Back to:
Tags:
Brother MFC-7820N Printer
Problems with Brother MFC-7820N
By Putty - usenet poster
I have Brother MFC-7820N Printer/Fax machine and some times I get problem
with not getting the faxes to PC at all. I reload the Driver with Repair
option and mostly it gets sorted out.
Today, I have tried twice to sort out and the following message comes:-
The Brother FAX RECEIVE program must be started for you to receive PC Faxes.
Faxes appear in different mode:- brfrxo71.tif and not the readable
Fax30-10-2006tif
How do I start my PC fax receive programme?
Ch. Rajinder Nijjhar
I use Win XP Professional. Intel
Any other information needed please?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
Thanks for Trying (70)
Joey2
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
"Chaudhry Nijjhar" <
Defrag your drive.
When you get that message again, google it, someone else must be
having the same problem that found a solution.
Then it does work, look for limits on pages or space, defrag your
drive :)
I wouldn't think you would lose your data removing and reinstalling
your drivers, - uninstalling and reinstalling the program itself you
could.
NASA Says Hubble Repair Mission Is a Go
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Problems with Brother MFC-7820N:
I don't want to Accept this solution
Solution #2
Not Rated (0)
pandamama
Rating: 0%, 0 votes
I did run the CD- driver and it says it could not install the hardware in
full.
Now, I get couple of faxes and afterwards the same problem.
Should I remove the driver altogether and reinstall every thing. Would I
lose my data?
Rajinder
Thank You!
Solution #3
Not Rated (0)
Rachel007
Rating: 0%, 0 votes
Yes. I went to Fax services and it is automatic.
I was also getting warning that there is not enough space on my PC and I
should delete some programmes. But there is a lot of free space on my C
Drive.
Rajinder
Thank You!
Solution #4
Not Rated (0)
Rachel007
Rating: 0%, 0 votes
Might check to see if it requires a service running
Start | Run <type in
See if there is a Fax service and if so it's started.
Thank You!
Can you Help with these Printers problems?
Manual feed pulls documents, whether paper or envelope,...
Changed toner, Black smear lines on copies.
I've been using my 7820N for quite some time, no problem...
Got another one - I have a wireless network, but the...
after i print a page the printer prints one page with a...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
