Question about Coby MP-705 Digital Media Player
Freezes when updating library
When ever i unplug my Coby mp3 player from the computer it sais updating library but then it freezes right when it is 3/8ths of the way done so i put something in the reset button to reset it but then it does not reconize all that i eddited on it. All my question is "Why does it freeze while it is updating library?"
  • 3 more comments
  • lhowell Feb 21, 2009
    i unplugged it after it downloaded.when it said please unplug deviece
  • Anonymous Apr 28, 2009
    No, the computer said it was okay to unplug the device.
  • Anonymous May 08, 2009
    Yeah my Coby705-4G does that too, Is there anything that I can do to make it upload?
  • Anonymous May 10, 2009
    after copying a musc folder, the usb gets disconnectd while copyig 2nd one. The status on coby says updating library and is frozen. after resetting it can be connected to pc, but the copied songs are not recognized.
  • minizidane26 May 11, 2010
    Wow, that is wierd, just clarify a little. How do u transfer your library?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 38 Answers
Did u unplug the device without the computer saying " it is now ok to unplug device"
Posted on Feb 17, 2009
Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
Frozen need to reset my mp3
Resetting the Player
Disconnect your player if it is connected to a
computer.
Use a paper clip to gently press the <RESET>
button located on the rear of the player
Mar 06, 2010 | Coby MP-610 MP3 Player
My M-610 MP3 keeps saying its unplugged even when it's not?
Here are instructions for a solution to your Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
Jan 10, 2010 | Coby MP-610 MP3 Player
Ok so I have a coby mp3 player and the songs are
Ok there are 2 Solutions that can fix this:
First:
1. Plug the MP3 player into the USB port. Open Windows Media Player, which will recognize that the device is plugged in and register under the "Sync" tab at the top.
2. Click on the "Sync" tab and and the library that is on your MP3 player will be displayed.
3. You can select individual songs or albums for deletion. Simply right click on the song or album to be deleted and scroll down to the "Delete" option.
4. After selecting "Delete," another window will come up which says "Are you sure you want to delete [title of song]?" There are two options at this point--you can delete from the library only or from the library and your computer. Select the one or the other and click
"OK." The song will be deleted. The change will be displayed within the library onscreen.
5. When you unplug the player from the port, the library will adjust the files to reflect the change. The player will say "configuring library" or some other message to that effect. Once this has finished, the main screen will be displayed. Depending on the model of the MP3 player, there may be a message stating "library updated."
Or if that does not work try this:
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the Coby's website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 03, 2009 | Coby MPC-848 MP3 Player
I need some instructions on how play it
1. Use Windows Media Player to put songs on your Coby MP3 player. Download songs in MP3, WMA, or OGG format from a legal downloading website. If the file is not one of the previously mentioned files, you must download a converter to convert the file to one of the correct files that can be played on Windows Media Player. Rip a song from a CD by inserting the CD and then click on the option to "Rip" the song to your library. Some Coby MP3 players do not need Windows Media Player to add songs, so be sure to check your user manual to see if there is an even simpler method.
2. Connect your Coby MP3 player to your computer using the USB connector that came with your MP3 player. The player will show up under the "Devices" option on your Window Media Player application.
3. Click on the "Library" option to view all of the songs stored on your Windows Media Player library. You can drag the song to the MP3 player in the "Devices" section, or you can right-click on the song and choose the option to transfer the song. In the pop-up box choose your MP3 from the drop-down menu and then click on the "Transfer" button.
4. Right-click on the MP3 player in Windows Media Player and choose the "Eject" option. Disconnect your MP3 player from your computer and turn it on. The song will now be available on your MP3 player. Press the bottom button to play or pause the song.
5. Add videos and pictures to your Coby MP3 player if it supports those files. The process is similar to transferring audio files. Plug your MP3 player into your computer. Open the photo file on your computer and drag pictures into the player. You can create folders to organize the pictures.
Sep 30, 2009 | Coby MP-C552 MP3 Player
I cant download music into it
Thry the solution below. If it does not work then you need to reformat. Also you might want to go to the coby website and download a updated version on the firmware and reflash your player. This will set it back to factory settings.
  1. Open Windows Media Player.
  2. Find and click the "Sync" tab. This is located at the very top of the program.
  3. Plug the Coby mp3 player into one of the USB ports found on your computer. Depending on the exact Coby mp3 player that you own, you can either plug the player directly into the USB port or by using the cord that came with the Coby mp3 player. The name of the Coby mp3 player will appear in the top right corner of Windows Media Player.
  4. Click "Library." This link will be on the left side of the program.
  5. Double-click the "Songs" option in the middle of the screen.
  6. Scroll through the list of music on your computer until you find the songs you want to put on the Coby mp3 player. Right-click on the title of the song and a drop box will appear. Select "Add to Sync List." You will then notice the song listed in the column located on the right side of the program.
  7. Repeat the previous step until you're finished putting songs on the Coby mp3 player.
  8. Click the "Start Sync" tab located beneath the list of songs you chose in Step 6. Those songs will then be added to your Coby mp3 player.
Sep 26, 2009 | Coby MP-705 Digital Media Player
Need help with unfreezing the Coby 4G Flash Video MP3 Player!
There should be a reset button on the lower back of the device (have to use a small tool, like a thumbtack to set it)
Sep 01, 2009 | Coby MPC-848 MP3 Player
COBY MP610-2G - FILE SYSTEM ERROR
you may have to get a firmware update
(download to computer, install utility, wire up player, run update..)
you will find firmware, specs sheet and manual for download here:
http://www.cobyusa.com/?p=doc
after doing the update, access player via win-explorer, erase all the mp3s(do not format!, as this will erase the firmware as well)
and drag and drop your new mp3/files onto the player.
unplug, press play and if everything is right: enjoy listening
Aug 08, 2009 | Coby MP-C7085 MP3 Player
Coby MP-705  Digital Media Player  Logo
546 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
