Question about Refrigerators
I changed the filter and got no ice.
I changed the filter and flushed out the line and reset the filter but I still can not make ice. I had the refrig. making ice with out the filter and then it stopped on its own. I bought the replacement filter thinking it would work but it has not made ice. What do I do???
The rubber washer around the end of the filter can sometimes shift to block the water flow to the icemaker without blocking the water flow to the water line. By removing and reinserting the filter, ensuring that the rubber washer was in its proper place, solved the problem for me.
Posted on Sep 03, 2009
  • 229 Answers
Have you made sure that the rotator forks aren't jammed by an errant piece of ice. If the forks cant rotate you wont make ice no matter what. This is the #1 problem I have seen on ice maker repairs. Check it out , hope this helps.
Posted on Feb 10, 2009
I put a new filter in my fridaire, but water dispenser not working, and ice maker not working
repairs should be performed by a qualified repair person. when replacing a filter make sure the filter properly installed. once secured get 3,1 gallon containers to purge the water line and reservoir. BEWARE! water may continue to run while flushing the water line. this is why you'll need 3 containers. once you are able to finish flushing the line and the water is no longer gray the flushing for the water dispenser is complete. dispose the ice in the container in the freezer. let the ice maker cycle a few hours then dispose the filtered ice. once copleted you're done.
Jun 04, 2017 | Refrigerators
After installing a stainlesssteel braided hose for my ice maker ( replaed a copper line) the ice cubes taste metalic. Is this normal?
No Its not normal, first of all did you flush the entire line and replace the filter at the same time? All of this is a factor. A stainless steel line is nothing more than a rubber hose wrapped in a steel mess, it very easy to move around and install. I think allow time for the water to settle and flush out the entire water system with a filter change should fix this issue.
Good Luck
Nov 03, 2013 | GE 5 foot Braided Hose water line ice...
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Icemaker isn't making ice; light flashes twice and cycles through this pattern. I just replaced the water filter and flushed the line but no ice has been made since changing the filter
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Sep 08, 2010 | Refrigerators
Skunky water/ice.
It will be good to clean well the full line leading to the filter.Since when the filter is changed you must make sure the supply lines had not been clogged. Now drain out the water for sometime after the new filter is changed as it will have a chemical smell. Flush off for sometime before you can start using. There cannot be any other reason than this , make sure there is no fault in the water inlet line.
Hope the filter that was changed was the original component. Hope you check this out. Good day
Aug 03, 2010 | Samsung RS2630SH Side by Side Refrigerator
Ice tastes bad. How do you flush the system?
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
May 14, 2010 | Kenmore 76579 Bottom Freezer French Door...
Fridge is one week old both water and ice have a metalic taste. My old fridge had no problem. The only change was I went from copper tubing to plastic.
You probably shook lose sediments that collected in your old water line. Flush as often as you can and the taste will dissipate soon. In other words; run the dickens out of the water and use up the ice to flush it out completely. You might also be tasting the newness of the ice maker and related components. Flush, flush, flush. Also helpful is to clean thoroughly with baking soda everything you can get to.
Jul 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
Change ice maker filter?
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
Jan 31, 2009 | KitchenAid Superba Architect KSCS25INSS...
Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Filtered water
what kind of supply line is going to the dispenser,, if you have well water you might want to think about even another filter in the line before the frige, change the supply line to copper if it is copper change it to another copper line,,, there is no reason for it to only happen to the ice maker,, what about the ice bucket and ice tray:{where the water fills to make the ice} try cleaning these also
Aug 04, 2008 | Maytag MFD2561HE Bottom Freezer French...
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
