Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Unsupported signal. Check your device output
I am on sattilite. I may have hit the sony remote as i was changing to my recordings.
2 Suggested Answers
mjjdesigns
  • 98 Answers
SOURCE: sony bravia klv-32t400a hdmi input through x-box
The problem is that, according to the specs for that TV, it doesn't support 1080p.
That's a 720p television you've got. (Specs here)
While the specs say that it supports 1080p, the resolution says it supports 1366 x 768, which is only 720p, not 1080p or even 1080i.
You may want to contact Sony for clarification, because their specs for that tv are contradicting each other.
Posted on Mar 19, 2009
How solve in my POLYCOM VSX 6000 showing error "unsupported signal adjust your PC output"
Try using the S-Video output and then try using the VGA output from the VSX 6000 unit. The unit can be fixed to output from either as the first monitor output (you may have the dual monitor option enabled). If this does not work the resolution of the TV might be HD, the output of your VSX 6000 is Standard Definition. You will need a monitor that accepts standard definition. If this does not work, I would reboot your VSX 6000 and try again. David
May 17, 2014 | Polycom VSX 6000 (220022222001) Video...
I own a Sony kdf-55e2000 , when I try to hook up a ps3 through the hdmi imputs i get a message reading "unsupported signal please check device output" i can here the sound but no picture.Is there any
try only having the hdmi cable hooked up to ps3 and tv, turn off ps3 and hold power button for 5 or 10 seconds and you should hear 3 beeps, this should reset the ps3 and detect the settings, if this doesnt work you mmay have to manually change audio and video settings in the ps3 settings menu to hdmi output and auto detect which settings work.
Jan 05, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
I have a sony bravia bx421 when i connect my ps3 to it using hmdi it says unsupported signal please check device output, please help mee.. i tried everything such resetting the video, changing the output...
Hey jhoff, you're a ******* ******. I'm having this problem right now, it only just started, my PS3 worked for a year on my Bravia before pulling this. Apples to oranges my ***. Go **** yourself, *******.
Nov 15, 2011 | Televison & Video
Why my hdmi cable keeps saying unsupported signal. check your device output
use a normal cable to connect to you tv and check the resolution that the hdmi is trying to output. if it wont display with the normal one then you will have to reset the video output system.
http://www.tipstrs.com/tip/1888/Reset-your-PS3-video-settings
Jan 05, 2010 | Sony Playstation 3 (PS3) Console
Everything is connected but when i turn on the ps3 the tv says unsupported signal check your device output
make sure your hook-ups are connected correctly and if so could be a high def setting or componet setting inside you system.
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
My remote control has broken. I am getting no response although I have changed the batteries
There are two possibilities for failure; the remote itself and the receiver in the recorder.
Many service shops have a simple device that will reveal if the remote is putting out any signal at all. If it does, the output is probably correct; they don't often fail by screwing up the coded infra-red signal.
If the remote seems to be working, then your problem lies with the receiving end inside the recorder.
Oct 24, 2009 | Evesham PVR160 Freeview 10-Hours Video...
Pc setting for sony bravia
'Unsupported Signal' Error indicates that TV is accepting the signals for Video but not able to display because resolution doesn't matches. Else the message would be 'No Signal'.
Follow the steps-
NOTE- Make sure cable is 15 pin(at both ends) VGA cable, working fine between PC & Monitor.
1.The standard resolution of laptop(any) which would support is 1024*768.
2. Toggle the display output from Laptop Fn Keys depending on Laptop Brand.
3. Connect the cable after settings made.
Also PC Settings will not be highlighted until connection is made.
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
1,773 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
