Question about GE 35GT740 35" TV
Rabbit ears to digital conversion box
I have an old tv (80's) that I am trying to hook up to a digital conversion box. I have an adapter to connect the rabbit ears to the converter. I don't have input/output or coaxial connectors on the back of my tv.
    Genius:
  • GE Master
  • 1,689 Answers
A long time ago I used to see adapters that would allow a 75 ohm to 300 ohm connection for the older TV sets. These may not be easy to find anymore.
Considering all things practical and the age of the set, there comes a time when it is the time to get a new set! At least the new set will be compatible and you will be able to enjoy a better quality of performance.
Jerry G.
Posted on Feb 10, 2009
How to hook up T V ears on 32 " element tv ( elucfw329 )
every since television went digital, rabbit ears are hard to get to work. you will probablty have to get a digital converter box for it first, attach rabbit ears to converter box and box to television the same way you would attach cable
Jan 16, 2014 | Element Electronics FLX3210 32 in. LCD TV
No reception with rabbit ears
Check to see if you have the "Rabbit ears" plugged into the correct spot and you are on "Analog tv" if you are trying to use digital tv on "Rabbit ears" it can't send out a strong signal like the areal ontop of a house. You may need to get an adapter to broadcast a stronger signal but even better if you can connect to roof antena.
Oct 24, 2012 | Panasonic TH-42PX6U Plasma TV
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Can't get any channels on Coby tv
Yes, you need an antenna -- rabbit ears or some other type of digital antenna.
Jan 28, 2009 | Coby TVDVD1350 13 in. TV/DVD Combo
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
Hook up old tv antenna to converter box
how do you hook up a tv with just screws to a converter?
May 27, 2008 | Televison & Video
Sony rabbit ears
The "Horse Shoe Like Ends" on the leads are installed under the Screws marked ANTENNA and then the screws tightened. If No Screws then your Rabbit Ears do not hook directly to this TV. Is there a connector comming out of the back that is Threaded? If YES, then this is your antenna connector (R59) and will require an Adapter for the rabbit ears. Available at Radio Shack.
Feb 04, 2008 | Proton MM2701VT 27" TV
GE 35GT740 35" TV Logo
112 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
