Question about Frigidaire ATF6000ES Front Load Washer
Magnet came out and now washer won't run
A magnet fell out of the soap dispenser, and I don't know where the magnet is supposed to go and now the water won't fill up.
  • 20 Answers
On the under side of the dispencer, remove it, flip it over, fit it in with some glue, as far toward the inner part as possible, put it back, try the washer, if it still doesnt fill, try pulling it out a little and see if that works, if it does this is the amount you need to move the magnet back.
Posted on Feb 13, 2009
Soap dispenser will not stay closed\
    Good Morning D, thank you for your post!
    I understand the soap dispenser is not closing properly. There is a simple troubleshooting test you can do to see if you can remedy the situation.
  • ·If you've double-checked the drawer and it appears to be closed, remove the drawer and examine the magnet. If the magnet is missing or defective, the magnet probably needs replacing.
  • ·If the magnet is fine and in place, an experienced technician may need to examine the reed switch or main control board.
  • Since there are cost differences in parts and accessories, it is always a good idea to have a service tech properly diagnose your washer.
Feb 19, 2014 | Electrolux EW1000i Front Load Washer
Magnet fell out of the soap dispenser and now the washer will not fill with water
The magnet needs to be located on the right side of the dispenser housing it is there so the machine knows the drawer is closed. The link below will show the location of the magnet which is part number 51 near the bottom of the page.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0503093-00001.png
Apr 20, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer - soap dispenser door - Magnet fell out... where does it go
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Oct 22, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore washer
pull drawer out on right side just behind outer cover there should be a area where magnet fits if can't find exact spot hold magnet along right edge of opening and turn washer own if nothing happens move magnet along right edge till it comes on glue mahnet to dispenser drawer in corresponding area
Aug 15, 2008 | Washing Machines
Not filling with water
Answer: The magnet goes on the back of the dispenser door. Pull entire dispenser out per instructions elsewhere in manual as if you were going to clean it. Turn it around so that you are looking at it from the back end. The magnet goes vertically on the very left edge (as you're looking at it, right edge when dispenser is in machine) of the back of the white outer cover of the dispenser about halfway down. If you run your finger along the left edge (the edge of the back of the dispenser) you will find a "cut out" area. The magnet goes immediately to the right of it between the edge and the portion of the dispenser that sticks further out toward you. There is a small clip to hold it in place.
I found instructions somewhere on the web similar to these that helped me locate it , but can't find it now to link or give credit. I have added some photos I took to help schematically challenged folks like myself.
PS If you need bifocals remove the front cover from the dispenser, take your glasses off and look at the far middle left of the back of the dispenser cover. It's really hard to see.
a4fbef54-7dc5-4c60-815f-e92937ca670b.jpg 6bc37cd8-9f56-4605-b13e-03c400a840ab.png
Jul 31, 2008 | Kenmore 43142 Front Load Washer
Kenmore super capacity 3.5 front loading washer
it may be locked. hold the "options" and "select" buttons down together for 3 seconds.
Dec 16, 2007 | Washing Machines
My door lock magnet fell out and I don't know whee to put it back on the dispensr mechanism tomake t lock
I found it! If you are looking at the drawer from the back the magnet sits in the pocket in the far left. The plastic extends out like a clip (to hold the magnet in place). You depress that when placing the magnet in.
hth.
Kate
Aug 15, 2007 | Kenmore 43042 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
249 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
