Question about RCA P56923BL 56" Rear Projection Television
RCA D52W26 rear projection. 2 years old. 3 times and powers out.
I have a D52W26 rear projection tv. Recently I replaced the middle fuse beside the flyback transformer, due to convergence issues with success, and shortly after doing so, the tv powers off after three attempts to come on. I have heard this is a flyback transformer issue, even a bleeder assembly requirement. I need this resolved soon, as I am looking to buy a Sony 42in. as a replacement if I can't get this piece of RCA **** to function again. Any help is greatly appreciated.
Thanks, Steve.
  • Shady007 Feb 10, 2009
    Thanks for the feedback. I'll be attempting that this weekend, and will post the outcome. Steve,
  • RCA Master
  • 8,617 Answers
Try replacing CP150, CP114 and CP120 first cost about 12.00 with free instructions available at the following link under the RCA parts category
http://servicemanuals.vstore.ca/
Posted on Feb 10, 2009
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca 52 in projection t.v has problems powering up
Push and hold power button. If it cycles and blinks on/off in 3s or 9 times, it is a power problem. Replace the deflection board. Cost about 250.00
Jan 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W26 projection Tv is blurry. Digital board replacement
You cannot replace it yourself sir because there are a lot of adjustments(electronically not mechanical) and you need an equipment to transfer the data from the old EEPROM to the new one. If the convergence is fine then the fuse should be ok..Picture is blurry??? 1. could be a dusty CRT lens, you can clean those 3 lenses by taking off the front speaker grill then there's a small hole that you can see the lenses... or the mirror needs to be cleaned also. 2. maybe it needs a convergence alignment, pls check your owner's manual if available. thanks:)
Dec 28, 2009 | RCA Televison & Video
Free 2-3 year old rca prjctn tv needing convrgnc chip
I had this problem with my Proj. tv also it cost me $135. to have the convergence chip replaced. i would call a tv tech. to get the true cost.
Sep 19, 2009 | RCA P46920BL 46" Rear Projection...
RCA Projection TV Model HD61W66
convergence power supply not working , there is a mini fuse close to the flyback thansformer , 400miliamp at 250 v resolder the flyback and replace this fuse , there is 3 fuses it look like small squer brown color is the one on the middle , normal repair $200 - 300
May 07, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
RCA D52W26
very simple fix there's three micro fuses beside the flyback transformer if the center fuse is open check with meter then theres bad solder connections on flyback simply resolder flyback in board &install new fuse. the 3 fuses are brown or tan about a 1/2" long
Nov 19, 2008 | RCA P52926 52" Rear Projection Television
Sorry, here is the original post.
When you press power does the led light at all? That chassis has been plagued with bad flyback causing dead sets sometimes the led will flash 3 times slowly then go out. Other times it will make a soft short hiss. Does your set exhibit any of these signs?
May 12, 2008 | RCA P52926 52" Rear Projection Television
RCA D52w26
Your CRT leaked on the board. You will need to replace the seal as well as the board which got leaked on. Can you post a picture of the board and I will post the board number as well as post a link where you can get another boards at.
Apr 14, 2008 | RCA P52926 52" Rear Projection Television
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
312 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
