Question about Acer Aspire 4530-5889 Notebook PC
Cannot communicate with www.microsoft.com(207.46.19.190)
Network diagnostic pinged the remote host but did not receive a response
  • yas_cool26 Feb 11, 2009
    how to renew the ipconfig?
    i have tried to the command but it's said no operation can be performed on local area connection while it has its media disconnected.
  • Acer Master
  • 3,051 Answers
Have you tried the {ipconfig/renew } command
Posted on Feb 10, 2009
Not connecting to google server. Even there is wifi connection.
There is a difference between establishing a Wi-Fi connection, than the connection to your internet. Although you see a connection with your Wi-Fi, your Wi-Fi is just like a cordless phone connection. You remember those old rotary phones you would have to charge on the charger/ receiver (Which is connected to the phone cord outlet on located in the wall). Just as how WiFi works, The range is limited. Just because you have no problems with your WI-Fi connection, you may not have an internet connection on which it may have something to do with your ISP (Internet Service Provider). The best way to find if you are communicating out side your home network, Open the "COMMAND PROMPT" Type ; ping google.com (press Enter)
If you are communicating out side your home network you should get results like this displayed below;
Pinging google.com [216.58.216.46] with 32 bytes of data:
Reply from 216.58.216.46: bytes=32 time=39ms TTL=52
Reply from 216.58.216.46: bytes=32 time=40ms TTL=52
Ping statistics for 216.58.216.46:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 39ms, Maximum = 40ms, Average = 39ms
If you're not communicating out side your home network; it will display.
Ping request could not find host google.com. Please check the name and try again.
Wi-Fi is to connect your devices to the Gateway (Wi-Fi Router/Modem) which your gateway provides the connection to your internet. You are not having problems with your Wi-Fi, you're having problems communicating outside your home network. When this occurs, unplug your Gateway (Modem/Router) and check to see if it restores your connection. If this does not work, call your ISP to check for outages. Other situations is not paying your internet bill which may have caused your ISP to disconnect your service.
Oct 24, 2017 | Google Computers & Internet
Problems big problems
Verify that TCP/IP (or other appropriate protocol) is properly installed.
  1. Open Control Panel and open Network Connections or Network and Sharing Center, then click Change adapter settings. The wireless card should be present as Wireless Network Connection.
  2. Right-click the appropriate Wireless Network Connection and select Properties. In the Properties window, make sure that the Internet Protocol (TCP/IP) or Internet Protocol Version (TCP/IPv4) is installed.
  3. If TCP/IP is not installed, click Install, click Protocol, and then click TCP/IP.
  4. Once installed make sure that Obtain an IP address automatically, and Obtain DNS server address automatically are checked (if using DHCP). To verify this, highlight the TCP/IP protocol, and select Properties.
Note: Only use a Static IP Address if your network/Service Provider requires one.
8.Verify the TCP/IP address.
  1. Click Startwindows%20start%20button.png, select All Programs, select Accessories, and then click Command Prompt.
  2. Type the command, ipconfig. This will list the IP address for the local machine.
  3. If this returns a 169.x.x.x or 0.0.0.0 address, then type the following commands;
    ipconfig /release and then
    ipconfig /renew.
    You should then receive a TCP/IP address appropriate to your network, along with a Default Gateway address.
  4. Try to communicate with it by typing this command ping x.x.x.x where x.x.x.x is the IP address of the Default Gateway. (i.e. ping 192.168.1.1)
  5. If this does not give a reply (see the example in step 9) or you did not receive a TCP/IP address, go to the next step.
  6. If you are connecting wirelessly, but receiving an IP address, your wireless router/Access Point might need to be reset (unplug power for a minute, then plug back in), or maybe defective. Please consult your wireless router/Access Point manufacturer for further assistance.
9. Ping the loopback address.
  • Click Startwindows%20start%20button.png, select All Programs, select Accessories, and then click Command Prompt.
  • Type the command, ping 127.0.0.1. This will send a message to the internal network stack on the machine. You should see a response like this:
    Pinging 127.0.0.1 with 32 bytes of data:
    Reply from 127.0.0.1: bytes=32 time<10ms TTL=128
    Ping statistics for 127.0.0.1:
    Approximate round trip times in milliseconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
  • If instead, you receive errors, then there maybe system corruption or malware installed preventing networking from functioning properly.
  • 10. Verify that the hardware is functioning using diagnostics.
    • Check the web site, http://support.lenovo.com. Choose Download Drivers and Software and enter your particular system. Then under Diagnostic choose the download for your system. If diagnostics fail, please contact warranty support for resolution.
    • Run diagnostics for third party wireless card.
      Note: If using another manufacturer's product, then consult it's documentation on how to run the diagnostics for the wireless card.
Mar 10, 2014 | Lenovo ThinkPad R60 with Wireless Wide...
Pingtest.net
I will help you to know what is Ping!!!!
Ping is a basic Internet program that allows a user to verify that a particular IP address exists and can accept requests.
Ping is used diagnostically to ensure that a host computer the user is trying to reach is actually operating. Ping works by sending an Internet Control Message Protocol (ICMP) Echo Request to a specified interface on the network and waiting for a reply. Ping can be used for troubleshooting to test connectivity and determine response time.
As a verb, ping means "to get the attention of" or "to check for the presence of" another party online. The computer acronym (for Packet Internet or Inter-Network Groper) was contrived
to match the submariners' term for the sound of a returned sonar pulse.
Tip: To find out the dot address (such as 205.245.172.72) for a given domain name, Windows users can go to their command prompt screen (start/run/cmd) and enter ping xxxxx.yyy (where xxxxx is the second-level domain name like "whatis" and yyy is the top-level domain name like "com").
You can check the ping test in http://pingtest.net/ also you can check that here www.whoisxy.com
Nov 20, 2011 | Computers & Internet
What is Gateway Ping
Ping is used to check for a network path to a specific host. In this case the script will ping from domain.com to the host you provide. Ping should be the first TCP/IP diagnostic tool you use when tracking down a network problem. Ping uses a series of Internet Control Message Protocol (ICMP, often-pronounced eye-comp) messages, that produces an Echo message to which every host responds. When Ping uses the ICMP messages and replies, it can determine whether the other system is alive, and also compute the round-trip delay in communicating with that system. So Ping can show you how fast the connection is between two ip addresses or domains.
Oct 11, 2011 | Samsung LA40A550 40 in. HD-Ready LCD TV
I can't connect through network can't connect by pinging
Can you ping your router?
If you can, log into it and see if you have any problems with it. If you have ADSL, you will see the status of the line as well as whether you are connected or not. You may have a diagnostic feature that will test the connection to your provider.
If you have lost DNS with your provider, you will not be able to ping using names, only by IP addresses.
Jul 24, 2011 | Computers & Internet
HI...since yahoo mail went down monday i cant get on any part of yahoo at all.......Why? thx Hellsvampbiker
I don't recall Yahoo going down on Monday, but it sounds like you might have a virus that changed your HOSTS file, which is an override for websites. Here's a good way to check:
1. Hold down the Windows logo key and press "R". A dialog box will pop up.
2. Type "CMD" without the quotes and click "OK".
3. You will see a black box appear. In that box, type "ping www.yahoo.com" without the quotes and press enter.
It will take 5 seconds for a successful test looking somewhat like this:
Pinging www-real.wa1.b.yahoo.com [XXX.XXX.XXX.XXX] with 32 bytes of data:
Reply from XXX.XXX.XXX.XXX: bytes=32 time=56ms TTL=57
Reply from XXX.XXX.XXX.XXX: bytes=32 time=53ms TTL=57
Reply from XXX.XXX.XXX.XXX: bytes=32 time=51ms TTL=57
If it cannot get to yahoo, it will take about 10 seconds and look like this:
Ping request could not find host www.yahoo.com. Please check the name and try again.
OR
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for XXX.XXX.XXX.XXX:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
If it cannot find Yahoo, navigate to C:\windows\system32\drivers\etc and look for a file called HOSTS. Rename that file to HOSTS.old. Once you've renamed the file, try to ping yahoo again. You should get a response, and you should be able to access yahoo.
If you need more troubleshooting help (if this doesn't work) send me a message and we can try some other steps.
Oct 29, 2009 | Compaq Presario Notebook
2005 FORD F150 AC blows cool/warm in front and cold n back vents
Check i the truck comes with separte a/c units, if the front is warm check for an open heater valve, if ok, check for proper gas pressure.
Jul 08, 2009 | 2005 Ford F-150
The camcorder doesnt reset anything. The mini DV still stuck in
Networking Configuration A network architecture is a set of standards for how computers are physically connected and how signals are passed between hosts. Some typical network architectures are described in the table below.
Network Architecture Description Ethernet Ethernet is a wired networking standard and is the most common networking architecture used in LANs (both in business and home networks). Dial-up Modem Dial-up networking is a common way to connect a computer (often your home computer) to a remote network, such as the Internet or a business network. A modem on each computer uses the phone lines to send and receive data. DSL (Digital Subscriber Line) DSL is a fast-growing alternative to dial-up networking to connect to the Internet. DSL uses regular phone lines to send digital broadband signals. ISDN (Integrated Services Digital Network) ISDN is another alternative to traditional dial-up that can be used to connect to the Internet or to directly communicate with another computer connected to the ISDN network. ISDN is more common in Europe than in the U.S. ISDN can use regular telephone wiring, but must be connected to a special ISDN network. Wireless Wireless networking uses radio waves or infrared light (with the air as the transmission medium) to send data between hosts. Wireless networks are common in homes, businesses, airports, and hotels. Most wireless networks connect into larger wired networks (such as LANs) which are in turn connected to the Internet. Communication between hosts on a network generally takes one of three forms:
  • Simplex--one-way communication from a sender to a receiver.
  • Half-duplex--two-way communication between two hosts. Communication only travels in one direction at a time.
  • Duplex--two-way communication between hosts. Communication can travel in both directions simultaneously.
Jul 08, 2009 | Panasonic Palmcorder PV-GS15 Mini DV...
Brand new linksys wireless, Host (Hard wired)has intermittent connectivity. Indicates it is conneted and is working properly.Cannot browse Web. The wireless part works great!
try to plug the Ethernet cord for the Host computer on another Ethernet port on the Linksys router.
have you tried replacing the Ethernet cable that's connecting the Host computer to the linksys router?
check if Host computer can get a response from a website by going to Start>Run, then type CMD on the Run box and click OK. On the black screen, type PING www.yahoo.com then press Enter.. if you get the word reply 4 times, it means the computer is connected to the Internet.
If there's no response from the PING test, it means there's totally no connection.
It's also possible the problem is with the Local Area Network adapter or Ethernet adapter. Try disabling the Ethernet adapter and re-enable it by going to Start>Control Panel>Network Connections, you should see the Local Area Connection, right click on it then select Disable then Enable it again. then observe if you're still experiencing intermittent connection on the Host computer.
and if you have security software, try disabling it temporarily and check the connection again.
and let's make sure the cable or dsl modem is connected to the Internet port on the back of the Linksys router.
May 10, 2009 | Linksys WRT160N Wireless Router
Acer Aspire 4530-5889 Notebook PC Logo
878 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
