Question about Emerson Quiet Kool 10GV13 Air Conditioner
Heater coil I have a early to mid 1980's emerson quiet kool wall mounted heater/air conditioner. I have not been able to find the model number, but did see LR39028 on the motor mount. Only about 1/8  of the heater coil is getting red hot. Can you buy replacement coils for theses units still? Where can I locate the serial number for this unit?
  • luke bussenschutt May 11, 2010
    does it operate on cooling mode ok
5 Suggested Answers
SOURCE: Emerson Quiet Kool Drips Water into the house
depends on the unit. you will probably have to slide it out of its case and clean the outside part . there should be a hose that goes from the inside to the outside for the water to go out. this hose may be clogged, trapping the water inside. as i always say a picture of the unit always helps so i can identify it and tell you what to do to try and fix the problem. email the pics to eyg2181@yahoo.com
Posted on Aug 05, 2007
  • 230 Answers
SOURCE: Can a window air conditioner fit in an exhisting wall mount?
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Posted on Jun 10, 2008
tebot
  • 15 Answers
SOURCE: Emerson Quiet Kool 700 roof mount air conditioner
It should have a drain so that it runs down off the roof instead of into the motorhome. All a/c's have a drain somewhere and they all plug up occasionally. A/C techs always carry coat hangers.
Posted on Mar 30, 2009
  • 16 Answers
SOURCE: I have a 1985 Emerson Quiet Kool model 19LD4E
you may have to buy a cut to size filter from a hardware store
Posted on Jul 07, 2009
I need to remove the blower motor from my Emerson Quiet Kool model 1350, how do I do this..
First open the control panel and remove all wires of your fan motor from the control switch and the capacitor. Remove also the compressor wires. Unscrew all panels and move the evaporator farther from the mounting base Pull-out the fan motor assembly with the panels. Unscrew the blower, fan blade, and them from the assembly. Unscrew the motor and now it is free.
Aug 31, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
I need a master control knob. I don't know the model number of the Emerson Quiet Kool air conditioner.
Without the Model Number, it's hard to know what knob fits your model. However, the link below, may provide some help. But, having the Model Number would be a bulls eye. Remove the front of the AC unit. There may be a manufacturer's data plate inside, which would provide the model number.
http://www.appliancefactoryparts.com/airconditioners/emerson/emerson-knobs.html
Hope this helps you.
Jul 13, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
I AM LOOKING TO BUYI AN AIR CONDITIONER / HEATER LIKE THEY HAVE IN HOTELS. WHERE MAY I FIND THEM
It sounds like what you are looking for is a Packaged Terminal Heat pump go to this site http://www.hvacdistribution.com. They also sale units like the one you have pictured(through the wall air conditioner).If you want to shop around then search for the first one and then through the wall with heat or a heatpump.
Nov 12, 2010 | Emerson Quiet Kool 5JV53 Air Conditioner
Emerson quiet kool model.eqk 1350 f serialo 20e 808320 wont heat, does it have an element? where is it located?
I looked up the model number parts
Their does not appear to be a heating element associated with this ac nor a reversing valve so I don't think it has a heat feature. You could mount it backwards and heat an area. That would look weird.
Apr 29, 2010 | Emerson Quiet Kool 6GC53 Air Conditioner
BTU's on Emerson Quiet Kool A/C
AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
Emerson Air Conditioner #10HW42K through wall
First off, my model # is Emerson Quiet Kool 10HW42K. No it is not yet solved, however I am reaching out to a number of sources. Was hoping to get a simple answer since it is not a "repair" problem, but rather a "replacement problem". I am looking for another AC that will fit the original sleeve.
Jul 07, 2008 | Emerson Quiet Kool 10NW16K Air Conditioner
Emerson Quiet Kool A/C Filter
If you know where to find a filter for a Emerson Quiet Kool--Model # 18DD4H-EE
Serial # 21A 927552 Please let me know
beverleyed@yahoo.com
Thanks
Ed Beverley
Jun 07, 2008 | Emerson Quiet Kool 10GV13 Air Conditioner
Emerson Quiet Kool 10GV13 Air Conditioner Logo
97 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
