Question about Maytag MSD2732GR Side by Side Refrigerator
Water Filter Indicator Light on Maytag side by side
How do you get the red indicator light to reset. I have replaced the filter. I have tried resetting the power and I have ran water through it but the light is still lit.
Hold light and lock until change filter light blinks
Posted on Feb 11, 2009
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
How do I change the water filter
Removing and replacing a water filter - upper right hand corner location
Filters situated in the upper right hand corner of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
  • Finally, reset the 'change filter' indicator light, if your refrigerator has one, at the front of your refrigerator. The procedure for resetting the change filter indicator light can vary from fridge to fridge. Typically, the indicator light can be reset by holding down on the 'lock' button and the 'water' button simultaneously for three seconds. Sometimes, it is the 'lock' and the 'light' button you need to press down on simultaneously for three seconds in order to reset the filter indicator light.
Removing and replacing a water filter - center ceiling location
Filters situated in the center ceiling of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • Turn the filter a quarter turn to the left, in a counter-clockwise motion. The 'unlocked' symbol on the filter will be lined up with the indicator line that is molded into the refrigerator just above the filter. Allow the ears of the cartridge to disengage from the filter holder.
  • Gently pull down on the filter, being careful to not spill any water still in the filter. Discard the used filter.
  • Remove the new filter from its packaging. Remove and discard the red plastic cap found on the top of the new filter.
  • Apply the appropriate month sticker to the filter to remind your self to remove and replace the filter in six months' time.
  • Insert the new filter into the filter opening. Line the 'unlock' symbol on the filter up with the indicator line that is molded into the refrigerator above the filter. Turn the filter a quarter turn to the right, in a clockwise motion. You will be able to feel the filter stop when it is all the way in, and the 'locked' symbol on the filter will now be lined up with the indicator line above the filter.
  • Close the refrigerator door and dispense several glasses of water through the water dispenser in the door in order to purge the new filter of any impurities. Open the refrigerator door again and check for leaks. If you find a leak, remove and replace the new filter again.
Nov 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Have replaced the water filter - how do i reset/turn off the "change filter" light ?
Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4 Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • May 18, 2010 | Maytag MZD2766GES Side by Side...
    I am replacing the water filter how do I reset on the outside door
    The Water Filter Status Indicator Light serves as a
    reminder to replace the water filter. A green light
    indicates that the filter is in good condition. A red light
    indicates the filter should be changed. Once light turns
    red, it will remain red until function is reset.
    To Reset Indicator:
    • Press and hold both the Lock and Water
    buttons simultaneously for four seconds. The
    green filter status indicator light will flash
    three times when the function has
    successfully reset.
    Thanks, Sea Breeze
    May 17, 2010 | Jenn-Air JCD2295HES Side by Side...
    Trying to reset filer light after changing filter-locked up
    Here is a link to the manual for your unit. Copy paste into your browser.
    http://shop.amana.com/assets/pdfs/literature/12591321.PDF
    Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
    There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
    DISPENSER LOCK
    (SELECT MODELS)
    This feature prevents ice or water from
    being dispensed.
    To lock dispenser:
    ➢ Press and hold DISPENSER LOCK
    button for 3 seconds. A green
    indicator light above button confirms
    dispenser is locked.
    To unlock dispenser:
    ➢ Hold DISPENSER LOCK button for 3
    seconds. Green indicator light above
    button will go out.
    Filter reset
    The filter status indicator light
    serves as a reminder to replace the
    water filter. A green light indicates that
    Once light turns red, it will remain red
    To reset indicator:
    ➢ Press and hold both DISPENSER
    LOCK and WATER buttons
    simultaneously for 4 seconds. The
    flash 3 times when the function has
    successfully reset.
    Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
    Red light stays on after changing the water filter and running about 2 gallons through it
    Light (select models)
    To Reset Indicator:
    successfully reset.
    Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
    Change filter light
    To Reset Indicator:
    successfully reset.
    Sea Breeze
    Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
    Maytag msd2454gr refrigerator how turn filter light off after replacing filter?
    For some refrigerator models featuring
    water filters, the Water Filter Change
    Reminder function monitors the life of the
    filter and provides a reminder when it is time
    for the filter to be changed.
    When the system detects either 12 months
    of usage, or the filtering of 416 gallons of
    water (whichever comes first), the CHANGE
    FILTER
    indicator light will illuminate. This
    indicates that the water filter should be
    changed and the light reset.
    To reset CHANGE FILTER light: Press and
    hold the LIGHT and LOCK pads until the
    CHANGE FILTER light blinks (approx. 3
    seconds). The control is now reset for 12
    months or another 416 gallons.
    Note: The Water Filter Reminder will
    operate if the filter bypass is in place.
    Nov 23, 2009 | Maytag MSD2454G Side by Side Refrigerator
    Changing light after installing new water filter
    (select models)
    To Reset Indicator:
    • Press and hold both the LOCK and WATER
    successfully reset.
    Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
    I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
    Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
    Maytag MSD2732GR Side by Side Refrigerator Logo
    392 people viewed this question
    Top Maytag Refrigerators Experts
    Bailey's...
    Bailey's...
    isaac johny
    isaac johny
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
