Question about Hitachi 57G500 57" TV
Green crt not getting signal
Tech swapped the green and blue signals to thr crt's and the green works.
estimate is 500 for signal board replacement. any suggestions ?
  • 42 Answers
Before you sink 500 into the signal bd
I would double check the crt bd for the green gun
There is a couple of resistors on that board that go bad (open up)
this does not sent the signal in
Did the tech use a scope to determine weather you have signal to the crt bds or did he just switch the crt bds from one to the other ?
I bet if you change the crt board or ohm out the boards you will find a open resistor
Posted on Feb 10, 2009
My TV screen turns green with no picture until i turn it on and off TV is approx. 2.5 yrs old and is used very little and it seems to be getting worse thanks Kent
This tv a CRT tube tv?Or a LCD tv or a Plasma tv?The tube tv,the video board that connect to the CRT tube head have problems.The Plasma or a LCD tvs.The main board,call the Tuner board is the cause,this board,that where the incomming broascating signal cable plug into it.CRT tube tv,old technology,must take to tv shop for estimate and repair.Plasma or LCD tvs can tries websites like Shopjimmy.com or Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 19, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Yellow circle in center of screen & blue shading to side
Hello, This will require you opening the back cover of the television. This could be a heater-cathode (H-K) short in the CRT, a failure of a component in the chroma circuits or video output (driver board), or bad connections there or elsewhere. Note: before proceeding, it is a good idea to make sure that the screen is degaussed - else you could be attempting to track down problems with the wrong color!
Some simple tests can confirm or rule out other possibilities.
Compare the voltages for the video drive signals to the CRT on the little board on the neck of the CRT with the CRT both connected and unplugged. A schematic will help greatly in locating these signals.
If there is a significant difference especially on the bad color, then the CRT is a likely candidate. Try tapping the neck of the CRT GENTLY (with it plugged in and while viewing a picture) to see if it is an intermittent problem.
If there is no significant difference, you may have a bad driver or a problem in the chroma circuits.
Look for bad connection/cold solder joints, probably on the little board on the neck of the CRT. Use an insulated stick to gently prod the board and its components in an effort to induce/cure the problem. Look carefully for hairline cracks around the component leads.
You can swap components between two colors and/or test with an ohmmeter on that driver board to determine what is bad.
Another simple test: Disconnect the cathode for the full-on color from its drive. If it is still full-on, there is probably an H-K short in the CRT since the only way to get each color on the screen is via the cathode connection to the CRT neck board. If it is removed and there is still that color, the current must be taking another path inside the CRT.
Alternatively, interchange the outputs of the bad color with a good one by jumpering on the video driver board (on the CRT neck). If the bad color changes, then the problem is in the circuitry and not the CRT.
To identify if the fault is in the CRT or a control problem try this (WITH SET OFF):
On the CRT board, lift the output end of the green cathode final resistor. Do the same with the offending red cathode's resistor. Use short insulated jumpers to 'swap' drive signals - drive the red cathode with the green drive and the green cathode with red drive. (Note that if this problem only occurs after a warmup period, color at turn on will be - well - wierd, but it is just a test.)
If instead the symptom becomes 'goes green' then the red drive leg has the fault and the CRT is probably good. (In this case, there may be bad connections or a bad component on the CRT drive board. Also it involve a technical skilled personnel to handle this..
May 20, 2010 | Sony Grand WEGA KFWE42S1 TV
The picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
I have no picture coming out of my blue picture tube
ok 2 things could be wroung one is u have a bad crt board one way to find out is swap the blue crt board with the red crt board and see if the blue comes up and now u have no red. now u can not swap it with green the green crt board is allways by it self noe if that does not work and u still have no blue it could be the picture tube or something from the video board that is blaking it out and without a scope u cannot trace it but if u are lucky it will be the crt board hope this helps u
Sep 05, 2008 | Philips 55PP9401 55" Rear Projection...
Yes i need more help on these opto-couplers
The halo effect is due to the green and blue CRT coolant being congealed this is a common problem. Red will not have the same condition. As for the opto-couplers they are located on the large signal board in the middle of the board all lined up in a row they will have board location numbers of 7412, 7406 and 7413 . 7412 is usually the culprit the part numbers for 7412 is 9322-105-14682 7406 and 7413 are the same part number 9338-894-15682
May 15, 2008 | Televison & Video
PT-47wx42 color problems
This could be a heater-cathode (H-K) short in the CRT, a failure of a component in the chroma circuits or video output (driver board), or bad connections there or elsewhere. Don't panic - heater-cathode shorts in CRTs can often be worked around.
  • Compare the voltages for the video drive signals to the CRT on the little board on the neck of the CRT with the CRT both connected and unplugged. A schematic will help greatly in locating these signals.
    • If there is a significant difference especially on the bad color, then the CRT is a likely candidate. Try tapping the neck of the CRT GENTLY (with it plugged in and while viewing a picture) to see if it is an intermittent problem.
    • If there is no significant difference, you may have a bad driver or a problem in the chroma circuits.
  • Look for bad connection/cold solder joints, probably on the little board on the neck of the CRT. Use an insulated stick to gently prod the board and its components in an effort to induce/cure the problem. Look carefully for hairline cracks around the component leads.
  • You can swap components between two colors and/or test with an ohmmeter on that driver board to determine what is bad. The nice thing about color monitors and TVs is that there three copies of each of these components. Swapping and/or comparisons between these is an excellent diagnostic technique.
  • Another simple test: Disconnect the cathode for the full-on color from its drive. If it is still full-on, there is probably an H-K short in the CRT since the only way to get each color on the screen is via the cathode connection to the CRT neck board. If it is removed and there is still that color, the current must be taking another path inside the CRT.
  • Alternatively, interchange the outputs of the bad color with a good one by jumpering on the video driver board (on the CRT neck). If the bad color changes, then the problem is in the circuitry and not the CRT.
So you have to get a tech if the above method doesn't solve your problem and get it fixed..
Goodluck,
Please don't forget tor ate me as fixya..
Feb 09, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Usuable signal/blue screen
No picture, just black screen
Check R3414, an SMD chip on the CRT board. There could be invisible bad solder joints
Noisy picture
Replace relay RY481 on S2 board
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
Nov 23, 2007 | RCA 32V430T 32" TV
JVC AV-56WP74 closes up and flickers when input is trying to come through
First possibility is a CRT coolant leak onto the signal PCB.
Examine from front and back with good light = even a few drops
of conductive coolant can cause various unusual symptoms....
Your symptoms are multiple and normally un-related, unless,
as you mentioned,all the signals converge......................T.
Nov 22, 2007 | JVC AV-56WP74 56" Rear Projection...
Get into service mode
if it cannot be adjusted then there is a problem in tv. as your green color is absent you will get red+blue=purple your problem is in green video ckt please check 1 sypply to green cathode ckt 2 loose contact in crt base 3 loose signal connector 4 check components related to green cathode& green video tr. itself 5 check for green signal is coming to green video section from processor. 6 signal processor ic if you are not tech person get it done by skilled tech. it is a common problem. it is a not a major problem. please check
Sep 30, 2007 | Televison & Video
Hitachi 57G500 57" TV Logo
124 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
