Question about Orion Cobalt 2105 XP Car Audio Amplifier
Key stuck in the ignition.
Key locked in the ignition, won't come out.
  • 323 Answers
Try putting your car in neutral then back in park. Most of the time the key won't come out if the gear shift doesn't lock in park. Try lifting your steering wheel. Use a pair of pliers and wiggle gently on the back of the key.. Maybe it'll disengage.
Posted on Feb 11, 2009
Ignition of ford edge will not turn completely is stuck in position 2 in auxillary power
My ignition key will not turn to off. I can remove the key, but it stays in the accessory mode. What's the fix?
My ignition key will not turn to off can remove the key but it stays in...
Ignition key is stuck and does not turn Inspection Service & Cost
Ignition key is stuck and does not turn Inspection Service Cost...
Ignition key won turn
Aug 24, 2016 | 2012 Ford Edge
I have my key stuck in the ignition of my 2007 Buick Lacross. How do I get it out.
Sounds like the battery or the ignition switch has gone bad. The key won' release until the shift lock solenoid is energized to allow the key to turn all the way back.
Feb 23, 2015 | 2007 Buick LaCrosse CXL Sedan
Dome light and key in ignition tone won't quit.
Yes, I would lean toward a stuck drivers door latch. Your door open switch is located in the latch itself and the ding is a reminder your key is in the ignition so you don't lock them in the vehicle when you lock the door. even though your door is shut, the truck still thinks it is open. sometimes spraying the latch with some WD-40 will get it freed up and working again, but a new latch might be in your future.
Apr 21, 2013 | 1997 GMC Jimmy
Key won't come out of ignition on 1999 vw jetta
It can be faulty ignition lock cylinder. I suggest to wiggle the steering wheel a bit and see if the key gets released out. If that is not helping then first turn steering wheel to right and try removing the key, or next turn steering wheel to left and see if you can remove the key.
Spray wd-40 in the ignition key hole and let it remain there for few minutes, after that once again try to remove the key and see if that helps.
But if that is not helping then ignition lock cylinder has to be removed out and key has to be manually removed.
For more troubleshooting on these types of issues, I suggest you to refer the help links mentioned below. Its the accurate solutions mentioned in it. That will help you to narrow the problem: -----
Click the link below: ------
1999 Toyota Camry: Key Will Not Come Out Of Ignition?
2001 Toyota Tacoma: Ignition Locked?
Ignition Switch Will Not Turn Off?
Car will not turn the ignition to start?
Ignition Key OFF but engine still running?
Chevrolet Malibu: Key Stuck in ON position?
2012 Dodge Ram: Ignition Key will not release?
Ignition locked up on Mercury Villager?
Key won't turn in the ignition on Toyota land cruiser?
How to remove ignition switch on VW Car models?
How to Replace Ignition Switch on Chevrolet Caprice Classic?
1995 Ford Taurus: Ignition switch not turning OFF?
Ignition Problem Troubleshooting
These will help.
Feb 15, 2013 | 1999 Volkswagen Jetta
My steering wheel is locked and the key is stuck in the ignition .The car won't start
Check to make sure the gear select lever is in the park position. Try starting the vehicle with the gear select in neutral.
Jan 14, 2013 | Megatronix - PASSLOCK-SL2 - GM Passlock...
2005 malibu key won't come out of ignition
the key lock is stuck, you can bypass it by break the key lock,
Nov 13, 2012 | 2005 Chevrolet Malibu
Stuck eldorado key in DTS ignition now car won't start
Make sure your steering wheel isn't locked. Sometimes a key won't turn until you jiggle the wheel while trying to turn the key.
Aug 21, 2012 | 2004 Cadillac DeVille DTS
My key wont turn to off in order to remove my key from ignition while in parking
Ignition - Key Stuck In Ignition Switch/Won't Turn Bulletin No.: 06-02-35-005 Date: February 28, 2006 TECHNICAL Subject: Key Stuck in Ignition, Key Will Not Return to Off Position, Shifter Button Won't Release in Park Position (Adjust Shifter Detent Finger) Models: 2002-2005 Chevrolet Monte Carlo Condition Customers may comment on any of the following conditions: - The key is stuck in the ignition cylinder. - They cannot return the key to the off position to remove the key. - The shifter button won't release in the park position. Cause This condition may be caused by the detent finger shifting over time. This may result in mis-alignment and binding of the shift rod on the shift position guide.
Aug 05, 2011 | 2005 Chevrolet Monte Carlo
My steering wheel is stuck and when I put my key in it won't turn either. It starts to turn but won't go all the way
hi,it maybe a good idea to remove the steering collum covers to visually inspect it can be the ignition bolt just being loose or the steering lock or ignition it self is on its way out.
May 19, 2011 | Volkswagen Jetta Cars & Trucks
Ignition won;t start. The key insert is loose and turns but won't start
the ignition switch may need to be replaced. im not sure if a lock smith can replace the ignition switch, call around to see if they can.
May 29, 2009 | 2000 Lexus LX470
Orion Cobalt 2105 XP Car Audio Amplifier Logo
70 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
