Question about Hunter Fan Company 5/1/1 Programmable Thermostat
I set temp to 74 and stop at 70 and decresing.
I have to turn off and turn on again heat and then after it reach two degree and stop.
    President:
  • 1,902 Answers
Sounds like the variances are not set right. if I am understand you. You set the thermostat to 74 and the heater shuts off at 70? If that is correct then the variances are wrong or you have placed the T stat in a bad location where it is getting heat from a vent, wall where there is a appliance or in a very drafty location
Posted on Feb 10, 2009
2 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: I set temp to 74 and stop at 70 and decresing.
The only thing I can think of other than being just old and worn out is that by design it may not be set to run but so much at a time. Has this always done this since you have had it? It may be needing calibration. One thing you can try is to set it at 2 degrees higher than you want it and then it would shut off at the temp you actually want.
Posted on Mar 04, 2009
How do I bring up heat to 70 degrees on my Proselect PsTs21P52 thermostat which has been programmed?
Looks like you have a hold function. This will bypass the programming and "hold" your desired temp. If the temp rises but reaches a maximum of a certain degree than someone has set the maximum heat temp to that degree. Meaning you will have to enter the settings menu and scroll through to make the changes. You need the manual. Good Luck.
Apr 04, 2017 | Heating & Cooling
My thermostat show 74 degrees as a current room temp...but we have it set at 70 and it's probably 65 in the house. ..the only way it will turn on is if I put it 74 or 75????
The old white-rogers thermostats with a mercury switch are adjustable. snap the face off. In the center you will find a plastic slot screw. set the indicator to the actual room temp.
Other type ? Replace the thermostat
Mar 01, 2015 | Heating & Cooling
UNIT KEEPS FREEZING UP. WE HAVE THAWED IT OUT MANY TIMES AND SAME THING HAPPENS. IS THERE A RESET BUTTON?
have you checked the filter ? do you have the temp set to low? are you trying to cool to big an area? shut it down again and let it thaw out. set the stat to mid range and trun it back on. close all unused rooms. when the unit cycles of and its still not cool enough turn the tstat down unilt it comes back on and leave it there.. unil the rom temp reaches 72-74 degree. thats the best set point .. you might be about to get it down to 70. but my bet is 1 dirty filter. and set temp to low.
Jul 16, 2011 | Heating & Cooling
User manual for jnc JAC-24Y2???- want to know what the optimal setting for heating temp is for economy in the unit. We seem to have to have ours set quite high to get the unit to run consistently. If we...
Normal settings 70 heating 74 to 76 cooling, I try to leave my cooling a 76 and keep it there. 76 degrees feels good if its 95 or hotter out side and the lower you set it the more it will cost.
Jul 03, 2011 | Heating & Cooling
Furnance will not start until room temp is at least 5 degrees below set temp ie temp set at 70 , wont start till it reaches 66 or 65 degrees
themostat is bad, or the heat anticipator on the stat is bad, which means you still need a new stat
Oct 23, 2010 | Heating & Cooling
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Mar 04, 2009 | Hunter Fan Company 7-day programmable...
The thermostat does register the right temperature.
Your heater might be on the Auto settings .. it will turn on and off itself once the pre set temp is reached ...
Jan 05, 2009 | Lasko 5365 Ceramic Compact Heater
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
116 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
