Question about IBM POWER SUPPLY 120W 25P4966 Power Supply
My monitor turns itself on and off with no prompting
I have an IBM P96 model monitor. Every few minutes, it will rapidly turn itself on and off. i have tried resetting the refresh rate to different levels, but it still does the same thing. It seems to be happening when I leave my mouse idle for around 15 to 20 seconds. This is highly irritating and I really don't want to have to buy a new monitor. Any ideas as to what this is?
  • 2,976 Answers
Go into the control panel and check the system settings. You might have it set to turn the monitor off after a low number of seconds of use. If you have it set for 30 seconds, if you don't use the keyboard or mouse for 30 seconds, the monitor will shut off. When you start to use it again, it will come back on.
Posted on Feb 10, 2009
Monitor will not turn on.
Could of damaged some internal parts sorry
Nov 27, 2013 | Myron & Davis Ans185mg 8.5-inch Flip Down...
Lg flatron w2240
You might need to change the monitor's power supply. I have seen similar problems with other LG models. Usually it is easier to replace the power supply than trying to troubleshoot it.
Replacing the power supply usually involves a few screws and a few cable connections. Troubleshooting the power supply board itself usually involves soldering replacements for blown capacitors.
Oct 26, 2013 | Computers & Internet
Monitor screen goes white at start up
That could be the monitor or the video/graphics card in the computer. Try another monitor as a test to narrow the problem. If it's a laptop, therer's usually a VGA port where another monitor can be installed. You might need to press a Fn key combination to turn on the second monitor in that case.
Feb 04, 2018 | IBM ThinkVision L201P (Black) 20.1 inch...
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Apr 07, 2009 | IBM ThinkPad T42 Notebook
IBM Thinkpad T40 randomly shuts off
did the monitor turn off when it is in idle mode? it might be the monitor power options (it might have been set that when it is idle for an X minutes it will turn off). check the monitor power settings.
Mar 16, 2009 | IBM ThinkPad T40 2373 Notebook
Monitor goes off after a few minutes of use. when pressing the on/off button, sometimes will turn back on. if left alone will turn back on after a few minutes. when computer is off, sometimes will turn on...
1.check power supply section any dry points
2. To replace all electrolatic capacitors in Power supply
3.Check Connectors Properly connected Or Not.
4.Replaced Microswitches in Front pannle.
Oct 06, 2008 | ViewSonic VX910 19" LCD Monitor
Hp ms705 menu comes on without prompt
Even my monitor HPM704 does the same thing from 12Mar08. I bought this monitor an year before. It looks like this batch of monitors have issues from factory itself. Plan to get support from customer care.
Dec 28, 2007 | HP mx705 17" CRT Monitor
Computers & Internet Logo
492 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
