 15, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Sony kp-57hw40 57in red bulb burnt out
Afraid the part number 8-733-648-15 shows as no longer avalible on all the suppliers I searched, but mabe some shop out there might have one, average cost $250+$350.00
Oct 22, 2008 | Sony KP-57HW40 57" Rear Projection...
Blowing Bulbs in the 50WE655
must replace with original bulb by sony,others don't last,ask for a refund from the lti company or a replacement if they say different at no cost to you.
Sep 10, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Power light on, no bulbs lit
arching hi voltage ,damaged Hi voltage block , and 80 % deflection board problem, you need a technician to check at home. because after the part it, need ,were replaced still need alignments, depending on the tech or shop could be no less than 300.00 if you have the brave to try , and can have some tools it gonna take time but you can fix it
Jun 10, 2007 | Sony KP-53S75 53" Rear Projection...
KV27FS100 a board
Whole boards for this model would only be something a Tech might have in his boneyard. I'll check tomorrow and see what I can find.. Email me privately. premtech@willapabay.org Bill
Jun 02, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KP-65WV700 65" Rear Projection HDTV Logo
132 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
